Question about McCulloch Garden
Need location of holes in gas tank for carb and priming bulb
  • 1 more comment
  • w_bonham Sep 26, 2009
    Serial number: 11-074362
    Model number; 600032-69
    American, as far as I can tell. It is a 3200 series.
    Thanks for any help.
    Serial Number: 074362
    Model Number: 600032-69
    American as far as I can tell, 3200 series.
    The machine is about 10 years old but has only been used about 5 hours at most.
    Sorry for the delay in replying and thanks in advance,
  • dontbother10
    dontbother10 May 11, 2010
    There are over 100 different McCulloch chainsaws. can you verify the make and provide the model number, and serial number from the manufacturer?s tag. Is it American or European, and the approximate age. Please include these in a clarification (below).
    President:
  • 2,220 Answers
  • dontbother10
    dontbother10 Sep 28, 2009
    The 600032-69 was key to this one, Thanks for supplying the numbers. Atta boy/girl
  • 546 Answers
The hoses pass from the carb. chamber into the tank at the seam of the housing halves towards the front [tank] side.removing carb helps.
Posted on Sep 26, 2009
Priming echo BP251 liaf blower
Hi Norman:
I'd check the routing of the fuel lines.
Tank to carb (this is the line with the filter on it)
carb to bulb (suction side)
bulb to tank (return line)
If the connections appear correct but it does not pull gas, check the filter to make sure it is clean, and you can try reversing the connections on the bulb.
Hope this helps.
Mar 11, 2016 | Echo Garden
Replace fuel lines bubble will not prime carb. which line receives the filter?
This is an ongoing issue for users, and rightfully so. Small diameter line out of fuel tank (has filter in-tank on end) connects to the side of the carburetor that has the fuel pump....that is the cover without the hole in it. Other larger diameter fuel line out of tank connects to the longer nipple on the external purge/primer bulb. The bulb "pulls" fresh fuel from the fuel tank to the carb and then out of the carb to itself, where it then pushes any air/old fuel back into the fuel tank. The remaining larger diameter fuel line in this setup goes from the metering chamber (has cover with writing on it and a vent-hole) side of the carburetor to the smaller nipple on the purge/primer bulb. Years ago on 2-stroke trimmers, primers were not even used,...you choked the carb with a slide lever and gravity let fuel enter the carb from above...a few pulls, a "pop"...slide it off of choke and away you went.
If the purge/primer bulb is on top of the carb...small line from carb body to small hole in tank with filter. Larger diameter line goes from the bulb on the fuel pump side of the carb to the larger hole in the fuel tank where the line is held in place with a nylon nipple connector that keeps the line from pulling out of the tank
Aug 22, 2010 | Craftsman 25cc Gas Line Trimmer
Getting my new fuel lines in correctly from gas tank to priming bulb & from gas tank to carb.
on weedeaters,chain saws. most are the same.
line with little filter in gas tank goes to carb. line out of carb to primer bulb
line from primer bulb to gas tank
Jun 24, 2010 | Garden
No gas when you prime it
1) Check fuel lines from tank for cracks, fuel filter in tank, primer bulb for cracks
2)Remove Carburetor
replace gaskets/diaphragms
a) use a spray carb cleaner to clean jets, holes, and body of carb
b) fuel pump diaphragm goes against the carb body,
then the gasket towards the outside
c) metering gasket goes against the carb body,
and the diaphragm goes towards the outside
Nov 13, 2009 | Craftsman Garden
Have 2 gasoline inputs to my walbro carbrator. The one on the bottom closest to the diaphram side leads to the prime botton. The one on the otherside leads directly to the gas tank. When the prime button...
Sounds like you have the lines connected incorrectly. Make sure that the bottom of the carb is connected to the inlet side of the primer (take the lines off and with one of the ports covered with your finger push the bulb, if it collapses and doesn't return then that's the suction/inlet of the bulb). The other side of the bulb needs to be connected to the gas tank. The other side of the carb needs to go to the filter side of the gas tank.
Nov 03, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Fuel lines rotted, unsure of routing new ones
Bottom of the tank one is an overflow, 2 in the top are connected to the bulb
. The bulb pumps gas from the gas tank to the bowl of the carb then back to the fueltank in a loop to prime things up, prime too much and the overflow comes out the bottom tube.
Sep 23, 2009 | McCulloch 26cc Gas Blower Mcb3208
Poulan chainsaw gas line routing?
There ARE two holes in the tank. One samll and another larger. One is on the left side and the other is on the right. Look carefully and you'll find them. As far as connections of the fuel lines:
The line from the fuel filter in the tank goes directly through the small hole in the tank to the top nipple on the carb thus giving the carb a constant supply of fuel when running. The primer bulb is used only for "priming" and does not play a part in the fuel flow after that function. The bottom nipple on then carb then goes back to the nipple on the primer bulb which is clearly marked "Carb". The above connections are made with the smaller diameter tubing. From the primer bulb, marked "Tank", the larger diameter tubing is routed to the large hole in the tank. The tubing goes into the tank only 1/2 to 3/4 inch. As far as getting the tubing through the holes in the tank, cutting the tubing at a slant. But no matter what you do it is still a witch. Be patient, use some Vaseline and avoid the temptation to get out the drill and **** the hole to a larger size.
Aug 30, 2009 | Garden
Primer bulb on weedeater won't prime
when you prime the bulb it sucks gas from the tank with the small tube, any excess gassed pumped will be fed back to the carb via the big tube leading to the tank. If you prime it and the bulb stays pushed down, then you have a clog or kink. To fix , pull the small tube out of the tank through the fill hole. Pull off the filter on the end and put the tube back in the tank. If it primes, your fuel filter was clogged. If it still wont prime check the hose going to the carb and make sure isnt clogged or kinked.(take of carb and blow in it). If that doesnt fix it take off the bulb from the carb with two screws. The bulb assembly will come off too(rectange metal thing) Take off the two black gaskets, be carefull with them. Take off hoses from carb and bulb asembly. Blow carb cleaner in all holes and over surface. Put back together.
If the carb wont prime and the bulb isnt staying depressed. then you might have a bad bulb or carb gaskets. Make sure hoses are not cracked, cloged, or pinched.
Jun 17, 2009 | Troy Bilt Tb70ss Gas Trimmer
Ryobi Cultivator 410r
The linefrom the tank with the filter goes to the mixture inlet on carb. The fuel return goes to the suction side of bulb. The bulb outlet line goes to the tank. Hopes this helps
Mar 19, 2009 | Ryobi Factory Reconditioned 18" 40cc...
Garden Logo
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
