Question about Panasonic SC-RT50 System
Error code U61 Unit is stuck in recovery mode. How do I convert back to normal operation?
SOURCE: U61 CODE WONT GO AWAY
I buy broken units reds repair 870-656-5139
Posted on Feb 25, 2008
SOURCE: Panasonic DVD SC-RT70 whilst
I have a SC-RT70 model and there is U61 error code in my dvd player's display. what does this error means?
Posted on Jul 01, 2008
  • 5 Answers
SOURCE: Model No'DMR-ES15 - U61problem
I get this message occasionally on my Panasonic DMR-ES15. It's actually a really simple fix. It occurs when there is a corruption in the disc which causes the recording mechanism to malfunction. There is a separate error message for this, however it is usually not detected until it's too late. When the recorder asks you to carry out the recovery process, do it. When the disc ejects, make sure you take the disc out that was in there when it occured and throw it away...it will keep happening because the disc is permanently corrupted. However, do not close the tray without a disc or the self-check will fail. Instead pop in a disc of the same format that the error occured in (if it was DVD+RW then put in a DVD+RW). It resolves the problem every time on the first try. (It only happened two times in a year and a half for me). As the manual says the unit is "NOT BROKEN".
Posted on Aug 11, 2008
shinma
  • 5 Answers
SOURCE: Error code U61 on a
The manual refers to the U61 as being a recovery mode. Have you left it at U61 for a period of time while it tries to recover?
U61 ≥There was a power failure or the AC plug was disconnected while the unit was on. The unit is
carrying out its recovery process. This process restores the unit to normal operation. The unit is not
broken. Wait until the message disappears.
You could always try to force it into standby mode and back out again:
Press [í/I, POWER] on the main unit to switch the unit to standby.
Now press [í/I, POWER] on the main unit again to turn the unit on.
If that doesn't take care of it, everything thing I've found points toward a replacement of components inside the system by a repair service. Hopefully you are still under warranty!
Posted on Sep 21, 2008
gripfitter
  • 557 Answers
SOURCE: U61 ERROR ON DISPLAY
U-61 is a hardware error code. Usually means main board failure, however have found that a bad changer can also trigger that code since it connects directly to the main board.
Posted on Sep 21, 2009
Panasonic dmr-es46v player recorder error code u61. what do i due
That error means: There was a power failure or the AC plug was disconnected while the unit was on. The unit is carrying out its recovery process. This process restores the unit to normal operation. The unit is not broken. Wait until the message disappears.
I suggest you unplug all the cords o the unit and after 2hrs replug and see if the error is gone.
Let me know the result.
Thank you for using fixya.
Jan 03, 2010 | Panasonic DMR-ES46VS DVD Recorder/VCR
Unit will not start
Sounds like my woman.  The thing is looking for a signal.  Hook the TV or stereo receiver up to it or put a DVD in the tray.  Some DVD players take a bit to power on so you might just be an impatient lot.  Take the thing back to the shop and exchange for a different brand like Sony or Samsung which power up quicker and are more user friendly.
Oct 29, 2009 | Panasonic DMR-E85H DVD Recorder
U61 Code will not reset - any suggestions?
You have the same issue as the one who is posted here at Fixya. But this requires you to open the DVD cover. If the unit is still under warranty, its best to bring it to the authorized service center. If not, you can try and test this if it'll work.
http://www.fixya.com/support/t221217-u61_error_code
"I have the same problem (same error # same model of DVR).
I noticed it happened after I left a DVD in play mode and paused for a long time.
I saw a message on the Internet that error U61 can mean that the lens is unable to move (return to its normal position).
The Internet message said that person unpluged everything, then opened the cover to the DMR-ES15 (3 screws) and gently pushed the DVD head back towards the rear of the DMR-ES15.
I assume that would void his warranty, but I am considering trying it since the time to have it repaired versus the replacement cost makes the possibility of a "self-repair" attractive.
Here is part of that actual Internet message. I hope it helps you:
Yesterday, my DMR-ES15 started to malfunction, giving me the error U61.
No matter how many times I tried to press Enter, and Power On, the machine
kept re-booting with the error U61. I noticed that the drive was making some noises as if the Read head was not able to park properly.
So I decided to open up the unit and find out why.
I took out the 3 screws holding the top in place. And then moved
the drive head mechanism back (pushed it towards the back of the unit).
I then plugged the power in, turned it on, and amazingly there was no more U61 error.
I test the unit this morning again and everything seems to work properly again!"
Aug 17, 2009 | Panasonic DMRES15 DVD Recorder
U61
According to the owners manual the U61 error is listed below. (Page 47)
You can download the owners manual here.
http://service.us.panasonic.com/OPERMANPDF/DMRES25-MULTI.PDF
I would recommend trying to unplug the unit overnight and then plug it in and see if this helps. Not sure what you might have tried, but this may help.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If not then please comment to this post and I will try to help you further.
May 10, 2009 | Panasonic DMR-ES25 DVD Recorder
PANASONIC DMR-ES35V have error code U61
From User guide:
U61 • There was a power failure or the AC plug was disconnected while the unit was on. The unit is carrying out its recovery process. This process restores the unit to normal operation. The unit is not broken. Wait until the message disappears.
If fail unplug and hold power button for a minute or two and turn it on and repeat.
Feb 26, 2009 | Panasonic DMRES15 DVD Recorder
U61 error problem
Sep 12, 2008 | Panasonic DMR-ES35VS
Error code U61 on a panasonic DMR-ES35v When I turn it on it says "Please Wait" end the code U61 occurs after som while.
Aug 30, 2008 | Panasonic DMR-ES35VS
U61 error code
UMM the DVD top lid uses FOUR screws. The entire DVD drive is bolted to the chassis with 3 screws.
Oct 14, 2007 | Televison & Video
Panasonic SC-RT50 System Logo
47 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
