Question about Logitech Wheel Mouse Optical
Light goes off & mouse stops working-have tried cleaning the light with alcohol on Q tip but doesn't help. it will stop working suddenly & start just as suddenly
  • 30 Answers
If it has a wire to the back of the computer make sure its plugged in tight sometimes tahey come loose. if its wireless change batteries. If neither buy new mouse.
Posted on Sep 26, 2009
How can i solve my mouse sensor (ttesport theron)? it stops working after I update the firmware that I downloaded from the official website
If the mouse has been used enough, there is a chance that dirt has accumulated at the opening of the sensor. Just put some alcohol base(95% alcohol) liquid on the tip of a cotton ear bud and clean it out. If this doesn't solve your problem - uninstall and re-install your mouse firmware( use something like ccleaner to get rid of all the files).
May 19, 2014 | Thermaltake TteSPORTS Theron Gaming Mouse
Tip
Mouse Balls ! How to clean a cranky mouse
This applies to ball type mice not the optical type.
If your mouse has stopped moving the cursor but the buttons still work or it isn;t as smooth as it used to be then this tip should help fix that. A lot of people will go out and buy a new mouse when all they needed to do was clean it.
To clean your mouse all you need is some rubbing alcohol, paper towels, cotton swabs and sometimes a pair of tweezers.
First thing to do is open the cover on the bottom and take the ball out. Use your thumbs to twist the cover and it will unlock. Set these aside we will clean them last.
Now look in the cavity and you will see a couple of wide rollers. These are what the ball rubs against and these in turn are used to generate the position signals to your computer. When they get dirty they won't roll and the result is that the mouse doesn't think it has moved. When you look at the rollers a dirty one looks like the photo.
The grey can be a a few things usually a mix of oils and dust. And sometimes it is lint. Soak one of the swabs in alcohol and wipe the roller. You will have to clean a spot then rotate the roller to clean a new area. When the stripe or buildup is gone then go to the next one. This takes a minute or so per roller so it is quick. If the buildup is stubborn you may need to scrape it off then clean.
The next thing to clean is the ball using a paper towel with alcohol. Just give it a good wipe and let it dry. Next clean the cover and the bottom of the mouse body. You may want to clean the surface you use the mouse on as well.
Replace the ball, replace and lock the cover in place and you are done.
The mouse should work normally now. If it still doesn;t it can be due to wear or lint on the internal sensors. However cleaning the mouse like this fixes it about 99.99% of the time.
on Apr 13, 2010 | Computers & Internet
Hi ! When I start to play a CD , it will only last for about 30 second , then it suddenly stop playing , what is the problem ?Grateful for help.
Either the laser is failing, or the unit is unable to move the laser along the sled.
Try skipping out to track 5 or so and see if it will play there for 30 seconds, or if it errors out trying to even get there.
If it goes to track 5 and keeps playing to the end, then you need to lubricate the chrome bar that the laser sled slides on. White lithium grease is what I recommend here. Remove the old grease first with a Q-tip and rubbing alcohol.
While you're in there, GENTLY clean the laser lens with a clean q-tip and rubbing alcohol.
Feb 24, 2011 | Audio Players & Recorders
Apple mouse scrolling problem
Your little ball is dirty. Q-tip and rubbing alcohol to clean it up. You will need to move it around with one finger while cleaning it. Be sure to disconnect it first.
Dec 29, 2009 | Apple Mighty MA086LL/A Mouse
All the sudden stopped reading disks on my ps2. How do I do a system reset? I am an electrician is there something I can do on the inside of the console to fix this problem?
the laser lens might be dirty.
try cleaning it with a q-tip dipped in rubbing alcohol (not dripping).
gently touch the q-tip to the laser lens and twirl it.
use other end of q-tip to clean it, again twirling it.
hope this helps ;p
it's helped a ton of people
Nov 09, 2009 | Sony PlayStation 2 (PS2) Console
Mouse Wheel not working
with mouse controls so cheap and so readily available , why would you bother with cleaning/ pulling it apart
is it wireless mouse ( battery flat) usb mouse ( cable problem) or mouse driver ( stopped working)
Apr 12, 2017 | Razer Computers & Internet
MU203 mouse not working
Replace the batteries and try this.
Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it to Reset/Connect the mouse to the receiver and work properly.
If not, try pressing the receiver button and then press the mouse. This should be done whenever you change batteries or glitch.
Hope this helps you. Bud
Nov 12, 2008 | ViewSonic MU203 Optical Travel Mouse
Left click on wireless mouse stopped working
Try taking the back off your mouse and cleaning the contacts with a q-tip and some alcohol. I would bet the other wheels inside your mouse could use a cleaning as well. Your mouse should work fine after you clean it.
or
if the left click dont work then it doesnt work unless there is a small fault in there. Can you here the click when you press it?
Truthly mouse and keyboards do not need drivers. So uninstalling and reinstalling will not do anything apart from taking up your time.
If you replace your mouse you will NOT have to get a new keyboard if you want. I have looked on the site that you gave for another mouse and truthly its up to you which one you want to get.
Hope this helps.
Jun 28, 2008 | Computers & Internet
Apple wireless mighty mouse
Here is my solution.
<embed src="http://www.veoh.com/videodetails2.swf?permalinkId=v378809PrA5a3pg&id=1377316&player=videodetailsembedded&videoAutoPlay=0" allowFullScreen="true" width="540" height="438" bgcolor="#000000" type="application/x-shockwave-flash" pluginspage="http://www.macromedia.com/go/getflashplayer"></embed><br/><a href="http://www.veoh.com/">Online Videos by Veoh.com</a>
Nov 16, 2007 | Apple Mighty MA086LL/A Mouse
Erratic behavior
I just sprayed my dad's lens cleaner on one end of a Q-tip to clean the lens of the mouse and dried the excess fluid with the other end of the Q-tip. WORKS GREAT :)
Nov 10, 2007 | Targus AMU18US Mouse
Logitech Wheel Mouse Optical Logo
234 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
