Question about Pioneer VSX-D711 Receiver
Error 71 an the reciever shuts down - Pioneer VSX-D711 Receiver
Volume is erratic without touching the volume knob. sounds get louder and sometimes sound get little.
Posted on Jul 27, 2010
    President:
  • Pioneer Master
  • 1,114 Answers
You have a speaker short. Disconnect all speaker wires at the receiver, then turn it back on to test. If you don't get the error code, your receiver is still ok. Reconnect your speaker wires one by one and test the power on the receiver until you find the wire that's causing the problem. Then disconnect that wire at the speaker and test again, this will determine if you have a bad wire or a bad speaker. If the receiver still reads error without speakers attatched, you will need to send it for service. While it's at service, check all wires and speakers for shorts with a meter if you can. This is the most common failure of all receivers, a shorted wire. Hope this helps
Posted on Sep 26, 2009
Error 71
Error 71 indicates that the laser unit has failed and will need to be replaced. A trained technician will need to be called to repair this problem.
Jul 08, 2013 | Brother DCP-9045CDN Laser Printer
I have brother DCP 7055 it shows print unable 71 error pls suggest
I have brother DCP 7055 it shows print unable 72 & some time it show 71 error pls suggest
Dec 18, 2012 | Brother Dcp-7055 Laser Print Copy Scan...
Evet time i hook my 1200 watt power acoustik and turn it up it cuts off
Usally When something like this occurs its because the amp cant handle the reciever. Meaning the reciever is pushing out more than what the amp can handle. As a safty feature to save you from blowing your amp or speakers the amp will shut it self down to minimum as you described. This also occurs when the amp over heats or doesnt have enough ventalation and once again as a safty feature to save your amp it shuts down. My first suggestion is to turn the "Loud ON" mode off on your reciever. As this feature can blow your speakers and can also cause this problem. Also do not use any factory settings on your reciever. It is almost always the bass in any given system that causes this so turn the bass down some on your reciever or on your amp turn it down and then adjust up and down from the reciever. Im sure you probably like the bump bump bump, I do to but your going to have to eiather buy an amp that can handle what your reciever is pushing, or turn it down a bit. You should also check the fuses for not only your amp but for the system under the hood near the battery. My own personal experience I have blown fuses when the system shuts down. Hope this helps
Oct 24, 2011 | Car Audio & Video
Starview telewest codes 21/01/2010
Telewest last updated 12/10/09
00 CF 53 OC 33 79 61 71 85
01 52 5E 8D 45 FC 75 F6 4A
NO CHANGES YET.
Jan 21, 2010 | StarTech.com StarView SV211K 2-port KVM...
I recieved an error 71 and do not know what to do?
I took a close look into this or you. You ca not make this repair. It needs to go to a service center. It is a hardware defect. I wish I could help you with this, please come back if you need any other help.
Oct 23, 2009 | Brother MFC 9700 All-In-One Laser Printer
Canon error code 6500
The PCI bus error is detected by the ASIC. - Logic board problem
Oct 08, 2009 | Canon Office Equipment & Supplies
Brother 4100 fax error code # 71
Error 71 is a laser scanner error.
Inkworks
866-381-0541
Nov 19, 2008 | Brother IntelliFAX 4100 Laser Fax
Xbox 260 error 71
put it in a towel and shake it n a circle IT WRKS
Apr 17, 2008 | Microsoft Xbox 360 Console
Printer error
You have a power problem, plug the printer in somewhere else, the 3160 is a power hog and has blown many a breaker in my building!
Jan 29, 2008 | Samsung CLX 3160fn All-In-One Printer
Pioneer VSX-D711 Receiver Logo
128 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
