Question about Rv Motorhome Dual Co & Lp Gas Alarm Detector
When my 2008 Birdsville Winnebago is not being used, how often should I connect to mains power to keep my house battery charged.
    President:
  • 1,114 Answers
Ideally, if you have a 12v 1.5amp trickle charger, and access to an outlet, keep it plugged in. It will only charge when the battery is low and will not "overcharge" or cause an internal acid spot. you can purchase one at walmart for about $20. If you don't have access to power, you should do a maintanance charge every other month, depending on the 12v current draw of the vehicle when off. Hope this helps.
Posted on Sep 26, 2009
Where are the fuses located for the 2015 Itasca Sunstar 36Y?
Winnebago RV Sales ' Itasca RV Sales ' Winnebago ...
www.lichtsinn.com/new-rvs-for-sale.aspx
Location: Main ... The All New Fuel Efficient Fuse with the Ford Transit Power Stroke Diesel! .... New 2016 Itasca Solei 36G The Forza and Solei Offer Diesel Pusher ... New 2016 Itasca Sunstar LX 27N All New Upgrades to the Vista and Sunstar with ... 2016 Brave Returns with Its New Crown as the 2015 RV of the Year Title!
Sunstar ' Specifications ' Winnebago RVs
winnebagoind.com/...a.../2015/sunstar/specificatio...
Winnebago IndustriesSunstar ... Length, 27'1", 31'3", 28'3", 31', 36'5", 35'5", 37'. Exterior Height1, 12'2", 12'2", 12'2", 12'2" ..... 2015 Winnebago Industries, Inc. All Rights Reserved.
Winnebago Industrieswinnebagoind.com/resources/manuals/Winnebago IndustriesIf you are not in a position to visit your dealer, some parts are available online at www.WinnebagoOutdoor.com. Please note that you can look up part information ...Winnebago RV Sales ' Itasca RV Sales ' Winnebago ...
Jan 01, 2016 | Itasca 2015 Sunstar 36Y
2006 DODGE WINNEBAGO VIEW WON'T CHARGE BATTERIES OFF ENGINE ONLY CHARGE WHEN PLUGED INTO SHORE POWER
perhaps that is so the truck will not have dead batteries when needed to start the truck.
Mar 05, 2015 | Dodge Cars & Trucks
My 2008 Prius is not charging the battery when the
hook a voltmeter at iddle should be at least 13.5 v if the condition of your belt is ok tension wise and the idle about 800 rpm replace the alternator your voltage regulator went bad
Oct 18, 2014 | 2008 Pontiac Grand Prix
Not getting power to the engine fuse box on a 1988 chevy winnebago
Could be a second bank of batteries, One set for the chassis and the other set for the house.
May 02, 2014 | RVs
I just bought a 1989 minnie winnie Winnebago with Chevy chassis, there was no generator all wires leading to generator were disconnected. There is no power to the rear cab unless the engine is running. The...
The wires that were hooked to the Generator were also hooked to the aux batteries. you'll have to trace the wires that are disconnected. Also, if you plan on just using your alternator to keep the aux batteries charged, then you need to make sure you have at least a 100 amp alt, If you use the batteries while the van isnt running it takes a big toll on the regular 60amp alt that most of these vans come with. I'd buy another generator and hoo it back in myself.
Oct 29, 2013 | Cars & Trucks
My c610 battery i have replaced it 2 times but it still dolesnt charges it stops it stops to charge during charging
Hi nabhanizatio
DELL LATITUDE C610 BATTERY CHARGE FAILURE
The likely cause of the original battery fault is a very common mistake in the way laptops are used. A laptop battery, working at optimum efficiency, whether of the older Nickel Cadmium and Nickel Metal Hydride or newer Lithium Ion types, is meant to charge under power and then discharge under use, if it is to have a long and useful life. This means that it should be used in a similar way to a cellphone's battery - connected to mains electricity and charged up when low or flat and then disconnected from the power and used on battery power alone until the power level means the cycle needs repeating. Many people, however, unwittingly use their laptops like desktop PCs and leave the mains electricity permanently connected to it even after the battery is fully charged. The reason that people cite for doing this is 'convenience'. This, however, is a mistake.
Laptops have more flexibility than cellphones in that, if they are mainly used in one place rather than as mobile devices, then it is possible to charge the battery to full capacity, disconnect from the mains, then remove and keep the battery until the next time the laptop's mobility function is required (periodically recharge the stored battery if not in use for long periods of time because the charge slowly dissipates when not in use), reconnect the mains to the battery-less laptop and use it like that, ad infinitum.
When a laptop battery is fully charged, what it really wants to do is discharge. However, maintaining the mains connection prevents it from doing so. The Power Management
System on the motherboard is designed to cope with long periods of either battery powered or battery-less mains powered use, but not long periods of simultaneous battery + mains powered use. A fully charged battery still connected to mains electricity has no means of discharging and various power sensitive components such as the Power Inverter, Cold Cathode Backlight, LCD Panel, Graphics Chip and Motherboard Power Management Stystem can become damaged by the power bottleneck created.
Using the battery in this wrong way also gradually depletes the charging capacity of the cells, until eventually, the cells can carry no charge, meaning a dead battery. A dead battery, where the cells are depleted, left in the laptop with the mains connected, is even worse for the Power Managent System
because the flow of power to the motherboard via the dead battery cells is inefficient and intermittent, creating battery overheating, low CPU Cooling Fan speed, inferior cooling and consequent internal overheating hazards in addition to potential electrical damage to several components. When damage to the Motherboard Power Management System passes a certain point, even a new battery might not charge - the situation in which you now find yourself.
