Question about Maytag MSD2756G Side by Side Refrigerator
Not cooling fridge is not cooling
  • booscloud Sep 28, 2009
    nothing but the lights
    President:
  • 1,197 Answers
If the refrigerator isn't cool, you need to answer some questions, then see if the compressor is running.
First, answer these questions:
Is the refrigerator completely dead? If so, see “It's stopped completely.”
Is the thermostat knob turned to the proper setting? If not, reset it.
Next, see if the compressor motor is running
The compressor is a football-sized case with no apparent moving parts. It's on the outside of the refrigerator at the back near the bottom. If it is humming or making a continuous noise and your refrigerator is still not cooling, there may be a more serious problem with one or more of several different components, we recommend contacting a qualified appliance repair technician for further help.
If the compressor is not running but you do have power to the refrigerator, there may be a problem with one or more of these:
The compressor
The Thermostat
The overload, relay, or capacitor
The defrost timer
The condenser fan motor
Cooling is poor
For an overall understanding of how refrigerators should work, read about refrigerators in the How Things Work section of our website. A refrigerator or freezer that is cooling, but cooling poorly, may have a problem in one of several areas:
Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt.
Evaporator coils
Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system:
The defrost timer
The defrost thermostat (also called the bi-metal switch)
The defrost heater
to check these components .... please refer to my solution in the below link....
http://www.fixya.com/support/t4189238-defroster_not_working_checked_defrost
If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem
Condenser
Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush (see the Appliance Accessories section) and your vacuum cleaner to clean the coils of any lint, pet hair, etc. You may not be able to get to all of the condenser from the front, it may be necessary to clean the remainder of the condenser from the rear of the refrigerator.
If I've been of Help to you... kindly take a moment to rate this solution.
Posted on Sep 10, 2010
Fridge quit cooling. The heating element works and propane works. Gets really hot but fridge does cool. There was no smell of ammonia and no yellow residue. What could it be?
How can "fridge quit cooling" but later you say "but fridge does cool" of course this absorption cycle system gets hot on the outside, heat is the "driver" of the system rather than an electrically driven compressor in the normal fridge. Is this a homework problem?
Apr 06, 2015 | Refrigerators
My whirlpool fridge makes a loud humming noise when the door is closed. It is not freezing items in the freexer and is not cooling items in the fridge section. The freezer is above the fridge section in...
The fan is hitting ice build up...
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 11, 2010 | Whirlpool Refrigerators
Fridge not cooling
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jul 10, 2010 | Maytag 22 cu. ft. Bottom Freezer...
Freezer is cold fridge is not
heatman101
Jun 02, 2010 | Kenmore 57029 Side by Side Refrigerator
Jenn-Air JCB2389GRS Fridge not cooling properly
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
puiodf
Mar 15, 2009 | Jenn-Air JCD2389G Side by Side...
Fridge part of fridge freezer not cooling
heatman101
Aug 16, 2008 | Hotpoint FFM90 Bottom Freezer Refrigerator
Maytag MSD2756G Side by Side Refrigerator Logo
406 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
