Question about HP OfficeJet 7110 All-In-One Thermal Printer
Model d145 Serial #SG2BRD2030RR, Service #13281. Repeated scanner failure. Turn power Off then On again and slow warm up. Have t0 run a copy before it will scan. Also recent problem. Bad Printhead Replace Yellow. Replaced Yellow in August, and Yellow again and all others 9-3 thru 9-17, still same problem. Ink cartridge and Printhead Print Out Good. What next?
  • 615 Answers
Please let me how this worked for you and please do not forget to grade my assistance so I am able to continue to provide you with better service. I will be working with you to conclusion of the issues.
According to teach supports at HP this issue a common one, to fix the issue please follow the step by step instructions that follows:
The message 'Scanner failure, Power off and on' displays on the control panel of the product. This error can occur when you try to scan or make copies, or when the product is warming up after you turn it on. They have two ways to fix it the first one as follows:
Solution one: Check the scanner light
Make a color copy of any document by pressing the Start Copy Color button on the product control panel. While the product is making the copy, lift the scanner lid slightly to see if the scanner light is visible.
Do not open the scanner fully to look at the light just a small opening so you do not hurt your eyes.
If the scanner mechanism moves across the scan bed, but the light is not lit, proceed to Solution six: Service the product .
If the light is lit, proceed to the next solution
Solution two: Check operating conditions
Extreme temperatures can affect the operation of the product. Make sure the operating conditions match those recommended in the User Guide provided with the product.
Solution three: Check the power connections
Make sure that the part number on the power supply matches the part number listed in the User Guide .
Disconnect the power cord from any power strips or surge suppressors, and then plug it directly into a wall outlet.
Try making a color copy by pressing the Start Copy Color button on the product control panel.
If the copy job is successful, you do not need to continue troubleshooting. Power strips and surge suppressors can sometimes prevent enough voltage from reaching the product.
If the error message displays again, temporarily move the product to a different room, or plug the power cord into a different wall outlet.
If the error message displays again, proceed to the next solution
Solution four: Perform a power cycle
Turn the product off.
Unplug the power cord from the product.
Wait 30 seconds, and then connect the power cord to the product.
Turn the product on.
Make a color copy by pressing the Start Copy Color button on the control panel.
If the error message displays again, proceed to the next solution.
Solution five: Reset the product
Follow these steps to reset the product.
Step one: Perform a partial reset
Disconnect the power cord from the product.
Press and hold # and 3 while reconnecting the power cord to the product, and then release both buttons.
If the partial reset resolves the issue, you do not need to continue troubleshooting.
If nothing worked, go the next step.
Step Two: Perform a semi-full reset This may delete all phone numbers on the unit
Press and hold # and 6 while reconnecting the power cord to the product, and then release both buttons.
If the semi-full reset resolves the issue, you do not need to continue troubleshooting.
If this did not fix the issue we can go to step two and that a software cleaning and manual cleaning...I know this is too long but it will help in the long run...God bless
Posted on Sep 26, 2009
What does it mean when it says scanner failure?
Hello it means that the scanner bulb temperature is too low or there is some internal or external electrical malfunction.Try these solutions.
1.Check the scanner light.Make a color copy of any document by pressing the Start, Copy, Color button on the product control panel.While the product is making the copy, lift the scanner lid slightly to see if the scanner light is visible.
2.Make sure that the room temperature is suitable for your device
3.Perform a Power Cycle on the unit by following the steps below:
1.Turn the unit off.
2.Unplug the power cord from the unit.
3.Wait 30 seconds, and then re-connect the power cord to the unit.
4.Turn the unit on.
5.Make a color copy by pressing the Start Copy Color button on the control panel.
4.Check the power connections.Disconnect the power cord from any power strips or surge suppressors and then plug it directly into a wall outlet.Try making a color copy by pressing the Start Copy Color button on the product control panel.If the error message displays again, temporarily move the product to a different room, or plug the power cord into a different wall outlet.
