Question about Kingston (DTIU3/2GB) 2 GB USB Hard Drive
How to take the file from the damaged pen drive?my pendive cannot open.but it can detact.
  • 696 Answers
If the drive detects as a USB device but not as a drive you will need the help of a pro. If it detects as a drive you may be able to recover the files yourself with a rather inexpensive program. Let me know if the drive shows up in My Computer or not and I can advise you further.
Chris
Posted on Sep 26, 2009
My pen dive doesn't show it memory . when i connect my 4gb pendive onto my pc then pc show me a removable disk connected but when i try to see properties then pc shows me that used space is o bytes and...
The problem you are talking about is most probably of the virus infection. Try to format your pen drive in your system and you can restore back your pen drive.
Dec 22, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Tip
Protecting Your Computer from Viruses
Well a computer user mostly afraid and suffers from virus attacks. Virus is the unwanted program that destroys your data and some times also damage the computer.
One of the most common ways of virus attacks is by connecting USB to your computer.
So today I will tell you some tips which can avoid or minimise the chances of virus attacks.
Always keep in mind the following points before connecting a pen drive to your computer.
1. Always use a good antivirus in your system.
2. Never open the pen drive directly.
3. before opening the pen drive, scan the pen drives for finding the possible viruses in the pen drive.
To scan the pen drive go to My Computer->Right Click on the Pen drive->Click on Scan option(Remember Scan option will only be there if there is any antivirus installed on your system)
4. if any virus found and the antivirus is not able to delete the virus, just safely remove the pen drive from your computer.
5. If no virus is found, do not double click on the pen drive to open.
Always open the pen drive by Right clicking on the pen drive and then clicking the explore i.e.:
My Computer->Right click on pen drive->Click on Explore
6. Always beware of copying the unwanted files on your computer. Just copy the file which you want. Never do a select all, copy all thing. Just copy the item you wanted, and paste into your computer.
While pasting the data you should never paste it on C drive (Drive that contains your operating system). Always copy data in a separate drive then C drive.
So these are some small steps which can be very useful to avoid virus attacks...
Regards,
polysandy
on Apr 12, 2010 | Computers & Internet
Pen drive is not openning asking formatt & not
Try to format it using the method describe below:
May be it will help
Go Start>Setting>Control Panel>
Or Start>Control Panel>
Then open> Administrative Tools>Computer Management>
Then select In the left Column Click disk management
Then locate your pen drive and try to format with fat file system
Also you can try to remove the partition and create new one
ok...
Regards
Uttam
Jan 16, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Pendive's containt
change the drive's Attribute using
Attribute Changer
http://www.petges.lu/index.html(Read the FAQ)
or
use XYplorer .
Aug 24, 2009 | Pen Drive IVO MP3 Player
Cannot transfer files in to sony 4gb pen drive
try a different usb slot ..if that doesnt works then it sounds like your pen drive is damaged .. that can happen in several ways .. if you carry it around with you, make sure the cap is on ... it can get static zapped otherwise .. also the gold fingers inside can get dirty .. another way the drives are damaged is to remove them while data is still being written to the drive ... wait until the light is no longer flashing before removing .. if you are using win98 or winMe .. then make sure you turn off the device before removing ..
Aug 05, 2009 | Sony Computers & Internet
Usb
I posted this to a similar problem:
I can help you with this. Follow these instructions--> Start-->Control Panel-->Administrative Tools-->Computer Management, under the Storage section select "Disk management". Locate the Pen drive, and then change the drive letter.
Select the external drive. Right click, and select "Change drive letters and paths"-->Highlight the driveletter to change-->Click the "Change" button-->From the drop-down list choose an unused drive letter, and hit Ok.
The pen drive should be recognized and accessible at this point. Let me know if you have any other questions.
Thank You,
 Raph30
Jan 28, 2009 | IBM ThinkPad R51 Notebook
Unable to open Pendrive
Your pen drive is infected by a virus/worm. I have two solutions for this -   > If you have WinRAR software, just open up the pen drive using this and delete "autorun.inf" from it.  OR  > Use any good antivirus software and scan your pen drive, and disinfect the pen drive from any virus/worms. Remove your pen drive, and insert it again. It'll work fine.
Dec 25, 2008 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
Pendrive problem
opening pen drive, it shows 'please insert the disk' & it shows 0 bytes & while trying to format it shows the same message again , i am using 2 gb pendrive of trancend.
Oct 24, 2008 | Transcend (589307) Media
Unable to open pen drive
Change your window yaar....its getting file crupte in windows library..........ok
I was also in tht problem.If this problem is arrive in more than 3 systems tht means ur pendrives starting sector is got damage thts called bed sector.
Oct 01, 2008 | Pen Drive IVO MP3 Player
Pen drive does not open
Your pendrive is affected virus and do the format both pen drives and first cheak with your usb port also once and when you are pushing the pen drive in the pc should be smoth dont press just push some times light is appear but data cabe is not connected to pc
Jun 17, 2008 | Computers & Internet
Kingston (DTIU3/2GB) 2 GB USB Hard Drive Logo
50 people viewed this question
Top Kingston Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
