Question about Sony FD Trinitron KD-30XS955 30" TV
I TURN MY TV ON BUT IT WNT IT BLINKS ABOUT 7 TIMES BUT NO PICTURE
  • 4234 Answers
SOURCE: SONY WEGA KV-36HS420 will not come on
The blinking is an indication that the set detected a problem. The code usually indicates a bad regulator circuit. If yu can solder, you can probably fix this your self. Please let me know if you wish to attempt the repair. If not, expect a parts cost in the $25-$40 range plus the local labor rate for the repair.
Posted on Oct 01, 2008
welcomejee
  • 10594 Answers
SOURCE: Sony Vega Service Codes
KV-32HS510 and KV-27HS420, seven times blink error code shows problem in Horizontal deflection circuit.
There are many possibilities like dry solder joints, weak capacitors, Horizontal transistor short or flyback transformer fried etc.
If you have little experience of TV repair and good solder skills and have necessary tools to test / check defective parts, then you can make it. you also need to have related service manual to see board location, schematics and part numbers.
Posted on Dec 12, 2008
SUPERMAN_B_1
  • 294 Answers
SOURCE: KD34XBR960- NO PICTURE blinks 7 times. Thanks
Horizontal Deflection
Stopped
7 times 7:0 or 7:1 • No picture
Horizontal Defl ection Stopped
Occurs when either:
1) a +B overcurrent is detected (IC5007), or
2) overheating is detected (Thermistor TH5002).
IF YOU WANT TO DOWN LOAD A FREE SERVICE MANUAL OR TECH MANUAL FOR YOUR T.V. HERE IS A SIGHT THATS TOTALY FREE
http://www.schematicsforfree.com/archive/dir/Sony/Video
Posted on Apr 13, 2009
rulds2008
  • 3866 Answers
SOURCE: tv turns on then off, stand by timer light blinks 4 times
You need to replace the power supply unit on this as it has malfuctioned there about $90 bucks plus labor on that.
Posted on May 25, 2009
rylee_smith
  • 8619 Answers
SOURCE: standby light blinks 7 times and tv will not turn
Thanks for using FixYa. Standby light blinking 7 times means high voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. You’ll need to check power supply regulation and horizontal circuits. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Mar 12, 2010
No picture. TV blinks 8 times
I have come across 6 blinks; 7 blink and even 10 blinks.
the video below may throw some light. Not sure if the blink codes are universal across models. Panasonic plasma tv 7 red blinks of *****
Apr 02, 2016 | Panasonic Viera TC-P65S1 65 in. HDTV...
Sony trinitron 36" has 7 red blinks wont turn on
I HAVE A SONY TRINITRON KV-36HS510. IM HAVING A PROBLEM,ITS NOT SHOWING A PIC, AND BLINKING 7 TIMES THEN PAUSE FOR A COUPLE OF SECONDS THEN IT WILL BLINK 7 MORE TIMES,I CAN HEAR AUDIO BUT CANNOT SEE PIC. COULD YOU PLEASE HELP ME OUT ,I'VE TRIED CUTTING THE TV OFF FOR ABOUT 6 HOURS AND CUTTING IT BACK ON,SAME RESULTS, THANKS
Jan 02, 2011 | Sony FD Trinitron WEGA KV-36HS510 36" TV
KV-40XBR700, won't come on, standby light blinks 7 times.
sony KV40XBR700 tv no picture but sound is on, standby light blinks 6 times
Jul 20, 2009 | Sony KV-40XBR700 40" TV
TV shuts itself off..red light blinks 7 times.
the only way is by bringing to a tech.i think there is no need fro self-fixing with problems like this.try tapping the tv several times then turn it on.
May 28, 2009 | Televison & Video
Stopped
Occurs when either:
Apr 13, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
The 7 blinks usually indicates a high voltage shutdown situation. Without the specific model, I can;t give you details about parts etc. The options are a defective flyback transformer or problem with the voltage regulation circuits. Please update this with the model number and I'll post additional details as soon as I can.
Thanks,
Dan
Jan 30, 2009 | Televison & Video
Sony projecting tv kp-57wv700
Based on service manual info, it cant blinks 7 times as per symptoms, please count again blinks. It can be 5 times.
If its 7 times blink, Horizontal Deflection stopped in this case. If you want to repair it at your own, please let me know to guide you further but it is necessary you should have knowledge of electronics.
Aug 18, 2008 | Sony KP-57WV600 57" Rear Projection...
No picture red light blinks 7 times
in this model is commom that the convergence ic.s go bad and stop the set from turn on check for a couple of fuses that are in convergence board if is blow replace convergence ic
Feb 01, 2008 | Sony KP-53HS10 TV
Blinking Standby Light
KV32hs500 tv won't turn on. Standby light blinks 7 times, stops and then 7 more times, etc.. The tv will usually come on after about 2 hours or so of being off. Plays fine when on but once it gets turned off the problem happens again. Any suggestions? T.V. is 5 years old.
I have a similar problem . mine blinks 6 times or 7 sometimes also,and comes on with sound ,no picture for about 2 seconds then shuts off. Anything?
Jan 31, 2008 | Televison & Video
Open Questions:
I have a SONY KD-30XS955 that I purchased in June of 2005. About two weeks ago I started to experience problems getting the TV to "light" or completely power on. In the past when I experienced this problem, I would simply unplug the set for about a minute, plug it in again and the set would power up completely. Problem solved. Recently, however, I found that this remedy no longer works. After I turn the power on, following the initial "click" of the power being engaged, there is a secondary click, followed by the "Stand By / Timer" red light on the front blink 7 times rapidly in succession and then repeating. Since the problem first occurred, I have been in touch with SONY customer care as well as their parts and accessories department. The most helpful of their techs seemed 90% sure that either the Thermistor or Capacitor (or both) needed replacing. However, since that day the TV has worked intermittently with no problems. Some days it would work fine and light while others it would not light at all. I'm aware that the 7 blinks denotes a High Voltage Shutdown. I live in a high rise in NYC, where for the past two weeks the weather has been extremely hot and humid. So much so that there have been rumors of Con Edison using brown outs to protect the power grid from overload. So I guess my first question would be is it possible that the TV is unable to draw enough voltage to light or power on since it has worked several times since I first encountered the problem two weeks back? Because a service call is $100 just to show up and diagnos the problem, I am reluctant to place one if this indeed might be the case. However, I have been very happy with the TV thus far and would be willing to have it repaired should the total cost be reasonable and it is indeed worth saving. A few people have suggested to me getting a power booster or even a special power strip which would regulate the voltage. Are these indeed options or is a service call the best remedy in this case? Any help, suggestions or advice you can provide will be greatly appreciated. Thank you for your time, insight and expertise...
Feb 27, 2017 | Sony FD Trinitron KD-30XS955 30" TV
See all Sony FD Trinitron KD-30XS955 30" TV Questions
Sony FD Trinitron KD-30XS955 30" TV Logo
150 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
