Question about Car Audio & Video
I have a 2005 Ford F150 truck. The radio resets as if the battery has been disconnected every time I crank the truck. I have had the battery checked out, it is OK. What would cause this to happen?
  • 301 Answers
The starter might be drawing too much current. Although it will still start the starter might be sucking all the juice out of the circuit making the radio think the power was disconnected. Also check the ground that the negative battery cable connects to. Get someone to do a starter current draw.
Posted on Sep 26, 2009
Reset computer 2003 ford f150 7700 series
Not sure what you mean by reset.
You can disconnect the battery and leave the door open for a few minutes to drain the power for the radio memory.
To clear trouble codes in the computer, you would need a code reader or scanner to erase them.
Feb 27, 2015 | Ford Cars & Trucks
The radio from my ford f150 wont turn on
I'd start by checking the fuses and resetting the electrical system by disconnecting the battery for about 15 minutes.
Dec 17, 2014 | Ford F-150 Cars & Trucks
Ford F 150 Radio stuck in Phone mode
Leave the battery disconnected overnight - NOTE THE ALARM AND OTHER BATTERY DEPENDENT ITEMS MAY NEED RESET, or just pull the fuse for the radio - read your owner's manual..
If it still doesn't reset, you'll need to remove the radio or see if it has a reset option on the radio.
GL,
Td
Oct 08, 2012 | 2004 Ford F150
My 2005 F150 Won t start. When you turn the ignition switch fuse # 102 the ignition switch feed blows. Can anyone help me on what could be overloading or shorting the wiring?
I have a 2005 f150 fx4 have replaced battery every winter because when it gets cold the truck won't start, It is not the battery because dash lights, door chimes all work but truck won't even crank (dead). Ford insist that it is the battery.
Dec 27, 2010 | 2005 Ford F-150
Change radio in 2005 F150
Well you need to remove the center instrument panel then disconnect the connectors behind it then remove the 4 screws that hold the radio in and unplug the connectors behind it. You might have to take your truck to the dealer to get your radio programmed to your truck that is right around the year that was one of the procedures. So if you change your radio and things in your truck start acting goofy and the radio doesn't work cantact your local Ford dealer with that question. Good luck.
Apr 17, 2009 | 2005 Ford F-150
Radio settings default every time I start the engine...
make sure the memory wire is connected straight to battery and or the fuses
Mar 26, 2009 | 2005 Ford Mustang
2003 Ford F150
disconnect the battery terminals... wait about 10 secs and reconnect... that should do it
Dec 08, 2008 | 2003 Ford F150 Regular Cab
Ford Taurus
I had all the same symptoms, would crank, but sometimes not start, guages would not come up immediately, and sometimes several trouble/warning lights would light. Also, my computer display settings would change. I also noticed that some of my radio setings would change too. Well, when I recently replaced my weak battery (original factory battery), all of the problems/symptoms went away. So, it was either the weak battery, or disconnecting the battery reset/fixed some kind of computer glitch? I think it was just a bad battery all along. Have your battery checked, even though it cranks, it may be delivering low current/voltage which affects the computer and other electronics. Hope this helps!
Sep 03, 2008 | 2005 Ford Taurus
Car Audio & Video Logo
194 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
