Question about RCA P52926 52" Rear Projection Television
Plastic screen needs to be cleaned. How do I remove?
Remove front speaker panel off should be 4, screws along the bottom of the screen.take them out and lift up on the screen
Posted on Oct 04, 2009
Remove tv screen from hitachi projection tv
The entire screen unit can be removed but first remove rear cover and look at the lens--clean with a lens cloth etc----peek up inside and look at the mirror--if not dirty or smudged just clean the lens.
removing the screen with its frame can be tricky--easy to damage the screens etc. Removal usually requires front speaker grill to be removed first---most just pull off but a few are secured from rear by some screws.
With it off look to see if at bottom of screen there are a row of screws--if the entire front unit can be removed it will pull out at bottom and be snapped in place.
A better suggestion is look at rear of set above back cover--if the upper part is plastic--it with the back removed can also be removed--careful as mirror is bolted into it---that way you can clean the mirror and get at the lens for the tubes without trying to remove screen unit--some of the smaller sets this is the ONLY way to get at the mirror.
Yes a number of screws but if plastic upper rear comes out with mirror much easier and safer way.
May 29, 2012 | Televison & Video
I have a Kenmore HE 3, model number 110.8787,8789. I cleaned the lint screen, unscrewed the plastic that holds the screen and cleaned all lint out. After doing so, my dryer won't start. The lig
when you removed the screen from the inside you disconnected the wires from the 2 metal strips. now you need to remove the lower panel on the front. and reconnect them. you will need a T-20 torx and unplug the dryer to be safe. the wire will have 90 degree push on connectors and it does not have any polarity concerns. the two male connectors are real close to the top of the panel, maybe even slightly under the other panel. By the upper right of the silver fan duct.
Jan 02, 2012 | Kenmore Dryers
A spider is on the inside of the screen. how do I open the tv open to get the spider out and clean the inside of screen and lenses?
go_n,
First gather your needed items: screwdriver and a helper.
The screen is mounted to the enclosure of the TV by hanging on tabs mounted on the enclosure inside behind the screen. The screen simply lifts off after removing it's set screws at the bottom of the screen behind the big plastic piece that is below the entire screen.
1) Remove the speaker covers (grills).
2) Locate and remove the screws that hold the plastic piece onto the enclosure (8-12).
3) Remove the plastic cover and you will see the set screws holding the screen.
4) Remove the screws (2-4).
5) Use your helper as your screen is really big for most average sized people and lift the screen including the plastic bezel up and away from the enclosure.
Ensure that you have a secure area to set the screen as it will be large, heavy but yet very delicate. Also, do not clean anything unless you know for sure that you need to as sometimes just by touching things they get misaligned or break. This means but is not limited to: mirror, lenses & the screen.
When reinstalling the screen ensure that you hang the screen back onto all of the tabs or the picture will be blurry.
Good Luck!
-Chris
Sep 06, 2010 | Hitachi 57G500 57" TV
Cob webs behind screen
The frame around the screen just pops off. Unscrew the plastic holders from the chassis frame and the screen will come off allowing you to clean everything inside easily. The "2" thin screens are easily cleaned and put back on easily also. Don't do what I did and think the screens go into the front slot of your plastic brace, they slide easily into the wider slot. You'll also be able to clean the dust from the reflector and guns with Windex. Much better picture after wards, trust me. You would be surprised how much dust may have accumulated on the lenses.
Jan 31, 2010 | Philips Magnavox 55P9271 55" Rear...
Bug between screen and plastic cover screen how do i clean
You will have to remove Front cover in order to clean, remove bottom part then you should see screws holding on screen remove and clean
Sep 21, 2009 | JVC HD56G887 56" HDTV
How do I take the front screen off to clean the bugs out? Philips 60PP9100D-37 60" Widescreen Projection TV
First: do not take front screen off for cleaning--easy way is to remove entire black plastic shroud (you look at back of set and you will see 2 silver pegs near top edge) This set uses torks type screws---you need to remove several and the entire upper plastic in back comes off. The mirror is suspended separate from this.With the shroud removed you can clean the lens of the 3 picture tubes or any debris on the inside of the screen----do not use glass cleaner on the screen; but if you have smudges or bugs on the inside just use a very fine soft cloth(you may need to moisten it slightly) Any mark you make will show! If you find you have spider webs use a swiffer type duster to remove them.
I do this here for free so if this was helpful give me a vote here. If you have questions or need help let me know.
Aug 03, 2009 | Philips 60PP9200D Television
It began with the stream of coffee slowing down, so I cleaned the urn with Brew Rite cleaner. I followed the directions, but when the process finished, it did not have a flow at all. The pot is...
I also had this problem, and reached the point where it was easier to pour the coffee out of the brew tank rather than going through the torturous hell of waiting for it to drip out of the spigot each morning. What I discovered was that the domed screen inside of the brew tank was plugged with residue. The screen can be removed and cleaned. You will see four plastic tabs holding the screen in place over the spigot. Gently and carefully pry the plastic edge of the screen nearest the wall of the tank with a small jewelers screwdriver or a sharp knife(steak knife worked). The screen will pop out and must be scraped (tip of a knife) and cleaned on the inside as well as the outside. The sceen goes back in the same way it came out by sliding the plastic edge back under the plastic tabs and push down the edge nearest the tank wall. It will snap into place. This was an easy 100% fix on my Hamilton Beach Brew Station.
Jul 29, 2009 | Hamilton Beach BrewStation 47224 Coffee...
I put a plastic screen protector on my blackberry 8310 and when trying to remove the screen protector because it was twisted,spots like water appeared between the lcd screen and the plastic cover of the...
When you put the plastic screen on make sure that the plastic and the screen on the phone are absolutely clean. If there is any dirt or debris on either the plastic screen will not sit directly on the phone and bubble up where there is residue.
Jun 04, 2009 | RIM BlackBerry Curve 8310 Smartphone
Can't clean the inside of the glass door--the screen blocks it
Have to replace the door. You probably removed the protective plastic cover inside the unit intended to keep material from passing through the screen into the area where the glass is located. That was my problem. I thought the plastic was shipping material. My Bad! No way to clean the glass from the inside because they "never imagined" someone would remove the plastic cover.
Nov 10, 2008 | GE XL1800 1100 Watts Microwave Oven
Screen
yes you can remove the screen by removing the front plastic trim and the removing the screws that hold the screen in. clean the screen and put it back together.the front plastic trim should just pop off
Aug 30, 2008 | Sony KP-51HW40 51" Rear Projection...
RCA P52926 52" Rear Projection Television Logo
93 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
