Question about Car Audio & Video
When I shift from park to drive, the radio cuts out on my ford ranger
  • Christopher Walker
    Christopher Walker May 11, 2010
    does the radio resume proper operation after you are in drive? If not will it power back up if you turn it back on
    Problem Solver:
  • 10 Answers
Thats unusual check wiring or take it into shop
Posted on Sep 29, 2009
What causes engine to ABRUPTLY shut off while driving ?
2004 Ford Explorer Engine Stalls/Cuts Out While Driving: 31 ...
www.carcomplaints.com/Ford/Explorer/.../engine/engine_stalls_cuts_out...
... 2013 · 2012 · 2011 · 2010 · 2009 · 2008 · 2007 · 2006 · 2005 · 2003 · 2002 · 2001 · 2000 ... 2004 Ford Explorer engine problems: engine stalls/cuts out while driving ...to overheat and slide out of its socket, causing the engine to shut off. ..... Suddenlyat 30-35mph, my engine just died and i cannot control the steering wheel.
2005 Ford Escape Engine Shutdown While Driving: 24 ...
www.carcomplaints.com/Ford/.../engine/engine_shutdown_while_drivin...
The 2005 Ford Escape has 24 complaints for engine shutdown while driving. ...January 22: Ford Ranger Driver Killed by Takata Airbag in South Carolina news ' 2 days ago; Ford Focus Door Latch ..... I was 80 miles from home when the engine shut off. .... No one could seem to determine the true cause of the problems.
Ford Ranger Stalling/Dying Problems - Edmunds.com
forums.edmunds.com > Ford > Ford Ranger
Nov 2, 2007 - 31 posts - ‎21 authors
Learn more about Ford Ranger at the Edmunds.com Car Forums! ... cut off a couple of times then it started happening more frequent while driving. ..... the other day I was driving down the highway and it just shut off, no warning .... 2000. when it gets overheated the circuit shorts and causes the engine to die. Ford Expedition engine cutting off while driving
Oct 24, 2009
Mercury Mountaineer Start Stall Idle Problems
Oct 1, 2007
More results from forums.edmunds.com
Jan 27, 2016 | 2003 Ford Ranger Regular Cab
Radio quits when taken out of park or neutral
Sounds like the physical movement of the linkage is pulling or rubbing the harness. Get up under the dash and see how the harness is located.
Nov 01, 2015 | 2007 Ford Ranger FX4 Off-Road
Location of 4 wheel drive relay on 98 ford ranger
All the relays are under the hood on these rangers, but you problem may be with the control box behind the jump seat on the drivers side. You may have to remove the jump seat to get to it. Once there, the box will have a white,grey or black button on it. Usually on the end where the red light is, Turn the key on and press this button and hold for 5 seconds. This puts the 4 wheel drive shift motor back in sequence. Now without starting the engine and the trans in park if auto and neutral if standard park break set, try the to shift in to 4 high, if you can hear the shift motor run and shift the gears in the transfer case, try 4 low, you should hear the same motion in the transfer case, if so you have solved your problem. If not you may have to move on to the connector on the transfer case, you may have to unplug the connector and look at the pins and socket, if they look corroded, clean and apply some dielectric grease to the pins and the socket and plug back in. Try the 4 High and 4 low again. If it works, great, if not you may have a bad shift motor.
Good luck.
Feb 25, 2014 | 1998 Ford Ranger
2004 ranger will not start in park
Sound like a problem with the Safety Neutral Switch, its possible that need adjustement. Keep in touch.
Hope this helps.
Jun 20, 2012 | 2004 Ford Ranger
1995 ford ranger wont come out of park
try disconnecting the rods from the ignition switch shift lever inhibitor.this is basically the mechanism which prevents you from turning the ignition switch to the 'lock' position when the shift lever is not in the 'park' position
Jan 27, 2012 | 1995 Ford Ranger Supercab
When i am driving my 2005 ford ranger the radio cuts out and and there is no sound, there wont be any sound from the CD player but the counsel shows that there still is power to it. When i put the truck in...
I have had the same problem with my 2007.
Going to the dealer, they did not found the cause and charge me for 2 hrs invstigation. ($200).
Finnaly I found the source of the problem by myself.
Water entering in the right door and falling on the speaker. + drain holes blocked at the bottom of the door by antirust compound.
Cleaning the drain holes, almost 1.5 liter of water flowing from the inside of the door. 2 days after, door interior drying, the radio start to work normally.
Jun 13, 2010 | 2005 Ford Ranger
1994 Ford Ranger won't shift into drive
In 9 out of 10 cases when I see this problem in the ranger, it is the planetary gear in the transmission. It is made of the cheapest metal available. It breaks usually from going to park before the truck stops or switching from reverse to drive while still rolling. Just a Idea , But I hope it isn't that . Reverse will work fine for a while, and have no forward gears.
Jan 15, 2009 | 1994 Ford Ranger Supercab
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
