Question about Solar ES1224 Truck PAC 3200 Peak Amp, 12/24 Volt Jump Starter
WHAT TEST CRITERIA CAN I USE FOR THIS PACK - Solar ES1224 Truck PAC 3200 Peak Amp, 12/24 Volt Jump Starter
    President:
  • 1,723 Answers
This thing is a beast! What criteria you ask? What do you want to jump? The answer.... any damn thing you want!
3200 peak amps is huge.
1600 peak amps is huge! You have got it covered here friend.
  • 3200 peak 12 Volt amps.
  • 1600 peak 24 Volt amps.
  • Integrated voltage selection switch.
  • LED battery status indicator.
  • Automatic recharging.
  • 60" Heavy-duty cables.
  • DC outlet to power a variety of 12 Volt accessories.
Posted on Sep 26, 2009
Is there any salary criteria for taking a home loan in Indore?
Yes, in some financial institutions, they have some set criteria of getting a home loan. Among them, one of the criteria is you need to earn as per the city standard you are residing.
Like for example, if you are residing in Delhi or Mumbai, your minimum net salary per month should be Rs. 50K. Similarly, if you are residing in Bangalore, Chennai, Faridabad, Ghaziabad, Gurgaon, Hyderabad, Noida, Pune or Thane, your minimum net salary per month should be Rs. 45K. Other cities like Ahmedabad, Goa, Kolkata, Mysore, Nagpur, Nasik or Indore, minimum net salary per month should be Rs. 40K.
But this factor is not compulsory or mandatory criteria. So, every lender does not ask for it. There are some common eligibility criteria of getting a home loan in Indore. Those are:
  • You are an Indian resident.
  • You are between 25-58 years of age.
  • You are a salaried individual with a work experience of 3 years or more.
  • You need to deposit a few necessary documents to the lender.
Oct 16, 2017 | Computers & Internet
Criteria for age pension
australian citizen
age 65 and older depending on birth dates
asset test (excluding home) applies and reduces
pension if assets above a prescribed amount
income test applies and reduces pension if income is above a prescribed amount
details of asset and income tests are on govt website or talk to centrelink
May 07, 2014 | Computers & Internet
What are the criteria one should use to judge bed sheets?
There are some important parameters on which you can judge any bed sheet like-
Good Thread Count
Quality weave and finish
Good quality yarn with long staple cotton etc.
To purchase quality bed sheets in India, visit- http://www.maspar.com/bed-linen/bed-sheets.html
Jan 15, 2014 | Furniture
TEST FOR THE EQUALISER DN360
You are not likely to get the specific test criteria except from the manufacturer diredtly. Also, unless you have accurate testing equipment, you won't be able to confirm the accuracy anyways. Is there a specific problem that you are trying to solve? Realize that each band of the EQ has a cutoff curve and is not a singular frequency adjustment. Perhaps if you describe what you wish to know, we can provide additional details.
Also, can you confirm the make of the unit. I know of a Klark-technic DN360 but not a Koss.
Thanks,
Dan
Jun 09, 2010 | Koss Audio Players & Recorders
Number one cyl on coil pack not firing, all others are, codes reads misfire on 1 cyl should i replace the coil pack and how do you test the pack
Check the spark plug first. then if the plug is good you wil need a digital ohm meter to test the coil pack. if you need to know how to remove the coil pack let me know, to test put on ohms should not have more than 2 1/2 ohms restance betweent coil lead to coil connector. If you test the coil pack on both sides of the pack and get a reading then the coil is bad, if it does not read then you haave a bad fireing plate diode.
Mar 12, 2010 | Ford Explorer Cars & Trucks
Check Engine Light
stop by an autozone and let them check it for you , they will scan it , and tell you what code(s) you have and the meaning , since you say its the day after a fill up it sounds like an evap leak , the car will run self diagnostic tests on itself and the evap tests would have criteria to meet before taking the test , one would be how much gas in the tank to take the test , then it won't run self test again till criteria is met again .
J5
Jan 19, 2009 | 2002 Honda Accord
P1127 HO2S Bank 1 Sensor 2 Heater Not On During Key On Engine Running Self Test
You have to drive the car for a certain number of drive cycles for the test to be run by the OBD II system, certain criteria have to be meant for self test to start, it may take days before it completes. Be patient.
Aug 05, 2008 | 1999 Mazda 626
Solar ES1224 Truck PAC 3200 Peak Amp, 12/24 Volt Jump Starter Logo
216 people viewed this question
Top Solar Electrical Supplies Experts
Steve
loft404
loft404
Level 1 Expert
Craig Butler
Craig Butler
Are you a Solar Electrical Supply Expert? Answer questions, earn points and help others