5.Perform a partial reset
1.Disconnect the power cord from the product.
2.Press and hold # and 3 while reconnecting the power cord to the product, and then release both buttons.
3.Try making a color copy by pressing the Start Copy Color button on the product control panel.
6.Perform a semi-full reset(Performing a semi-full reset deletes any saved phone numbers on the product).
2.Press and hold # and 6 while reconnecting the power cord to the product, and then release both buttons.
If nothing of these works and you still see the error you should take your printer to support service for repairing the parts.
Feb 08, 2010 | HP OfficeJet d145 InkJet Printer
Scanner failure
Since when this problem started (have you done any updates or instalation of application,), Have you try Reset the Printer after replug and power on.
Please find updates for your Printer from the Official website of HP
Also check out if you can go for Reinstall the Printer (best option): HP- D145 Officejet
Nov 01, 2008 | HP OfficeJet d145 InkJet Printer
Scanner failure
replace the scanner or the whole unit. only way I have found is to replace the top half of the machine
Oct 16, 2008 | HP OfficeJet d145 InkJet Printer
Scanner Failure
The only thing I can surgest is that you check installed programs I found that the 750 is very fussy about being the only kid on the block. Maybe worth trying a commercial program that says it will remove "junk" from your hard drive
Aug 24, 2008 | HP PSC 750 All-In-One InkJet Printer
Scanner failure message.
Scanner Failure, Power Off and On' Message Displays on the Control Panel when Copying or Scanning
Issue
This error usually occurs when trying to scan, to make copies, or during the product start up.
Try the solutions in this document until the issue is resolved. It is not necessary to continue to the next solution if one solution resolves the issue.
Make a color copy of any document by pressing the Start Copy Color button on the control panel. While the product is making the copy, slightly lift the scanner lid to see if the scanner light is visible.
CAUTION: Do not look directly at the light. It is not necessary to completely open the lid to see the light.
If the scanner mechanism moves across the scan bed, but the light is not lit, click here to service the product .
1.
Make sure that the product is connected directly to a grounded wall outlet and not plugged into a power strip.
2.
3.
If the error message persists, temporarily move the product to a different room or outlet, and then make a color copy by pressing the Start Copy Color button on the control panel.
4.
Check the part number on the power supply to make sure that it matches the part number listed in the User Guide.
1.
2.
3.
Wait 30 seconds, and then reconnect the power cord to the product.
4.
5.
1.
2.
Press and hold # and 3 while plugging in the power cord.
3. Make a color copy of any document by pressing the Start Copy Color button on the control panel.
If the partial reset resolves the issue, do not continue to the semi-full reset.
Step two: Perform a semi-full reset
CAUTION: Performing a semi-full reset deletes any phone numbers that are saved on the product.
1.
2.
Press and hold # and 6 while plugging in the power cord.
If you have completed all the steps listed above and are still experiencing a problem, service the product.
Mar 05, 2008 | HP OfficeJet d145 InkJet Printer
Scanner failure
scanner failure, turn unit off and back on, does not help
Oct 01, 2007 | HP OfficeJet d145 InkJet Printer
HP OfficeJet D145 unable to print or scan
It could be the bulb. Sometimes disassembling the scanner and thoroughly cleaning the glass and mirror will help.
Jul 20, 2007 | HP OfficeJet d145 InkJet Printer
Scanner failure
Checxk the manual for FAQ's Check makers tech help site,looks like a service job
May 10, 2007 | HP OfficeJet d145 InkJet Printer
Scanner failure
I assume from your remark you are using this as a stand alone device or are you connected to Computer? If you are using as stand alone try through the computer. If you are using it through the computer then simply re install the software. If you are using it as stand alone only. Contact the makers website for more detailed support.
HP OfficeJet 7110 All-In-One Thermal Printer Logo
71 people viewed this question
Seeker5211
Seeker5211
