Question about GE Refrigerators
Our GE GSS25JFMBWW refrigerator is not keeping cold on the refrigerator side, but is keeping pretty cold on the freezer side? Any idea on what is happening?
  • Mike Smith
    Mike Smith May 11, 2010
    Need more information to help you ....Is there frost build up on the inside freezer rear wall (?)...Open the freezer door and press the light switch in ..Do you hear the freezer fan working (?)...Remove the panel from the back of the refrig ..Is the fan which cools the comressor and the coils working (?) ...Is the compressor running (?). Reply back with the answers to these questions , and either myself or another expert will be glad to help .
  • GE Master
  • 4,655 Answers
Sound like your refrigerator is experiencing a defrost problem. Mot times this involves the defrost heater part number WR51X10055 Look into the back wall of the freezer compartment and if frost is beginning to stick to the back wall unplug the refrigerator and remove the rear panel in the rear of freezer. Defrost with a hair dryer until you can see the defrost heater below the evaporator coils. If burned out it will be easy to spot because the defrost element is inside a glass tube. The defrost thermostat could also cause this problem if defective. If you replace the defrost heater I also recommend that you replace the defrost thermostat part number WR50X10054 There is no defrost timer on your model. Defrost is controlled by the mother board, Let me know what you find, Thanks, Sea Breeze
Posted on Sep 26, 2009
My side by side refrigerator and freezer is not keeping cooling temperatures. Freezer had frost in ice dispenser, then began dripping water-had a few ice-sicles and then noticed food defrosting and...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
uiot45
Apr 16, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Started leaking water out the freezer door and ice was melting last nite... bad timing we just got a snow storm here in NC last nite. Seems to be running but food is defrosting. Its a GE Side by Side about...
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} . Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Is the evaporator fan in the freezer running. It blows cold air into the fridge side through a damper in the wall between the freezer and fridge. Make sure the damper is open.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
Jan 30, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
GE side by side and it is not keeping the refrigerator cold
You have a fan not working. The fan moves cold air from the freezer side to the refg. side. eather the fan is bad or the T-stat. You will have to pull down your controls and ck wiring with a Volt meter.
Aug 04, 2009 | Refrigerators
Freezer side working reefer side warm ge side by
There is a vent that gets clogged. The easiest way to fix it is to let it thaw for 24 hours (open-48 would be better). This is much ceaper that calling for a tech. Cold air from the freeezer is what keeps the fridge side cold.
Jun 11, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Side by Side GSS22JERFWW not keeping cold
often there is a cover in the rear of the freezer with some screws remove these and put low temp grease on the fan. The Problem Is %100 The Fan So If You Look Up Your Fridge On Google It Will Tell You Where The Fan Is.
Jan 04, 2009 | GE GSS22JER Side by Side Refrigerator
Ge side by side not cold enough in fridge or freezer
if there is no frost build up in freezer section sounds like a refrigerant leak
Apr 14, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Ge refrigerator
This happened to me with my side by side. The repair man came to my house, said that GE have cheap refrigerators because they are not meant to last very long. The mother board that controlled the temperature went out. A component in my freezer would get frosted up, but the heater would not kick in to reduce the freezing. Everything starts to warm up in the refrigerator as a result. A new motherboard would get the refrigerator back in timing.
Aug 02, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
645 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
