Question about HP Pavilion dv6174cl (RG362UA#ABA) PC Notebook
My Hp DV6174CL laptop makes a fan grinding noise near the power button. this happened after a repair from Micromedics
  • 788 Answers
The DV6000 units have a cooling fan located on the bottom of the case top left side.
If you hear a grinding noise, please do not use the unit.
Bring it back for repair. The blower is on-top of the CPU and if it does not recv. the correct cooling, it will take out the processor.
Posted on Sep 26, 2009
Power lost and grinding sound on 2000 isuzi rodeo v6 need a help
2000 rodeo 3.2L v6?
on all machines on earth, find and fix abnormal sounds first
and grinding tops my list.
power loss is 2nd. to that. as it will be zero power soon.
  1. get car serviced?
  2. DIY , you have tools?
DIY, get a $5 stethoscope an learn to find sources of noise.
posting here is impossible, we cant hear it and do those checks.
use that tool all over engine, to find what parts is making noise.
do not get near fan, if you dont understand that.the stop
and get skilled service.
if the noise can HAPPEN parked, that makes it 10x more easy
does it, parked in park or neutral , gunning throttle?
Feb 13, 2015 | 2000 Isuzu Rodeo
HP pavilion HP Pavilion 15-p087sa laptop is not powering on and making ticking noise.
Hello
It's might be the fan that's making the noise or can be something worse then that, I would recommend ask them for repair if it is still under warranty.
Dec 03, 2014 | HP Pavilion Computers & Internet
Problem with my Acer 5740
sounds like you need to replace battery,,its sounds like the fan is making the noise clean the fan.
did your laptop get wet at anytime?if so that would stop keys working.
check to make sure all drivers are in and turnd on.
and check to make sure all programs are upto date.
May 30, 2014 | Acer Aspire 5740-6025 Notebook
Random Short Grinding/Buzzing Noise from my Notebook gets amplified through PA system!!! Don't know where it is coming from or when it will happen next!!!
try and blow out the laptop with compressed air as it could be your fan making noise, make sure to leave the laptop on a flat surface, and don't press too ******* the palm rest. i say this because i have a dell 1545 and the hard drive is located on the left side under the palm rest and if i apply too much pressure i hear a slight grinding noise. let me know if this helps and please tell me if you're near the machine when it does this grinding sound.
Jan 31, 2012 | Computers & Internet
HP Laptop Fan Grinding
Take it to qualified system engineer for repair
Dec 25, 2011 | HP Computers & Internet
I have an HP dv9500 Intel laptop. The fan is making some pretty bad noises. I took the laptop apart according to the HP Maintenance Guide. I found tons of animal hair (I have two cats and a dog) and...
If there is nothing hitting the fan blades and the fan makes a grinding noise then the fan bearing is faulty. You may be able to place a drop of oil on the bearing under the label in the center of the fan and if this does not work then you need to replace the fan.
Apr 23, 2011 | Computers & Internet
When i power up the printer it make a loud noise. It appears to come from lower area below the cartridge. it makes the noise even if the cartridge isn't in
If this is a grinding noise it will be the gear assembly near the fuser on the printer. You would need a printer repair person to fix this for you.
Mar 08, 2011 | HP LaserJet 3320 All-In-One Printer
Grinding fan noise HP dv6 1130TX
First, if you just purchased the unit, you should have the problem fixed by HP under warranty.
HP offers a extended 1 year from the date of purchase. Thats 2 years on startup problems.
You are correct on the noise comming from the fan.
This will not go away and may get worse.
If the fan slows down or stops when needed, the CPU will go for a walk.
Email HP customer care and log your problem.
Make sure you have reg. your unit first.
Sep 16, 2009 | HP Pavilion dv6000z Notebook
HP Pavilion DV6500 - The fan makes too much noise!
If at all possible " do not try and clean the fan yourself " you will kill the m/board - take it to an auth Hp serice agent and get a new CPU heatsink assy & fan unit fitted. I work on Hp units all the time and I am always very carefull of the electrostatic conditions. Try and do it yourself and it will prove expensive. If you have warranty log a service call for a replacement heatsink
Glenn
May 09, 2009 | HP Pavilion DV6500T Notebook
Hp laptop dv9500 noisy and loud fan ...
The sound you are hearing is probably the fan, This fan has a noisy bearing and will eventually lock up and the fan will stop spinning and therefore the CPU will overheat and shutdown.
The fan needs to be replaced.
Feb 13, 2009 | HP Pavillion ZV6000 Athlon 64 3500+ 15.4in...
HP Pavilion  dv6174cl (RG362UA#ABA) PC Notebook Logo
297 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
