Question about Disney Princess MCP DVD2050P DVD Player
Vcr dvd combo
2 year old pushed a dvd and toy into vcr had to dismantle to remove vcr won't accept tape now ejects immediatley
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 242 Answers
Retime the gears
Posted on Jul 17, 2010
Cannot play a VHS tape. Push in and pops out.
The belt on the loader motor is slipping. This causes the tape to not completely position itself to allow the tape to load around the drum. The machine senses this and ejects the tape.
Feb 20, 2014 | Samsung DVD-VR375 DVD Recorder/VCR
I hAVE 24 in DVD triple combo ^&@$DG TV. I put
You're describing what could be a loose or worn loading belt problem, most of the vcr mechanisms used in these combos use one to load the tape and thread it for it to play or record, that is why you have to keep puhing the tape untill the machine accepts the tape and you have to keep pressing play untill it starts the play function.
Sep 19, 2009 | Sylvania Televison & Video
Vcr/dvd combo, vcr no longer will play tape, when I press play, after a few seconds will eject tape.
Hi
Thanks for using FixYa. Please check the eject mechanism and the drive motor connected with the tape mechanism. Try and align the drive motor. Also check the push-pull arm of the tape mechanism and make sure that the springs connected with the mechanism are fine.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Sep 15, 2009 | Philips Magnavox DVD/VCR Dual Player
Go-Video VCR Problem with accepting/ejecting tapes
As with any VCR, there are rubber parts inside that have become slick. This is a simple repair for any shop. The mechanisms are Samsung ones if I remember correctly. Expect a parts cost between $20-$40. Add in the local labor rate for the total cost. This is worth the repair cost as any replacement would not last anywhere near as long. This is also a normal occurrance as rubber parts harden with age. I have repaired many of these over the years.
Dan
Jan 05, 2009 | GoVideo Go Video DVD/VCR Combo
VCR Not Accepting Certain VHS Tape
I had this happen once and all I did to correct it was to fast forward it just slightly or manually wind it past the leader strip (the clear or white part at the beginning). To do it manually, there is a small hole you must insert a toothpick (or something else as small) to push the pin in and then advance it with your finger while holding the pin in. Hope this helps.
Oct 15, 2008 | Philips Magnavox DVD/VCR Dual Player
JVC HR S5700AM S-VHS video recorder - won't accept tapes
Hey Lindsay
Yes the ejector is probably damaged inside maybe a bent arm or something mine is like that 2 and I didnt even bother fixing it I will be finding one very soon and I suggest you should 2 so just throw out the old and come in the new with your new vcr or dvd vcr combo..
Jul 23, 2008 | Televison & Video
Lg v181 combo problem with vcr keeps ejecting tapes when I want to record.
The tape load carriage is defective or there is something in the way inside the machine....accordianman
Feb 21, 2008 | LG V181 DVD Player/VCR
What do I do when my Emerson TV keeps turning off by itself?
I had the same problem with mine turning off after 3-5 seconds. After much research I found a suggestion that on some combo units the vcr part could have a power supply cutout if it is not working correctly. I tried to insert a tape and found that the tape mechanism would not accept a tape. I used a little bit of force and managed to insert a tape. I then played the tape forwards and backwards and the power stayed on! I ejected the tape and found the TV then worked just fine. The power has now been on for over one hour. I hope this give you another avenue to try and fix your problem.
Nov 30, 2007 | Televison & Video
Disney Princess MCP DVD2050P DVD Player Logo
46 people viewed this question
Top Disney Televison & Video Experts
Jaime Hernandez
Demonic-2011
Demonic-2011
Are you a Disney Televison and Video Expert? Answer questions, earn points and help others
