I have a RUUD AC Model UPFA 060JAS, Serial # 3687 F4787 3195. My dog ripped the wires apart on the outdoor unit. Wire coming out of the house (6) are colored red, blue, white, green brown, and yellow. Wires (4) out of the unit are colored red,green blue and white and there are 4 wire nuts. How should I match them up? Thanks. Paul
    Sergeant:
    Champion:
  • 232 Answers
Paul, you will need to look at the indoor unit and determine which wires from outside are connected inside. let me know. more then likley they color coded it but better to be safe. also does the fan inside still run if you switch thermostat to fan ON. if not the transformer may have blown, if yes you need to make sure you shut the breaker controlling the inoor unit off while your messing with the wires, or you will blow the transformer in the furnace
Mac
Posted on Sep 26, 2009
My customer has a Rudd Model UBHA-14A00NFAA air handler. I have replaced the 24 volt transformer twice and am about to install a third one. Initially it was suggested to me that the transformer in the...
John from one service man to another, most of the time I have seen that many transformers fail is when there is bare wires touching somewhere from the outdoor unit to the air handler. This cause a small short in the circuit. Usually its when there is a crawl space under the house or even when the wiring is up in the attic. I have seen birds, squirrels, dogs and even rats chew thru thermostat wire. Hope this helps you . Have you thought about putting a small 5 amp fuse in series with "C" on the thermostat?
Jul 11, 2011 | Ruud Heating & Cooling
The unit is not communicating between the Furance and the AC
Then it is not communicating with the thermostat. When you turn it to cooling and the fan comes on, then the thermostat is communicating
with the furnace.
If you have 24volts between Y and C then it is communicating with the AC Unit. If you go outside and remove the electrical panel(shut off power
to outdoor unit) you can still hear the contactor being pulled in.
If you cannot hear that you need a new two wire from furnace to outdoor unit
Jul 16, 2010 | Ruud UAMB024 Air Conditioner
My dog chewed through a group of multi-colored wires on my AC outside. Is there any way that i can fix this?
HI there well i think what you dog chewed on was the thermostat wires. if you tell me the colors maybe i can help you out.
ordonez305@aol.com
This is my e-mail
Jun 03, 2010 | Ruud UBHC Air Conditioner
We have a RUUD AC unit, model number UAMB-042JAZ. ...
Those are the low voltage wires from the thermostat and transformer. Yes he can just match up the colors and splice with wire nuts or something else to hold the tight. If the transformer got shorted out during any of this it may need to be replaced. Hook them up and if the unit runs, then no problem with the transformer.
May 21, 2010 | Heating & Cooling
My dog yanked a brown wire out of the outdoor ac unit that has the fan. how do i rewire it?
If it is the small wire, that goes to the coil on the contactor. It is a low voltage wire that comes from the thermostat. You need to disconnect power from the machine before attempting any repairs. Do not short the small wires or that could fry the transformer
On each side of the contactor is spade connections to the 24 volt coil. All machines use a magnetic contactor as a way to energize the machines parts using smaller wires coming from inside the house at the thermostat and inside blower.
Apr 19, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
Thermostat wires running from house to outside Kenmore AC unit were chewed by dog. Got replacement wire. Took panel off. There were three encased wires running into AC unit that were chewed. Only see...
If you have a central air conditioner, or a split system, where the indoor unit is attached to the furnace and a outdoor unit is located outside of the home. 2 copper lines will be connected to it, a larger and a smaller one. If it is a air conditioner and not a heat pump, the A/C usually uses 2 wires, that are connected. Allot of times a installer will use a 3 wire thermostat wire, to run to the outdoor unit, if this is the case, the third wire will be folded back out of the way.
The color of the wire is usually picked by the installer, I myself usually use white and red and fold the green out of the way. If you only had 2 wires hooked to it to start with, it really would not make a differace which one you hook up to either one of the yellow wires.
All you are doing it having one wire coming in and one wire leaving,,,, just creating a complete circuit, just don't connect the two yellow wires together.
Example: If you have 2 yellow wires on the A/C unit and 2 wires coming from the house "example a red and a white" hook the white to "One yellow wire" and the red wire to "the other yellow wire".
You are just creating a complete circuit, when the thermostat calls for cooling, it creates a magnetic pull and closes the contact points, in the air conditioner, outside, this allows the 220 volt to flow to the compressor,,, and ahhhh cooling!
I hope I have not confused you, I am just starting to help on this site and still trying to make things understandable.
Wish you the best,
Paul Gibson
Mar 29, 2010 | Heating & Cooling
Trying to wire RUUD gas furnace. connection block
No problem have done this many times. R from the t-stat goes to R on the indoor unit. G goes to G Y goes to Y and C goes to C if you have a C or the t-stat the you are using. If there is no C there dont worry about it. It only need to be hookup if the t-stat uses power from the unit to run. Many t-stats today use battery power and do not need the C wire hooked up. Now R and C from the outdoor unit. R goes to the Y on the indoor unit and C goes to C on the indoor unit. That means that you may have two wires under the Y terminal and sometimes under the C terminal on the indoor unit. If on the outdoor unit there is no designation of R and C dont worry, just hook one wire to each of the two wires there for your low voltage connection. It does not matter which one goes to which unless they are marked then it may matter.
This should get you up and running and see it really isn't that hard!! :-)
Nov 14, 2009 | Ruud UBHC Air Conditioner
Ruud UAKB-018JAZ outside condensing unit will not run
Trace the wires (small cable) going to the out door unit. This is your 24v control circuit. when it enters the outdoor unit it ties to wires routing through the inside of the unit trace these down. For AC units 1 usually goes directly to the "contactor" (the item you push in and the unit runs?) the other wire can also go to the other side of this same item. But I suspect it goes through other tings before it finally gets there.
Some items are the high and low pressure switches and a delay timer.
A red button sticking out where you can reset it is the high pressure switch and if it clicks and lets it come on you may have a dirty outdoor coil or a fan motor outdoor that is not operating all time.
A low pressure switch has no reset normally on AC or HP.
A delay timer will have 2 3 or 4 wires depending on the type of timer. 1 of these wires goes to the contactor (usually) and one of them feed this wire. remove the wire going to the contactor. now 1 at a time take the other timer wires and touch them to the wire just removed. if the times is bad the contactor will click when you touch one of them with the removed wire.
If its a heat pump you will have to make the contactor try to come on around the board. and this you will need some knowledge on which and what feeds your contactor. Here Id suggest a technician. If I had a way to see your setup and wiring I could talk you through this but its too hard to type and would take way too long.
Jun 27, 2009 | Ruud UAKA042 Air Conditioner
Wiring connection for a Ruud air handler & seeking its wiring diagram.
we are trying to install a goodman heat pump with a rheem air handler, the orange wire is hook up and the unit is still staying in the heat mood. does anyone have a wiring diagram for the air handler, their is some white wires in the air handler one with a purple strip and one with a black strip we need help
Jan 05, 2008 | Heating & Cooling
Wiring Diagram for Ruud Heat Pump
Unfortunately, the wiring diagrams for heat pumps are not so easy to come up with. The outdoor unit will have its own diagram, but may not include the indoor air handler and will probably not include the thermostat. That said, the orange wire is commonly run from the thermostat to the reversing valve in the outdoor unit. This wire is usually not connected to the indoor airhandler. The orange wire is usually used in a unit that has the reversing valve energized in cool. Ruud, however has its reversing valve energized in heat. Probably not useful but maybe helpful
Mike
Jan 04, 2008 | Heating & Cooling
Heating & Cooling Logo
89 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
