Removed the sorter from a ricoh FT5832 copier and replaced with copy tray. how do I bypass the sorter cover (C-5) error message? Will not operate without the sorter plugged in.
  • 143 Answers
Enter the SP mode by hitting the CLEAR MODE key, 1 0 7 then hold the CLEAR STOP key. When SP mode is selected , "1" blinks. Then enter SP 6-101-0 by hitting 6 then the . (dot) key, the 101 then the . (dot) key then the 0 key then the . (dot) key. This will tell the copier that NO sorter is intsalled. Hit the CLEAR MODE key 3 times or turn the machine off/on.
Posted on Sep 26, 2009
Lanier 5635 Sorter
Under user tools, system settings make all prints, copies to come out in internal tray, the front and rear covers have to come off to remove screw 1 each side the SC code is shift tray motor error
Dec 18, 2013 | Lanier Office Equipment & Supplies
The ricoh copier ft5832 lift that raise the paper plate in tray 1 & 2 are no more working; how can i get it replacement or get repaired? Thanks
Hello; if you have tray 3 and it working fine, then exchange with tray 1, if working that's mean the senser actuactor on the tray 1 is broken replace it, otherwise that's lifting motor defect, replace lifting motor.
Oct 07, 2012 | Ricoh FT5832 Copier
When i switch on my photocopier tohiba 2860, it asks for service and gives an error code 08221-918100. what could be the problem?
Hi tkasirye,
Welcome to Fixya.
You may need to check again the error code. According to the manufacturer's checklist for error codes, only the following are documented;
  1. Error Codes - Toshiba 2860
  1. "E01" Paper jam inside machine. "E02" Paper jam near the fuser. "E03" Paper jammed inside machine when power supply is switched on. "E04" Front cover open while copying. "E05" Paper jam near the aligning roller "E08" Paper jam at stacking area in the ADU "E11" Paper feeding jam at the ADU "E12" Manual feeding jam "E13" Paper jam from cassette 1 "E14" Paper jam from cassette 2 "E15" Paper jam from cassette 3 "E16" Paper jam from cassette 4 "E17" Paper jam from cassette 5 "E19" Paper jam from the LCF "E21" Paper jam in transport route 1 (LCF) "E22" Paper jam in transport route 2 (COPIER) "E23" Paper jam in transport route 3 (ALIGNING) "E25" Paper jam in transport route 4 (PFP) "E71" Original feed jam in ADF "E72" Original transporting jam in ADF "E73" Original exiting jam in ADF "E75" 2nd original feeding jam "E81" Paper jam before sorter "E82" Paper jam in sorter "E83" Sorter early arrival jam "E84" Paper in sorter when power is turned on "E85" Joint open jam while copying "E88" Paper jam outside the sorter bin "C01" Abnormal operation of the copier main motor "C04" Abnormal operation of the PFP main motor "C05" Abnormal operation of the ADU main motor "C11" Abnormal operation of the ADU side motor "C12" Abnormal operation of the ADU end motor "C13" Abnormal operation of the upper cassette tray "C14" Abnormal operation of the lower cassette tray "C15" Abnormal operation of the PFP upper cassette tray "C16" Abnormal operation of the PFP middle cassette tray "C17" Abnormal operation of the PFP lower cassette tray "C18" Abnormal operation of the LCF tray "C21" Optics carriage initialize error "C22" Lens initialize error "C23" Mirror initialize error "C26" Faulty exposure lamp "C33" Easy set-up is failed "C35" Developer material exists at the transfer separation adjustment "C41" Faulty thermistor or heater "C43" Faulty thermistor "C44" Faulty heater "C45" Sub thermistor is open
Shoulg you not find any of these mentioned error codes, I suggest you contact the tech support especially if the machine is still under warranty.
Hope this helps.
Takasashi
Jul 05, 2011 | Toshiba Office Equipment & Supplies
Error code E70 on ricoh FT 4418
Empty the waste toner tank.
1. Open the front cover
2. Lower the transport unit
3. Pinch the cleaning blade release lever and slide the cleaning unit out.
4. Remove the 4 screws in the top cover of the unit.
5. Dump out the waste toner.
Mar 14, 2011 | Ricoh FT5832 Copier
It is showing the following signs U1, A,C
look my dear that is misfeed positions ok a; that mean first tray misfeed and tray2 c; that mean misfeed in fuser unit u1; mean misfeed in sorter
Jan 08, 2011 | Ricoh FT5832 Copier
I have a RICOH FT 4022 Copier and when I switch it displays U 6
Ricoh 4022, 4027 Код ошибки Описание C1 Front door open C2 Exit door C3 Cassette cover C4 LCT cover C5 Sorter open or not latched to machine, or fuse 304 on DC power board C6 ADF cover C7 Right side cover E101 Exposure lamp too long E103 Frequency problem E120, 121 Scan home problem E124 Scan drive problem E140 Lens home, or fuse 303 on DC board E141-143 Lens home sensor, fuse 303 on DC board E144, 145 Mirror sensor, fuse 303 on DC board E191 Image density sensor error E302 Charge roller problem or HVT problem E346 Bias loss E351 Image density sensor problem E352 TD sensor error E353 Vsp problem. Dirty or bad image density sensor E354 Vsg problem. Same as E353 E355 Toner density sensor problem E356 Same as 355 E405 Transfer belt or charge roller drive E440 Main drive E442 Drum charge thermistor E501 Upper lift motor E502 Lower lift motor E503 1st tray motor E504 2nd tray motor E505 3rd tray motor E506 Tray main motor drive problem E507 LCTl lift motor E522-525 Jogger sensor E541 Fuser thermistor E542 Fuser temperature too low E543 Fuser temperature too high E544 Fuser temperature too high E547 Fuser lamp won't shut off E548 Fuser temperature too high or too low E620 Communication problem between main board and ARDF E621 Communication problem between main board and sorter E623 Communication problem between main board and paper trays E720 Sorter stapler timing roller sensor E721 Sorter stapler bin lift sensor E722 Sorter stapler jogger sensor E723 Sorter stapler grip sensor E724 Sorter stapler error E900, 901 Copy counter U2 Key counter U6 Fuser unit not installed properly U7 Duplex unit
Aug 24, 2009 | Office Equipment & Supplies
E6 error On a Ricoh ft4022 copied paper doesn't throughly comes out
It can be some of this because you give us only the firs digit you should press "." for to see the two other digits which can be as follow:
E620 Main board – ARDF communication error
E621 Main board – Sorter communication error
E623 Main board – Paper tray unit communication error
For start you can see do the sorter or the ADF are good connected
It has two cables one is white and other is black see do they are good connected or it can be broken on some place of the cable, special the black because is optical cable.
also see do the paper tray is good entered in the machine if all this up mentioned are good then is a problem with the main board
May 13, 2009 | Ricoh Office Equipment & Supplies
Hi, I am receiving an E-4 error message on my FT5832 copier. I have tried shutting off and restarting the copier a few times, and this hasn't fixed the probem,. Please advise. Thanks!
if you are not a technician here you cannot do nothing because the problem is around the main motor.
The main motor may be loced or some gears in the drum unit are broken.
This problem can solve only official ricoh technician.
But this is a old machine so if need to be replaced the motor is better to not do that because for those many you will by some new machine.
I advice to call a service because if you want to operate your self you may damage something and from nothing to became a large scale problem
Dec 04, 2008 | Ricoh FT5832 Copier
Ricoh FT3713
Try to properly close the cover and also the Drum Section
Sep 22, 2008 | Ricoh FT5832 Copier
97 people viewed this question
jasbo
jasbo
