Question about Motorola Mobility RAZR V3
How can i unlock my phone with out a sim card?
I have a samsung galaxy and a sim card that reads TF64SIMT5 V2 **********165746720 but the card will not fit into the sim card slot. Does this sim card not go to this phone?
I want to unlock my TracFone simcard for a Samsung? - I ...
www.askmefast.com > ... > Unlock
If you do not have the PUK card with you anymore the only way you can get the PUK code is to call customer service. I know your SIM ... Yes, your tracfone sim card will work on your unlocked samsung galaxy. If your getting an unlocked phone you`ll be able to use any sim card ... read more ... Tf64simt5 v2 fit what phone.
PUK TracFone Samsung S125G SIMCARD TF64SIMC4 V2 ...
www.askmefast.com > ... > Samsung
Need puk code for oberthur sim card provider to unlock samsung phone .... Tracfonesim card tf64simc4 v2 replacement ... your sim card will fit in. some smartphones now uses mini sim card like galaxy s3. .... Puk code for sim card tf64simt5 v2 .... I havesafe link wireless gov phone.phone is g440 says tracfone but it is safe ...
Which is the original carrier of my sim card in tracfone ...
Dec 29, 2015 | Samsung Cell Phones
How can you jailbreak a lg g800?
ow to Enter Unlock Codes on LG KB770: Insert an original simcard and turn phone on Enter sim PIN if required Enter 2945*#770# From the menu that pops up select "SIM unlock" Enter unlock code you received and press OK The phone will then reboot and the unlock is complete How to enter Unlock Codes to LG GB250 & GB220 Power on your phone without SIM card Enter 2945#*505# From the menu that pops up select "SIM unlock" Enter unlock code and press OK The phone will then reboot and the unlock is complete How to Enter Unlock Codes on LG GT505: Power on your phone without SIM card Enter 2945#*505# From the menu that pops up select "SIM unlock" Enter unlock code and press OK The phone will then reboot and the unlock is complete How to Enter Unlock Codes on LG KP100: 1) Insert a not allowed SIM card 2) Press the unlock button 3) Enter the code OR 1. Insert allowed SIM. 2. Booting (Request PIN Code, PIN Code enable) 3. In Idle Screen, Input the hidden number (2945#*20001#) 4. Input the number (above), go back to the idle screen 5. Menu-4.Settings, 7.Security-6.SIMLock Code:-1.Network Unlock Code:-1.Deactivate: 6. Select "1.Deactivate:" Menu, Display pop up " SIM Lock Code:". 7. Input right Unlock code, Display pop up "Deactivate". 8. Reboot, and unlock simlock code How to Enter Unlock Codes on LG KF390 and KF390q: 1) Insert a SIM Card from the network the mobile is locked to and turn it on 2) Insert the following sequence *#865625#; 3) Select 'Unlock USIM' 4) Select 'Network Lock' 5) Insert the unlock code 6) Reinsert the unlock code 7) Select OK. Done! How to Enter Unlock Codes on LG Prada (e.g KE850, etc): 1. Switch the telephone on with Original SIM card inside. 2. Enter SIM pin if required. 3. Enter 2945#*8501# and press the call button (middle button bottom of the screen). 4. SIM unlock mode will appear on screen. 5. Enter unlock code 6. Select Reboot. 7. Switch phone off, and then turn back on again. Phone is now unlocked How to Enter Unlock Codes on LG KE990 / KU990 Viewty: 1. Insert original sim card and turn phone on. 2. Press telephone icon at bottom of screen to bring up the phone keypad Enter 2945#*990# 3. A menu will pop up, select sim unlock: 4. Another menu will appear, select Network lock. Enter your unlock code and press ok 5. The phone will then reboot and the unlock is complete. How to Enter Unlock Codes on LG KG245 (Vodafone Australia): 1. Insert a Vodafone Australia working SIM card. 2. Ensure the phone is charged and then switch the phone on. 3. Optional Step: If the SIM card has a PIN, enter your PIN number 4. Wait for the phone to power up then enter 2945#*7101# 5. Select Menu , then go to Settings > Security > SIM Lock > Network 6. Select Deactivate and enter the 8-digit unlocking code provide for your handset. 