Question about HP LaserJet 1020 Printer
Printer ZM400 First Label problem
Printer Name: ZM400
First label always failed as it didnt print out the whole data. For instance, it only print out the 80% (top part) of the data while the rest 20% (bottom part) is not displayed.
However, the next subsequent label is working fine.
But if the printer prints alot of labels at once, it may stop a while (around 0.5 sec) and print again. This problem happened again as the next first label printed out.
If I was not wrong, this happened since we replace the ribbon.
jaylex
  • 417 Answers
SOURCE: Printing accurately
Hi there within the envelopes and labels print function within MS Word you will be able to set the correct label and sizes. If this doesn't work then adjust the margins.
This problem is nothing to do with your printer as you are sending a command to it and the printer is doing what you told it to do. Check the settings first.
Thanks J
Posted on Jan 13, 2008
SOURCE: Printer Stripe S-500 Zebra
The printer now is replaced, but i had changed also te printhead before. Now we use a other type of Zebra now :), more better and slower.
Thank You
Posted on Feb 04, 2008
SOURCE: cd label
I finally figured it out. The default DISC LABEL got set to HP TATTO. It should be PRINTABLE CD/DVD STANDARD. The HP Tatto uses the photo paper tray so the printer wants you to close the DVD tray
Posted on Jun 18, 2008
SOURCE: Datamax I-CLASS DMX-I-4212
Printer ribbon has a wrinkle and it transfers to the label in the form of a blank line accross the ribbon.
Posted on Aug 19, 2008
SOURCE: My printer display keep showing " Warning, Ribbon in", cannot print multiple label at a time
i have the same problem , but my printer is ZEBRA S4M ZPL
my solution is:
in your barcode software: change printer settings: 1 and 2
1 . in media setting : change media type --> Thermal transfer
2. in documents options , configuration --> use printer settings
by Lin Yu Hsien
Posted on Dec 10, 2008
The top portion of the word and or number is cut off on the label. Other wording is fine on the label. Zebra ZM 400
please send me photo to paulr@Rocotech.com.au and I will help you to sort the issue. regards. Paulo
Mar 02, 2015 | Zebra ZM400 Thermal Label Printer -...
How to fix dissapear printing label for Zebra ZM400
Hi, please be more especific regarding issue, can be software issue or hardware issue.
Jun 20, 2014 | Zebra ZM400 Thermal Label Printer -...
Z4MPLUS doesn't recognize the MEDIA(LABEL) automatically.
you should recalibt=rate the printer.
Are you sure that your previous label was not longer?
With the autocalibrate function activated the printer should try to detect the correct length. If it doesn't the yoou have
- A problem with the label border
- Preprinted stuff which the printer detects as to fo feed
Dec 09, 2013 | Zebra Z4Mplus Label Printer
The print out of ZM400 misalign to the left. How to make it back to the centre of the label?
Printing from an Internet Browser can cause this result if you have not set the margins, footers, and headers.
File ' Page Setup
Change all margins to 0.01 (or as close as possible, it may override you) and all SIX bars below that to Blank or Empty.
Apr 10, 2013 | Zebra ZM400 Thermal Label Printer -...
Zm400 media darkness settings get reset after printings lable from SAP
The printer driver settings override the printer settings unless you tell the driver to use the printer settings. You can tell by setting the printer setting and saving it permanently. Print a configuration label. Send a label to the printer. Print another configuration label. Compare the config labels and If it changed, then the driver changed it. Set the driver as above and it will not change when you print.
Jan 18, 2013 | Zebra ZM400 Direct Thermal-Thermal...
Zm400 label jam
Hi
Do not use a tool you may damage the printhead which will cost ofver 300 pounds to replace. First get what you can off with your fingers, then use IPA swabs or cotton cloth soaked with white spirit to gently and patiently remove the remains of the label and any adhesive residue.
Regards
Rob
Plain, Printed and Barcode Labels
May 11, 2012 | Zebra ZM400 Thermal Label Printer -...
On the Zebra it was printing 4x13 labels without a problem. However when I tried to print a 4x6 label it still thought there was 4x13 stock in the printer. I played around with the label format size, even...
I think this is more related to the calibration of the label each time you change the new label size. I use ZM400 and your printer should also have the same setting. Under setting, put the When Head Close setting to Calibration. This will let the calibration perform automatically when ever you load a new label size and close the print head. Well 2 label will be lost every time.
Aug 31, 2011 | Zebra 105SL Thermal Label Printer
Will not print onto the label. but can see it on the black ribbon reel.
Perhaps your darkness is set too low, or your labels are not coated to accept thermal transfer printing. Let me know if this helps!
Aug 28, 2011 | Zebra ZM400 Thermal Label Printer -...
I print labels on a ZM400 zebra printer, I use Bardy software. on almost ever label there is white line that appear to be wrinkles. Never in same area.
check to see if part of a label is stuck to the print head. If not then clean the print head with alcohol. wipe it only in one direction. If this still fails then you will have to replace the head.
Apr 23, 2011 | Zebra Z4Mplus Label Printer
I can't print label from ZM400 PRINTER thru' serial port
There are a number of parameters for the serial port that have to match the pc. i would print out a config page from the printer via the menu, or power on with the cancel key held. then compare it with the settings on the pc. on the config page you should be looking for things like data bits, host control, parity etc.
Jan 19, 2009 | Zebra 170XiIIIPlus Thermal Label Printer
HP LaserJet 1020 Printer Logo
61 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
