Question about Aiwa NSX-A777 Shelf System
Why does my stereo shut off when I turn it up it
Why does my stereo shut off when I turn it up, it just started happening. Once I get it to about 25 or so it just shuts off and its very! frustrating.
    President:
  • Aiwa Master
  • 1,114 Answers
Check your speaker connections, make sure wires are not touching each other. If this is ok, then check your speakers with a meter for an internal voice coil short. (blown) If you don't know how to use a meter, take your speakers to a local "Radio Shack" or electronics shop and they can test them very quickly. If wires and speakers check out ok, you have an internal problem with the system and it will need serviced. Hope this helps.
Posted on Sep 26, 2009
My stereo restarts when I shut off the car engine even though I am leaving the key in the 'on' position.
This forum is for video cameras and camcorders. Please repost this query in a forum dealing with vehicle accessories. Thank you
Mar 12, 2017 | Kenwood Video Cameras
Repeated off and on
speaks are hooked up wrong or speakers are blowin.
Apr 01, 2010 | JVC KD-SX980 CD Player
Sony xplod XM ZR602
What ohm is your sub running at. Sounds like your runnig your amp to low an impedance causing it to thermally shut down, when it cools a bit it turns back on. Either that or you have wires crossed somewhere. Check your wiring and make sure the load of the speaker does not fall below the rcommended ohm of the amp. Usually 4ohms mono and 2ohms stereo
Sep 07, 2009 | Eclipse EA3422 Car Audio Amplifier
JVC KD-LX333 car stereo turns on, but then shut off and wont...
TAKE IT OUT AND TRY IT ON A 12V BATERRY AND IF IT TURNS ON ITS GOOD AND IF IT DOESNT IS NOT GOOD. IF IT TURNS ON FOLLOW UR CONSTAN AND UR POWER WIRES AND SEE IF IT HAS A FUSE BOX IN THE BOAT/ CHECK THOSE FUSES. AND CHECK UR BOAT BATTERY TOO CAUSE IT COULD HAVE DIED WHEN TESTING THE STEREO TOO IT HAPPENS ALOT ON BOATS
Jul 04, 2009 | Sony CDX-GT210 CD Player
CAR STEREO AND CLOCK DONT WORK, LOCATION OF FUSE 25
You are correct on checking the sterio, just 12+ and ground to see if it powers up. Fuse 25, in your fuse box should be numbered. If not, just pull them one at a time to see which one got fried.
Apr 04, 2009 | Hyundai Motor 2002 Sonata
Car stero doesn't come on
You have it wired wrong. With the fuse out it is like disconnecting the wire, thus removing the fault. Be glad it is shutting down. It is protecting itself from damage and electrical overstress. Trace the wire, my guess is it is a power wire that is grounding. Check all of your wiring again.
Feb 24, 2009 | Car Audio & Video
Volume turned up, kenwood shuts off briefly...
does it keep cutting in and out?
if so i think you have your polarities crossed
make sure you have negative to negative positive to positive
Jan 27, 2009 | Kenwood KDC-X692 Car CD/ MP3 Player
Power problems
The set is detecting a problem internally and shutting down to prevent further damage. This is often call protection mode. I would guess that there is either a bad connection somewhere or a part starting to fail. If there is a pattern to the failures, a quick trip to the repair shop is in order armed with that info. Rough guess would be abaout $30 in parts plus the local labor rate. This is based upon my own repair experience with these systems.
Dan
Mar 26, 2008 | Sony MHC-GX450 CD Shelf System
Aiwa NSX-A777 Shelf System Logo
268 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
