Question about GE Microwave Ovens
We have a GE microwave model JVM1430 that gives an error code of F3 which is keypad. My questionis can it be cleaned versus replacing it. Thank you
  • GE Master
  • 9,086 Answers
F3 on a GE / Hotpoint microwave means you have a shorted membrane keypad.
So until it is repaired, please leave it unplugged or leave the door open.
On these models, the membrane keypad is not available as a separate part, so you would have to order the control panel frame assembly which comes with a new keypad.
It is usually called the "Control panel asm" in the parts list (ref # 105 on the exploded view) .
You simply move your circuit board into the new frame. That is a simple do-it-yourself job.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then you unplug the keypad (as per the photo below) and move the circuit board into your frame.
Some connectors on the relays may have a lock:
Posted on Sep 28, 2009
GE JES2150MRSA  f3 code microwave turns on by itself,beeps out of control starts cooking by itself f3 is a control panel error
- "F3" means you have a shorting membrane keypad.
- Looking at the parts list for model JES2150MRSA, only the glass turntable and turntable support are listed, so it appears this is one of those unsupported "doorbuster" models.
- If it's still in warranty, it can be exchanged. If not, it should be disposed of.
Mar 15, 2017 | GE Microwave Ovens
Tip
Troubleshooting KitchenAid oven, range and microwave error codes
Here list of Kitchen Aid range and oven codes.
4 Digit Failure Codes
F1 - E0 EEPROM communication error
F1 - E1 EEPROM checksum error
F1 - E2 UL A/D error
F1 - E4 Model ID error
F1 - E5 Calibration shifted
F1 - E6 Latch signal mismatch error
F1 - E9 Stack overflow
F1 - E3 Wiring harness cavity size does not match stored value
F2 - E0 Shorted touch pad
F2 - E1 Keypad cable connection error
F2 - E5 Cancel key drive line open
F2 - E6 Cancel key drive line open
F3 - E0 Oven temperature sensor (RTD) opened (upper oven on double oven models)
F3 - E1 Oven temperature sensor (RTD) shorted (upper oven on double oven models)
F3 - E2 Oven temperature is too high (Cook mode)
F3 - E3 Oven temperature is too high (Clean mode)
F3 - E4 Oven temperature sensor (RTD) opened (lower oven on double oven models)
F3 - E5 Oven temperature sensor (RTD) shorted (lower oven on double oven models)
F3 - E6 Drawer sensor open
F3 - E7 Warming drawer sensor shorted
F4 - E1 Meat probe malfunction - shorted
F5 - E0 Door Switch
F5 - E1 Self clean latch will not lock
F5 - E2 Latch during CLEAN error
F5 - E5 Self clean temperature not reached within 45 minutes.
F5 - E6 Door is open, but latch is locked
F5 - E7 Self clean latch will not unlock
F6 - E0 Return line not connected
F7 - E1 Common switch wire defective
Two digit codes:
F0 ERC Board failure
F1 ERC Board failure
F2 Oven temperature is too high
F3 Oven temperature sensor open
F4 Oven temperature sensor shorted
F5 ERC Board failure
F7 Function key stuck on ERC
F8 ERC Board failure
F9 Oven door lock failure
Microwave and Microwave combo error codes:
F1 - E3 or F1 - E4 Electronic control malfunction
F2 - E0 or F2 - E1 Keypad connection error
F2 - E3 Keypad held down too long, or keypad is shorted.
If you get an error code, try first resetting the code:
1. Disconnect power for about two minutes.
2. Connect back power.
3. If code re-appears, test and eventually replace faulty part.
Regards.
on Mar 27, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
We are getting an F3 message on GE JVM1750DM microwave. After turning off power and then back on. It works for a few minutes, but then the F3 message come back ?
Hi
F3 error in your GE microwave means that the keypad/touchpad is bad and should be replaced. However, before replacing it you can follow these step by step instructions to clean the touchpad assembly and see if it works:
1) Unplug microwave
2) Remove two small screws from upper face plate
3) Remove screw on upper side of control panel
4) Life panel and pull out
5) Identify flat tape-like harness connecting circuit card to keypad
6) Wipe down harness with an all-purpose wipe
7) Use hairdryer to dry remaining leftover moisture
8) After this put the keypad back if its not solved then replace it.
Hope this helps...please post back for further assistance.
Daniel
Sep 05, 2011 | GE Microwave Ovens
F3 code
An F3 error code indicates that the keypad for the control panel is bad or has a short. This will cause the microwave to beep continuously after the set clock message appears.
On many models of microwave oven means a problem with the touch panel, (tact switches).
Replace the switch panel to fix the fault.
Hope this helps.
Aug 10, 2011 | General Electric Microwave Oven
Out of no where I get and F3 error messaGE AND A BEEP BEEP BEEP the model # is JES1036WF001
Hi
1) Unplug microwave
Daniel
Aug 06, 2011 | GE Microwave Ovens
My GE microwave is beeping and the display says F3
We would need your model number to give you more specific info, part ordering info, and en estimate if needed.
Simply contact me here with your model number and symptoms for free help.
On some models, the membrane keypad is peeled off and a new one stuck on.
In other models, the plastic frame must be replaced, and it comes with a keypad already installed.
May 12, 2011 | General Electric Microwave Oven
WHAT DOES THE CODE ---F3--- MEAN ON THE SCREEN FOR A GE PROFILE MICROWAVE MODEL # JVM3660?
Hello :
F-3 error is an error code for a bad keypad . If you couldn't find the spare parts , then it will be cheaper to replace the microwave.
good luck .
please rate !
Mar 29, 2010 | GE JVM3660 Microwave Oven
Have a GE model JVM1430 that has error code of F-3
Sep 25, 2009 | GE Microwave Ovens
Ge microwave jvm 1430 error code F3
F3 Key panel (touch pad) shorted This code will occur if a shorted key panel is detected continuously over 60 seconds. Replace key panel (also called touch pad).
Jul 17, 2009 | GE JVM1430 Microwave Oven
Open Questions:
GE Microwave JVM1441BH04: Safe to reconnect replacement stirrer & turntable motors after accidentally burning out the turntable motor? GE JVM1441BH04 Over Stove Microwave: Tapping noise was coming from the 21v AC stirrer motor which sits atop the cooking chamber. I disconnected the two connecting leads, unfastened the single screw holding it on, placed in on my scanner glass to get a high rez photo of all the specifics listed on the motor label. Bad news: While waiting for the scan to finish, I warmed my coffee in the microwave on the highest heat for 30 seconds. I subsequently discovered the 21v AC turntable motor, which had been working just fine, was now no longer working, with infinite resistance across its terminals, and a burnt electrical smell. Both the stirrer and turntable motors are powered by a 24v tap off the magnetron fan. My theory: By running the microwave with the stirrer motor out of the circuit, I delivered excessive voltage to the turntable motor, which quickly fried. The 24v tap off the magnetron fan motor currently shows the correct 24v output. However, with both the stirrer motor and turntable motor disconnected, running the microwave for a few seconds shows approx 95v across the wire leads for both of the 21v motors. I have obtained replacement motors for both the noisy stirrer motor and the fried turntable motor. My question: Can I simply reconnect both motors in their proper locations, vow never again to run one without the other connected, and all will be well? Or will the newly installed motors simply be fried in a matter of seconds?
Jan 04, 2018 | GE Microwave Ovens
Microwave Ovens Logo
277 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
