Question about Car Audio & Video
Im running a jl 500/1 and a 300/4 with a 2 gauge power wire quiet a few people have told me i dont need to use my capacitor . does anyone have any advice on power caps ? ive heard they dont work an they do please anyone with any thoughts please help i need it thanks
  • 436 Answers
A cap is always a good idea. it helps with power requirements that is needed from amplifiers when it is needed. The higher the rating the better holding of power. They work best right by the amplifiers.
Posted on Sep 26, 2009
JL Audio 750/1 installation help
upgrade all 12v wires running to your system to 0 gauge to kill you wiring to small problem when dealing with systems bigger is better double check to see if you alternator is putting out enough power for everything just because it say it will doesn't mean it does upgrade your capacitor seems to be falling you because there made to store power when needed and also get your battery check for any defects and add and extra just for your system
Jul 31, 2012 | Car Audio & Video
Can you run a 8 gauge power wire to a jl audio 1000/1 amp and not have problems even though jl reccommends 4 gauge power wire?
Hi, if you're going to run a smaller wire, you also need to use a smaller fuse. A 50 amp fuse is needed for 8 gage wire. The fuse is there to keep the wire insulation from melting, which is what will happen if you run too much power thru the wire. If you don't plan to turn the amp up too high, this may work fine, but I would test it first with a 50 amp fuse before installing. You will need all of the speakers hooked up and the gain set to max to test the power draw. See the following link on wire sizing for more info: http://www.bcae1.com/wire.htm
Mar 14, 2011 | Jl Audio 1000/1 Car Audio Amplifier
What number of cable should use on rockford fosgate 1 farad capacitor thanks
If good brand name wire, jl rockford monster kicker, the 8 gauge wire will be fine. if buying it at walmart or somewhere, then use 4 gauage wire
Jul 19, 2010 | Rockford Fosgate 1 Farad Capacitor Cpc10...
I have a jl 500/1 pops fuses some times could it be im pulling too much power from the battery because i dont have a cap or extra battery im running at 2ohm with a 15 inch kicker l5
Seems like the KICKER is pulling to much power try to knock it back up to 4ohm and see what happens. If its fine that way then you might need a bigger amp.
Apr 29, 2010 | Jl Audio 500/1 Car Audio Amplifier
Jl audio 1000/1 low voltage -keeps shutting off at high volume
You should definitely upgrade the power wire to the sub amp to 4 gauge -absolutely your choking your amp its starving for current-poor thing is starving !!!!!!!
Apr 16, 2009 | Jl Audio 1000/1 Car Audio Amplifier
I enhance volume car light shimmer and amp off.
Need more info. Are you sying that your lights pulse to the bass? Capacitors help. I would recomend at LEAST a 2 farad. Make sure you are using GOOD QUALITY 4 gauge power wire. So many "kits" say 4 gauge, but strip it back and you have a glorified 8 guage wire. I've seenit. Also, MAKE SURE that it is ran to the bayttery and use the SAME gauge for the ground (no more that 4 feet if possible).
In case your next question is "how do I hook up a Cap?", here it goes:
Power AND ground to the cap, then power AND ground from cap to the amp input. So very easy!!
Take care,
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Jan 27, 2009 | Jl Audio 1000/1 Car Audio Amplifier
Have a jl 500.1 amp
for that amp u need a compasitor to mantain the amps the amp draws the amp is being choked when the car is off and when its running its killing the cars charging system
Jun 25, 2008 | Jl Audio E1200 Car Audio Amplifier
Added another amp to system now subs dont hit as hard
This sounds odd, but try putting your subs out of phase from the mains. Just see if it changes anything.
Feb 16, 2008 | Jl Audio 250/1 Car Audio Amplifier
Blowing fuses
You will need to have the amp bench tested at full load to see if there is a pending problem. It will need to see with speaker loading resistors, how much current the amp is drawing and at different frequencies. if the amp checks out with the proper current, at the rated output, have the speaker checked out. Good Luck
Jun 15, 2007 | Jl Audio 500/1 Car Audio Amplifier
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
