Question about Toshiba 30HF83 30" TV
My Toshiba 30HF83 TV has a good picture, but no sound? Help! I have checked the mute and volume functions and mute is off and sound is turned up. All of the sound menu functions seem to be set correctly.
Shuttle83
  • 1139 Answers
SOURCE: Tuning programmes on Toshiba 30HF83 30" TV Problem
Hello Skinno, Frist of all make sure that you are set to Antenna input and then connect your antenna to the TV this will pull in the VHF ansd UHF channels. Then perform the auto channel select. If this does not work perform a manual channel selection this should clear up your situation.
Posted on Sep 03, 2007
SOURCE: Toshiba 32A50
I have the same problem but can't find any adjustment. Thought it was the satillite dish but, no. Network channels come in good but the others are almost impossible to hear. It isn't worth taking to a repair shop - what a waste!
Posted on Mar 01, 2008
marked
  • 6487 Answers
SOURCE: Picture but no sound on a Toshiba Theaterwide HD tv
You can check the user manual for some troubleshooting tios about this problem and also try resetting the audio part of the TV its on page 42 of the user manual if resetting the audio still didn't fix the problem reset the entire unit you can also see the steps from the user manual http://www.tacp.toshiba.com/tacpassets-images/models/50hp16/docs/50hp16_om_e.pdf
Hope that helps.............
Posted on Sep 12, 2008
  • 346 Answers
SOURCE: Toshiba Regza 32C3000A tv sound
if you press the volume + on the tv and the volume- on the tv and the volume increase and decreases respectively then the remote control mute button is the problem
Posted on Nov 14, 2008
Stakanoff
  • 69 Answers
SOURCE: There is no more sound from my Toshiba laptop loudspeakers
Try to use different players like windows media player and winamp
and check if it is not muted by standart software or 3rd party
Posted on Mar 19, 2009
No sound
  • 1 Make sure that your audio cables are plugged in properly to the correct ports if your audio is distorted or noisy. Every cable should be inserted completely. If you still encounter bad audio, replace the cable and then attempt to use a different device with the old cable. This will help you pinpoint the source of the bad audio problem.
  • 2 Use the "Volume up" button on the remote or TV buttons panel to turn up the TV audio volume if the volume is quiet. If the volume is still quiet, check to see if your audio source device has volume settings. If it does, turn the up the volume on your device (see your device documentation if you need help with this).
  • 3 Press the "Mute" button on your remote control to disable the mute function if you can't hear any audio. Once disabled, press and hold the "Volume up" button on your remote control to turn up the volume. If there is still no audio, press the "Menu" button on your remote control, select the "Audio" menu, and ensure that the "TV Speakers" are set to "On." If you are still not having any luck and are using the built-in TV tuner, open "MTS Audio" inside the "Tuner" menu and make sure it is set to "Stereo/English." If there is still no audio, verify that all your audio cables (including the antenna cable if you are using one) are plugged securely into the proper ports on your TV and audio source device (if applicable). If you are using an antenna, reposition it to a clear, open area; preferably near a window. If your audio source device has audio settings, check to make sure they are set the way they should be (see device documentation).
  • Read more : http://www.ehow.com/how_7498064_troubleshoot-vizio-sound-problem.html
    Mar 08, 2014 | Vizio Televison & Video
    Sansui volume
    Check whether the 'mute' function is ON. If it is On, there will be no sound output, but picture will be OK.
    Jan 24, 2013 | Televison & Video
    I have a Sharp LC37D43U TV that has no audio. The volume indicator shows can be moved up or down but no sound comes through the speakers. The picture works fine. I have nothing else connected to the TV....
    It appears you ve discovered the sound task levers required to adjustment properties. Your Tv can still move levers even when the volume is set to mute. Select the unmute button before any voice or audio would be reactivated. Assuming that seting the TV on mute has predominant integrety over the volume functions where not unmuting usually with the same button on the remote would not achieve accessibility to the volume functions. refer to the TV user guide for diagnostic audios. Good luck
    Jan 09, 2011 | Sharp Televison & Video
    Hi. i vacuumed the back of my 9yr old toshiba tv to get rid of dust.when i put it on the volume does not work properly.i get some noise but not proper volume.plz help
    Hello
    During vacume back, some plug in connections may be got loose contacted, due to the suction power of the cleaner. You just open your tv, after unlug it from mains supply, and pull out and replug each plug ins, for two or three times. Again you feels the probelm is not resoved, inform me through Fixya. OK.
    Nov 19, 2010 | Toshiba 30HF83 30" TV
    Toshiba CN36X81 television.. NO Sound... Great Picture. Using the TV2 output of a DISH Network HD receiver... TV2 output is std def, coax output. Using a different TV I get picture and sound... but not...
    IF coming in via, the "Dish" networked receiver, please check that this volume is turned way up, on the TV. and then control the the Volume, with the Dish Remote, often this is a problem, as one is turned down, and the other cannot turn that up, simply try syncing the Volume controls, UP on TV, control the Audio with dish remote. thats all i can think of. Check by feeding a signal IN from an AV, source, ie: Yellow, Video, & Red& White, Audio. Turn TV UP and check, IF it responds to this all is well. If NOT then you do indeed have a fault, with the TV.
    Mar 27, 2010 | Toshiba CN36X81 TV
    No clear sound from speakers, even when volume is max out on toshiba model 30hf83 tv
    Use a audio signal tracer to pinpoint the distorted sound location,you can use an amplified pair of computer speakers.Or request the complete 9mb 126pages schematic diagram from my personal server at computec40@hotmail.com
    Nov 21, 2009 | Toshiba 30HF83 30" TV
    I have no sound
    go to menu settings and check audio on?
    Jul 10, 2009 | Televison & Video
    My volume sounds muted on my 36" toshiba tv, nothing is working
    Good day.
    Please check on the speakers of your unit. They may be busted.
    chris
    Mar 20, 2008 | Toshiba 36A40 36" TV
    No sound from 5 yr old Toshiba
    as picture is ok means 100% it is due to sound section. solution 1 check speaker &its connection or loose 2 check supply to sound section 3 check parts in sound section (resistance& capacitors). 4 check for audio ic if it is demaged.
    Sep 22, 2007 | Toshiba 32AF41 32" TV
    Sep 03, 2007 | Toshiba 30HF83 30" TV
    Toshiba 30HF83 30" TV Logo
    Top Toshiba Televison & Video Experts
    Jaime Hernandez
    Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
