Question about Epson Stylus C86 InkJet Printer
I installed new ink cartrages in my Epson C86
I installed new ink cartrages in my Epson C86 printer but the two red lights next to the power button keep flashing. I probably didn't get the cartarges in securly but the printer will not allow me to remove the installed cartrages.
  • 51 Answers
This is idicative of a waste pad counter overflow, the ssc printer utility can clear the inbuilt counter but if your using your printer a lot it would be a good idea to replace or clean the waste pad, its inside the printer and will bee messy but if your doing lots of prints it will be less messy than if it overflows
Posted on Sep 26, 2009
EPSON Stylus c86 with CISS - color and power led lit contantly
Download this file Epson Adjustment Program to reset your printer
blink lights because the ink counter of your printer is full and need to reset to zero
Jun 12, 2015 | Epson Stylus C86 InkJet Printer
Epson Stylus C86 printing blank pages.
Ensure the proper procedures for installing an ink cartridge was done. Next, perform at least two cleaning cycles (hold down the ALT and the Pause button on the printer panel to initiate a cleaning cycle). Print out the demonstration page (press the ALT button while applying Power). If the problem persists and there is no improvement, take the printer to an Epson Authorized Service Center.
Oct 28, 2010 | Epson Stylus C86 InkJet Printer
I installed new epson ink cartrage, but printer has red x and tells me to change ink again.? Can i just change only the bkack ink?
Yes you should be able to just change the black ink cartrage, A lot of printer wont allow other third party cartrages, is it a genuine epson ink cartridge? if so try cleaning the contacts on the cartrage.
Apr 25, 2010 | Epson NX415 All-In-One Printer
After installing new ink cartrages the two red lights keep flashing and I can't check the cartrages to see if they are seated properly
Do you have a message on your screen ??? Try printing a document or opening the print manager and see the error message - that looks like a maintenance error when your pads need to be serviced after a set number of prints.
Press the button to set the carriage in ink change position - while your carriage is in the ink change position UNPLUG YOUR PRINTER.
ONce printer unplugged from electrical wall socket - remove all carts, and then place them back one by one making sure you use the right color for the right slot - make sure they snap in securely, close the latch.
Now plug in your printer and wait for the initialization process and see if this works....
If you still get the blinking lights, you will need to locate the error message - your printer pad counter has reached its maximum and it needs to be serviced and reset.
There are reset software out there, but you need to change the pads or divert the tube to a tank outside your printer.
Sep 26, 2009 | Epson Stylus C86 InkJet Printer
C86 Epson printer will not print.
Please see your user manual for the meaning of the various light combinations, or if you don't have one, see:
http://files.support.epson.com/htmldocs/sc86__/sc86__ug/wwhelp/wwhimpl/js/html/wwhelp.htm
and look at "Diagnosing Printer Problems".
BOBDOYLE - can you confirm which red light is flashing? If it is the ink light, see the instructions for changing ink cartridges. If it is the paper jam light, check for a paper jam. If you still cannot fix it, come back with a new comment giving any further information.
If this advice was helpful, please rate it.
GUESTS - you both have quite different problems to bobdoyle. If you require specific further help, please register and post a separate request for help.
Feb 05, 2009 | Epson Stylus C86 InkJet Printer
Epson Stylus C86 Printer Ink Refill
The chip that is located on the cartridge has to be reset also. You can take it to a ink cartridge replacement store. They will reset the chip when they refill the ink, however, Epson doesn't recommend this of course. It is cheaper this way.
Aug 15, 2008 | Epson Stylus C86 InkJet Printer
Epson Stylus C86 won't print
You have to check if the waste pad of the printer is full. If this occurs, you have to call a technician to replace it (or yourself can do , if you are able to). With the waste pad replaced, you can reset the internal counter with this program :
http://www.ssclg.com/epsone.shtml
This program can show you if the waste pad is full, or what problem is happening.
Apr 07, 2008 | Epson Stylus C86 InkJet Printer
Printer not working
Red light near tear icon is indicating no ink, when you press ink button carriage should move to center of printer, if you open lid and look where it stops there is a arrow pointing to which ink need replacing, replace ink indicated with gen epson cart.
Oct 29, 2007 | Epson Stylus C86 InkJet Printer
EPSON STYLUS C86
Let's Try first if it can print without using your computer just to check if printer is working fine by itself.
step1
Make sure its not connected to the computer and there is paper loaded on the printer. Turn off printer, press and hold paper button (middle button) then press and release the power button (right button). If you can see a flashing green light release your hold on the paper button.
If it prints by itself good go to step 2 if not check what lights do you see. Solid red light on ink light (tear drop button) means one or more inks is empty. Epson printer will not print if one or more ink is empty.
step2
Check if computer can detect printer goto start/control panel/systems/ click on hardware tab and click on device manager
On device manager click on Universal Serial Bus controllers press on the "+" sign check if there is USB printing support on it
Check if there is a mark (ie. ?, !, red x mark). If none good there is no conflicts. If there is a mark right click on USB printing support and click on update driver and install recommended
Oct 21, 2007 | Epson Stylus C86 InkJet Printer
Epson Service warning
hi, try downloading the ssc utility (just google it). it lets you reset the ink counters, individual ink cleaning etc. once you've opened the main screen you need to right click to get all the other bits. hope this helps
Nov 20, 2006 | Epson Stylus C86 InkJet Printer
Epson Stylus C86 InkJet Printer Logo
223 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