Loose DC jacks, leading to intermittent power drops and surges, are typically caused by the jack being allowed to take the weight of the heavy transformer box on the laptop's power cable. The solution is to ensure that the laptop is never held, carried or used with the transformer hanging unsupported. If the laptop is in use, the transformer should be disconnected, carried, placed on a desk or table near the laptop (if the cord is short) or laid completely full-weight-flat on the floor (if the cord is long enough). Also, a Surge Suppressor/Surge Protector should always be used between the mains power socket and all computer
equipment, rather than directly to the mains.
If either the Motherboard Power Management System or DC Jack are ever damaged, your laptop would require professional specialist repair by a Component Level Laptop Repair Specialist, providing No Fix No Fee, Warrantied Repairs ( typically 3-6 months Repair Warranty).
I hope this helps.
If this answer does help you, please take the time to rate it. This helps answerers better understand the needs and the point of view of the asker and guides us in exploring the best ways to provide useful, high quality answers. If you need further help, please feel free to post another question or add a comment to this question.
Thanks for using FixYa.
Oct 07, 2011 | Dell Latitude C610 Notebook
Should i use my new acer 5760 on mains power when possible
It depends upon how much time you run your laptop on battery power, you can keep an eye on the battery charge level when you connect it to mains power. You do not need to keep it on mains power all the time, only when the battery level drops to a low level and needs charging.
The laptop will warn you when it is low on battery power.
Aug 29, 2011 | Acer Travel Mate 7720G-932G50MN Notebook
76 Winnebago brave, not charging the batteries, even with generator on.The main battery to run the motor is not charging either. We hooked up the generator and everything works fine, but as soon as we shut...
Your power converter is probably okay, since the lights are getting bright when generator runs (and probably when plugged into shore power). A coach that is as experienced as yours is probably going to have multiple wiring issues that have occurred over time. Corrosion on battery terminals is common, but so is not maintaining the batteries. Batteries are usually killed by not charging properly, discharging too deep, and not keeping them clean. The batteries can also be wore out, especially if they are more than a couple years old and spent a lot of time sitting in the back lot.
Start by looking at the cables located at the battery, as well as at the battery connection on the DC fuse block. Everything should be clean bright and shiny. If not, I would suggest loading a dremel tool with a brass brush, and clean all wires and connections individually. Make sure everything is turned off in the coach to minimize sparks. While you have the cables off, take a look at the date codes and check the water levels. Correct accordingly.
There is a possible problem that can be at the converter as well. When you supply power to the converter, a solenoid engages a switch that transfers power to the batteries, charging them. If this switch has failed, it will cause same symptoms since batteries are not being charged.
The chassis / starting battery may not be charged by the house charger at all, especially if there is a Emergency Start / E-Start / Boost button on the dash somewhere. The engine is able to charge the chassis battery and the house batteries through a big relay (looks like ford starter solenoid on coaches like yours).
If you drive down the road, and main battery doesn't charge, and house batteries don't charge, Look closely underneath your coach for a grounding problem as well as possible bad alternator. But, if your house batteries charge off the alternator, then your problem will likely lie in the switch on voltage converter. If chassis battery charges and house batteries don't, look for 30 amp fuse between house battery and relay on firewall of engine compartment.
Make sure you wear old clothing, wear eye protection, and gloves when around batteries, and also when using the dremel.
Jul 04, 2009 | Rv Motorhome Dual Co & Lp Gas Alarm...
Laptop compaq presario f500,running vista.Wireless is not working,Windows cannot load the drivers required for this device. (Code 31)
Matt Sydney Aug 4, 2008 00:28:44 GMT 10 pts
I experienced this problem last night, and seemed to have fixed it this morning.
SYMPTOMS: HP Pavilion dv9000, Win Vista x64 Ultimate. Running on battery, battery level became critical; windows went into 'Hibernate' mode. Upon plugging in to mains power, and resuming the Windows session, the Wireless is still disabled, no matter what position the switch is in.
POSSIBLE CAUSE: Critical battery switches off the wireless network card to preserve power. Motherboard seems to log this status but when re-connecting to mains power the card does not receive power again. Uninstalling the driver and getting Windows to re-install automatically upon re-boot does not work.
SOLUTION: Charge up the battery whilst the computer is running. You can charge it to a substantial level, say, above 25%. Disconnect mains power so that your laptop is running on battery only. Set your wireless switch to OFF (this is usually to the left position, away from the orange indicator). Now run your computer down to the critical battery level again (perhaps overnight). In the morning when you press the power button, the 'CHARGE' indicator (looks like a lightning bolt) on the front of the laptop should flash quickly, indicating that there is no charge in the battery. Remove the battery from the laptop's underside. Wait a couple of seconds, then press and hold the power button for 30 seconds. Keeping the battery off the laptop, reconnect mains power. Boot up your PC. When at the Windows desktop and all your startup programs have finished loading, switch your wireless on (to the right position). You should now have a blue light, and wireless should once again be working. You can now re-insert your battery. You might have to setup your wireless network connection again as mine seemed to be 'lost', but at least hopefully the main problem is now fixed.
Jamie Madriz Aug 8, 2008 01:58:15 GMT N/A: Question Author
Matt, i did what u said, and i'm happy because my wireless switch is WORKING! :) Hopefully it stays this way.
Sep 23, 2008 | Computers & Internet
Rv Motorhome  Dual Co & Lp Gas Alarm Detector Logo
98 people viewed this question
Top Camper Vehicle Parts & Accessories Experts
Jim Goldsmith
Jim Goldsmith
Mike
Are you a Camper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
