Question about Nikon Travelite V Binocular
Each eye is clear, but they aren't lined up right...it is like being crosseyed.
  • 121 Answers
This is more common than you would think.. Here's how to set up a pair of binoculars to suit yourself.
Any good binocular will be able to do this and the reason is to allow you to adjust them for the difference in strenght between your two eyes. I wear glasses myself and sometimes contact lenses so it's good to be able to quickly adjust them.
1. turn the binoculars over so you are looking at the underside.
2. on the eyepieces can you see on one eye(usually the right eye) a little plus - minus marking. The eyepiece should be able to rotate a little to each side of this marking.
3. Set the rotating eyepiece to the middle setting.
4. Look through the binoculars as normal and bring the two sides together until you form the two circles that you see into one.
5. Pick an object app 10 meters away.
6 Presuming that the adjustable eyepiece is on the right hand side then close your right eye, look at the middle distance object you chose with your left eye and use the central focusing knob/wheel in the middle to bring your left eyepiece into focus.
7. Now, close your left eye and adjust the rotating right hand eyepiece while looking at the same object until your right eyepiece is in focus.
8. The binoculars should now be set for the differences in strenght of your eyes and you can use the middle focus control as normal.
Most binoculars have a soft rubber eyepiece that can be folded back for people who wear glasses but I, like most people I know who wear glasses, find it horribly uncomfortable.
This method allows you to set them for yourself and if someone else uses your binoculars you can quickly reset them for you.
Hope this helps...
- Oh yeah, sorry, forgot to mention.. This set up is so you can use them without wearing your glasses.. Much more comfortable!!
Posted on Oct 20, 2009
Fisher and Paykel Dishwasher beeps while it washes dishes. Any solution?
Here is a suggestion: I had problems with the top drawer on a model 603I, I found that the control board under the drawer cover (at the upper right corner) had a broken latch. This allowed the control board assembly to drop down at the right side which caused the electronic eyes at the side of the drawer to become misaligned. This was giving false information to the control board indicating that the drawer wasn't closed properly. My problem was fixed by securing the control board back in place making sure the electronic eyes were lined up properly. (Note: The electronic eyes I am referring to include two clear plastic tubes about an inch and a half long to the right of the control board. These tubes must be properly lined up with the led and photocell on the side of the control board) It sounds complicated but if you take the drawer cover off you will notice the control board alignment immediately. Its an easy fix if this is your problem. One way to fix it is to take a piece of string and tie the board back in place. (That's what I fixed mine with and it has worked like new ever since.) NOTE: MAKE SURE THE POWER IS TURNED OFF BEFORE YOU BEGIN THIS REPAIR!
Nov 21, 2013 | Fisher and Paykel 23 in. DD-603SS Built-in...
Tip
How to Put on Eye Shadow
Achieving Smoky Eyes.If you're looking for a way to play up your eye color, go smoky. A smoky effect makes eye color pop and creates a dramatic evening look. Read on to learn how to create a flawless smoky eye. <br /><br />Create a smooth canvas for eye makeup. First, you'll want to apply a primer to your entire face, including the eye area. Then apply a concealer to get rid of redness and dark circles. Finish off by applying a moisturizing foundation to create a flawless canvas. <br /><br />Apply eyeliner. Use a black liner and draw a line across the upper lash line. When you get to the middle of the eye, make the line a little bit thicker. Choose a lighter-colored eyeliner and line the bottom of your eye. Smudge the liner with your finger to create a smoky appearance. <br /><br />Apply two colors of eye shadow. In order to select the right products, check out eye shadow reviews. You'll want a color palette that has both a light and a dark color, such as L'Oreal Paris HiP Concentrated Shadow Duo. Use the lighter color as a base and blend the color all over your upper lid. Then, apply the dark eye shadow, starting at the lash line and blending upward.
on Nov 22, 2010 | Health & Beauty
Dd605 ss does not complete cycle
Nov 16, 2013 | Fisher and Paykel 24 in. DD603H W Built-in...
Vertical lines on wd-62637 mitsubishi dlp tv. went away at first now are on constsntly
You probably have a bad signal board. Try heating it to see if the lines clear up where all the inputs go.
You may need to get a repair man to fix this, for the parts aren't on ebay.
Jun 19, 2011 | Televison & Video
The focus between the two lenses is not synchronized; when I zero the eyepiece lenses and try to use the center wheel to focus, I can only get one clear image at a time.
Here's how:
Focus the left side first.
Close your left eye and now rotate the right hand eyepiece (dioptre ring) until the right hand side is clearly focused.
Open both eyes! Surprise! both sides should now be in focus simultaneously!!
Jan 29, 2010 | Nikon Action Binocular
Problems may a child encounter when its mother drinks alcohol during prognantcy
well he'll have a taste for it and will not walk straight. might even be born crosseyed and have hiccups.
Sep 29, 2009 | Rockstar Games Grand Theft Auto: San...
Hello My printer(3100 cn dell) every time I
This means that loose toner powder has gotten in the way of the lazer "eye". If you open up the front door, you will see a blue tab toward the right, pull that toward you, then look on the right side of the printer, you will see that a door has opened. Pull that blue stick out as far as you can and you will see some toner powder on that, clear it off, and make sure the little pad is clean. After you have cleared the powder off, slide it back in and out a few times, this will clean the eye. Run another document through, if the line is still there, just clean another time. Should go away. I have this problem alot.
Aug 13, 2009 | Dell 3100cn Laser Printer
Have 7 x 50 vivitar binocs cant get it lined up for both eyes
One of the two eye pieces should be adjustable. Try turning the one until you see clearly through both.
Apr 26, 2009 | Vivitar Optics
Nikon Travelite V Binocular Logo
497 people viewed this question
Top Nikon Optics Experts
George Merkley
George Merkley
Are you a Nikon Optic Expert? Answer questions, earn points and help others
