Question about GE Profile Spectra JGBP90 Gas Kitchen Range
I have a JGBP30 gas range and the oven does not. Someone checked it and said the main control is bad. Is there a manuel that I could get or is there any way I could check it, before ordering a new control, as this seems to be a very expensive part?
  • GE Master
  • 2,605 Answers
Does the oven ignitor "glow" when turned on but no flame appears? does this model have an actual broil burner ? or does it just have a broil drawer at the bottom ? If it has a broil burner up top of the oven, does it ignite ? It could be the clock/timer, but rarely. If the "bake" ignitor glows, but the burner doesn't ignite, or ignites slowly and/or a "sputtering" flame, replacing the bake ignitor should solve the problem.
good luck
Posted on Sep 26, 2009
I have a GE JGBP30 gas range. The oven is taking
Quiet possibly, but make sure there are leveling legs installed and the front edge of the range is not blocked by any flooring. It may be that the oven is not receiving enough combustion air. (sometimes happens when flooring is replaced and legs are removed so the range is not higher than the countertop, or a layer of flooring is added to the room and buts up against the range, where flooring was not added.)
Jul 04, 2010 | GE Spectra JGBP30 Gas Kitchen Range
Broiler works - oven won't heat - smell gas
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Oven Problems Replacing the Igniter http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
Jun 03, 2010 | GE Spectra JGBP30 Gas Kitchen Range
GE Spectra Oven flames TOO High
have your gas pressure regulator checked
Nov 02, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
When i increase the temperature control the oven soots excessive
Check your oven for flame color; what you are describing could be deadly. It is possible that you have an air vent clogged or blocked causing the flame to burn yellow indicating incomplete combustion and possible source of carbon monoxide. This is very dangerous and I would strongly recommend you purchase a carbon monoxide detector. We have one on the main floor and one in our basement.
A defective gas floor furnace in a home in a neighboring town 2 days ago put three children and two adults to sleep during the day and a 64 year-old man died of the fumes. The others are recovering but are all hospitalized. The family moved to Clay, WV from New Mexico only a week ago.
Dec 28, 2008 | GE Spectra JGBP30 Gas Kitchen Range
Oven temp
You could have a weak oven ignitor. If it has a "glowbar" style ignitor they get weak after while and will light once or twice nd then wont be drawing enough energy to open the gas valve on subsequent attempts. You can check only with a clamp on amp meter. If under 3 ampa replace the ignitor.
Apr 12, 2008 | GE Spectra JGBP30 Gas Kitchen Range
GE Spectra Oven won't heat
i would def try to replace the bake ignitor. most common problem on any gas range. part problbly $75, $250 for someone to install one
Feb 28, 2008 | GE Spectra JGBP30 Gas Kitchen Range
Oven and Broiled will not light - GE JGBP30 oven
I think it was the 'Guest' who commented on this and we just exchanged information again.
You can read it here:
GE Oven-Broiler problems
Feb 08, 2008 | GE Spectra JGBP30 Gas Kitchen Range
Gas GE Range
need to replace ignightor in oven
Dec 30, 2007 | GE Spectra JGBP30 Gas Kitchen Range
GE Profile Gas oven igniters
  If it is also a round ignitor it's the same.
Oct 24, 2007 | GE Spectra JGBP30 Gas Kitchen Range
The oven won't light, it is a gas oven. The top (broiler) lights but the oven won't light. Thank you.
Chances are the oven ignitor will need to be replaced.  Look and see if it glows.  If it does then it is weak and not opening the gas valve to lite.  Let me know what you find.
Oct 20, 2007 | GE Spectra JGBP30 Gas Kitchen Range
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
173 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
