Question about GE Profile JTP18 Electric Single Oven
My oven stays on, only way to shut off it to shut breaker
My oven stays on, even when the knob is turned to off. the only way to shut it off is to turn off the breaker
  • GE Master
  • 2,605 Answers
Do you mean it continues to heat, or the indicator "says" it's on ? These wall ovens have notorious problems with the erc (clock/timer) could be a relay stuck in the closed position. trip the breaker, pull out the erc and visually inspect it, or if you're really inclined check to see if the relay "cycles" (clicking on & off/open & closed) through out operating.
Posted on Sep 26, 2009
Oven will not shut off
Good Morning Friend,
I understand your Frigidaire oven will not turn off. I also see that when you turn it off, the blower and heating element, stay on. The blower will stay on to help cool down the oven, but the heating element should turn off. I see that you have to turn your oven off at the circuit breaker. I suggest contacting your local authorized dealer for further assistance. They will be able to diagnose your appliance and determine why your oven will not turn off. Hope this is helpful.
-Best Regards-
WP
Jul 02, 2014 | Frigidaire Ovens
Oven will not turn off
-Best Regards-
WP
Kenmore elite dual fuel range model # 790.75503- My power was cut off and since my oven won't heat (display shows on, but doesn't heat - stays at 100 degees) - also my burners won't ignite (unless I t
It could possibly be you are not getting 240 volts to the range. The top igniter may be getting a current back through the other side of the 240 circuit and that is why it works when the oven is turned on but the oven will not be getting power to heat. Have the 240 circuit checked or make sure the circuit breakers are reset correctly.
Feb 09, 2014 | Ovens
My oven wont turn off from the knob it keeps turning
You didn't say whether you have a gas or electric oven, or oven & stove. I'll assume you have a stove, just to cover all bases.
First, you should shut down the oven: a gas stove will have a valve on the gas line behind the stove. The valve will either have a red handle or a flat stem that usually has a hole in it. Turn either valve 1/4 turn to shut off gas, use a wrench on the flat stem. An electric stove should be shut off by flipping off the double circuit breaker for it in your electric panel. Do not unplug an electric stove when it is on; this can damage the plug &/or electrocute you.
Most likely the inside of the knob has stripped out. Look at the knob for a hole that has a setscrew in it: a small allen wrench or screwdriver will loosen the setscrew, most knobs don't have them and will pull off. Be careful to use even pressure on two sides of the knob; if you can't pull it off, use two butter knives or flat screw drivers to pry it up enough to get a grip on it.
Look at the center stem on the back of the knob, it will likely be cracked or stripped. Some stems have a D-shaped metal insert that strips out inside the plastic stem. If you have one, pull off a burner knob and compare the stems in the back, if they are the same size, put the burner knob on the shaft for the oven control, and use that knob to turn the oven control off.
If the burner knob won't fit, use your fingers or a pair of pliers (gently) to turn off the oven control shaft. If the shaft stops normally, you can turn the stove back on using either the gas valve or the circuit breaker. If you have a gas stove that doesn't have electric ignition (a clicking noise when you turn on a burner) you may need to re-light the pilots for the burners. Lift the covers off the burners to re-light the pilots.
If you have succeeded in turning off the oven, you need a new knob -- you can get one at an appliance parts store or maybe a hardware store. If the oven control did not turn off normally, I would leave the oven/stove turned off: the control itself will need to be replaced by a qualified repair person.
Mar 03, 2013 | Ovens
Bottom oven element stays hot will not cut off
In order for the element to stay on, the oven switch must be broken. No details are provided, but if your oven is like most, you have an Oven Selector knob for ~bake, broil, clean and another knob for Temperature selection.
Look at your Oven Selector knob closely to make sure it is not slipping on the shaft. It may be as simple as the knob being broken, and even though you are turning it to the Off position, the switch may still be on. If the knob is indeed turning the switch shaft, then it is most likely the switch stuck in the own position. Thanks for using FixYa.
Mar 03, 2011 | Ovens
The broiler coil heats even when the oven is off.
The oven control is bad, since I do not have your model number I cannot tell what type of control it uses. If you could send me the model number from the tag I could take a look and maybe give you some insight as to what it will take to repair.
Thank you
May 12, 2010 | Ovens
OVEN STAYS HOT
This is somethig you should have checked by technician.Till then turn the oven off then pull straight out on the knob removing it. use a plyers to check if it's actually turning off by turning it to the left. If it does turn to the left( off position) you may just need a new knob.
Oct 04, 2009 | Ovens
Broiler won't turn off. Error code F-3
The broiler won't turn off even when you press the "Off/cancel" button? It sounds like the broiler control relay is stuck shut. The F3 code means the oven temperature sensor has failed, this probably happened because the oven got too hot when the broiler was stuck on. There is fail-safe thermal fuse that will blow if the oven gets too hot, so the oven won't melt down but you should leave the unit off so you don't blow the fuse.
To fix the relay, you will have to replace the oven control module. I think this is about $200 and not too hard to replace if you are somewhat handy. The temperature sensor is also serviceable, you can find parts at Appliance Parts Pros on the web. Hopefully you haven't thrown the range out yet, let me know if you need further assistance.
Nov 27, 2008 | Whirlpool RBS305PD Electric Single Oven
GE Profile JTP18 Electric Single Oven Logo
150 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a GE Oven Expert? Answer questions, earn points and help others