7. The handset will be unlocked automatically and will display "Done". This will be confirmed if you can make and receive calls with the Non-Vodafone Australia SIM card. (You will need reception and phone credit with the different network provider) How to Enter Unlock Codes on LG KG800 or TG800 Chocolate: 1. With the phone in standby, enter 2945#*7101#. This will activate the extra menu. 2. Go to: Settings>Security>SimLock>Network 3. Select deactivate. Enter the unlock code How to Enter Unlock Codes on LG C2000: 1. Insert non-Cingular SIM card 2. Power on the handset - phone will display "phone restricted" 3. Select "Cancel" - phone will display "phone restriction code" 4. Enter the SIM Unlock code 5. Select "OK" - the handset is now successfully unlocked How to Enter Unlock Codes on LG U8150: 1. Switch ON your phone with a not allowed SIM card. 2. Compose: 277634#*#. 3. Go to menu "SIM Lock". 4. Enter the unlock code How to Enter Unlock Codes on LG INCITE CT810 Power on phone with original SIM card Type 2945#*810# In the menu that appears select Sim unlock Enter supplied unlock code Your phone is unlocked How to Enter Unlock Codes on LG F2250 Power on phone with Orange SIM card inserted While in the Start menu type 2945#*3311# Return to the startup screen Press Menu key Select Settings > Security
Jun 06, 2014 | Samsung Galaxy S GTI9000 Smartphone
Showing invalid sim
The most common thing for any mobile/cell phone.
Easy fix simply take an eraser & rub over the contact of the sim card then making sure not to touch the sim cards chip re-insert in to the phone & it should be problem solved. If the problem still exists insert in to another phone if possible to test the integrity of the sim card if the sim card works in another phone it could be the phone you are attempting to use it maybe faulty or the sim card is incompatible or the phone is not unlocked entirely, if it doesn't work in another phone the sim card has failed & a new sim card is required.
Apr 29, 2014 | Huawei Unlocked G6600 Qwerty Smart Cell...
Insert sim card
Do you want to insert other network sim or if your Blackberry Curve 8350I displaying insert sim card,if already sim card inserted.Don't worry i will help you.You can insert other network sim card in the phone by unlocking the phone from current network lock.To unlock Blackberry Curve 8350I use unlock code.Visit the site Wickedunlock.com get unlock code and unlock it easily.Then insert any GSM network sim card.If the phone displays insert sim card even though sim card is already in the phone.Please remove the sim card and replace it correctly.It is because the phone didn't detect the sim correctly.After inserting if it is display invalid sim or sim not valid message on the screen.It is locked to some network,you need to unlock it.To unlock use unlock code.Get code from online site and unlock it.
Jul 30, 2013 | Blackberry Curve 8350i
Sim
Did you mean your Samsung S8000 Jet phone displaying invalid Sim card?You need to unlock it from current network lock,to use other network sim card.Visit the site Mobileunlocksolutions.com get unlock code and unlock it easily.Then use with any GSM network sim card.Check whether unlock code is available for your network and country.If it is available get it and unlock it.You can unlock only GSM network locked phone.You cannot unlock CDMA network locked phone.After unlock your phone you can use any GSM network sim card in it.You cannot use any CDMA network sim card in it.
Jun 17, 2013 | Samsung Jet S8000 Cell Phone
When i insert my sim the phone does not support the sim
You will most likely have to purchase a new sim card as some phones are sim card specific. Also try a jail breaking program or have it done.
Sep 26, 2011 | Samsung Cell Phones
Sim card error
What is your Phone Brand and it's Model?
Make sure that your phone has been unlocked....If the Phone Locked means if you insert Other Network Sim card means it says invalid Sim or Sim card error...So find out the Network and country locked now,all network locked Phones cannot be unlocked ,Some Network locked Phones can be Unlocked.It depend on the brand of the Mobile also,you can unlock it using the Unlock code,You can get the Unlock code from the Theunlockarena.com
and Unlock it,after Unlocked the Phone use any GSM Network Sim card,You cannot use the CDMA Network Sim Card in the Unlocked Phone,Only GSM Network locked Phones can be Unlocked...
Jul 04, 2011 | Cell Phones
Motorola Mobility RAZR V3 Logo
139 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
Rami Obeid
Level 1 Expert
D. E. Hev
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
