Question about Pioneer VSX-305 Receiver
It displays muting in the lcd box how do i get it back to a normal state ?
    President:
  • Pioneer Master
  • 1,114 Answers
Press the "Mute" button on the receivers remote control again and it will return to it's normal state. Hope this helps.
Posted on Sep 26, 2009
TV has no sound
Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Pull up older posts. Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Sep 30, 2016 | LG 46LD550 46 in. LCD TV
APEX LD4088 service menu (advanced menu)
Try this:
  • Turn the TV off.
  • Press and hold the {VOL -} button ON THE TV and
    the {TV/VIDEO} button on the remote for at least 5 seconds.
  • The TV will turn on with the Service Menu displayed.
Here's how to access the SM:
  • While the TV is in standby:
  • Press the {DISPLAY}, {5}, {VOL+} & {POWER} buttons.
Nov 29, 2014 | Apex Digital LD4088 LCD TV
How can I turn off CC on my SONY 52XBR. I used the Remote control settings and selected off on the cc display, but the cc never turns off. I also used the menu button on the side of the T.V to select
If Closed Captioning is being displayed even though the CC option in the TV menu is set to Off , then it is being produced by another device, such as a cable or satellite set-top box. To remove the Closed Captioning from the TV screen, it must be disabled on the device that is decoding the Closed Captioned signal.
NOTE: Some set-top boxes may automatically display Closed Captioning on the TV screen when the set-top box sound is muted. If this is the case, turn off the Mute function of the set-top box
Oct 31, 2014 | Sony Tv Xbr Bravia Kdl-52xbr5 52 Lcd Tv...
Sennheiser ew135 mutes at random moments during a show and it also displays MUTE on the LCD screen. Any solutions would be greatly appreciated. Thanks!
It sounds like wireless signal problems...the receiver will mute when it loese signal from the transmitter (mic).
1. Raise the receiver up higher in the performance area.
2. Stay within the recommended range/distance stated in the owners manual.
3. Read "If a problem occurs" section of owners manual...page 31 "MUTE appears on display panel." For some reason I can't link the owners manual here, but sweetwater music has it at the bottom of the Sennheiser ew135 sales page.
Sep 10, 2013 | Audio Players & Recorders
Hi, I started to have an issue with a display of my Tecra M5. The laptop is 2 years old and there has been no problems with it before.. Last week I attached a 32" LG LCD TV to my Tecra as an...
the 32 inch LCD may have a lower display resolution that the LCD on your system. Ensure that the display settings for the LC are at the MAX resolution and 60 htz
Jul 31, 2011 | Toshiba Tecra M5-S433 Notebook
How do you shut off the internal speakers in Dynex 42" LCD tv?
The best solution i have found so far is to hit the mute button on the remote. It will display a small "MUTE" box in the lower left corner of the screen for a short while, but that will disappear. Another issue that makes this solution less than perfect is that you must hit the mute button every time you turn on the TV. There's got to be a better way, but I just can't find it.
Dec 25, 2009 | Dynex DX-LCD19-09 19 in. LCD TV
Mute the audio system when
yes the yellow wire is mute and needs to be connected to the mute on the back of your radio.
Nov 06, 2009 | Parrot SA Parrot Ck3100 Lcd Handsfree...
A box stating not optimum mode-get distorted internet images
Sounds like your resolution is not set correctly.
Try going to Start-->Control Panel-->Display and choose the Settings Tab
Under there change the resolution slider bar to 1280x1024
Should do the trick!
Jul 11, 2009 | Samsung SyncMaster 913V 19" Flat Panel LCD...
It is all black, as if off
when starting windows press f8 key before the windows logo shows up > go to safe mode > click start>control panel> display>adapter>list all modes> choose 800x600 x 16 colours > apply > close > reboot to normal xp. OR When f8 key pressed > choose VGA mode. If this does not work then change the VGA Cable (borrow from someone if its TFT to test)
Jan 05, 2009 | Acer AL1717 17" LCD Monitor
140 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
