Question about Whirlpool GS6NBEXR Side by Side Refrigerator
Knocks when cuts in and out
Compressor knocks when cuts in same when cuts out
  • Whirlpool Master
  • 1,606 Answers
The internal motor support springs are broken or rusted inside the sealed compressor . The only way to stop the noise , is to replace the compressor . The noise , doesn't mean that the compressor will go out , only be noisey untl compressor or refrig , is replaced . Could be used as a good garage box .
Posted on Sep 26, 2009
I have a 91 camaro rs with 305 it starts but it has a knock in the front of the engine and if it stays running it starts to screech every couple of revolutions any ideas as to what might be going on? It...
The screeching you speak of, does it sound like the belt slipping? Does this car have A/C? To me it sounds like the A/C compressor may be trying to lock up which in turn means that its low of charge. Try to pin point the knocking noise using a cut off broom handle. Hold one side to the A/C compressor, alternator, water pump, etc, and hold the other side up to your ear (careful not to get the handle hung up in any moving parts). When you locate the knocking noise you will be able to hear it clearly through the handle. If you're still not sure if you found it or not keep trying something else until you are sure you found the origination of the knocking. Let me know how it goes. Good Luck.
Sep 02, 2011 | 1991 Chevrolet Camaro
My refrigeratro makes a knocking noise and it is getting more frequent and louder. What causes this?
The knocking noise will be from the compressor in the back of the fridge. It is a (typically) black object a little smaller than a soccer ball, situated at the bottom of the unit in the rear). It will have pipes connecting it to the hear exchanger (a black radiator that covers most of the rear of the fridge). The knocking will happen when the fridge is in a cooling cycle and the compressor is running.
There are 2 reasons for the compressor to "knock":
1) It is positioned on rubber mounts and one of these may have become dislodged if the fridge was moved recently. Or one or more of the mounts may be worn, or the compressor may have been slightly moved by something and is knocking on another component or the chassis of the fridge. It may be simple enough to check this out and move the compressor on its mountings slightly to aviod the knocking.
2) Far worse, the knocking may be from an internal component in the compressor. Sadly, this is a sealed unit and while it is possible for a professional to replace the compressor and then re-gas the fridge (Re-fill the coolant gas that will escape when the compressor is removed), the cost of doinf this will probably mean that the fridge is beyond economical repair.
Aug 30, 2011 | Amana ABB1927DE Bottom Freezer...
Compress is making a loud noise.. What could it b
Check that the air inlet filter is intact and tight, it cuts out a lot of the compressor noise. If that is in order, and you have a knocking noise, check the oil, if that is low, it is unfortunately already too late, the rod bearing is probably destroyed.
Mar 14, 2011 | Air Tools & Compressors
Knocking sounds like something is knocking on the door
Hi
The knocking could be the damper if it last for about 5 seconds when the compressor turns on or off, or it can also be the refrigerant gassing off in the evaporator this sound can be really intermittent, but is normal with the refrigerants used today. However the compressor you see is actually the outer shell, inside of which is a refrigerant pump (i.e.: compressor) which is on internal support springs. When the unit turns off, the momentum of the internal parts can sometimes knock against the outside of the compressor case. The only "fix" would be a new compressor. However this does not actually indicates compressor failure and most likely will run many more years with no problem.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Jan 03, 2011 | Refrigerators
Only when my whirlpool refrigeratior stops running, the compressor makes a knocking noise. If I push the compressor slightly with my hand, it makes the same noise and the mounting bolts are tight. What...
Good day,
The motor and pump inside the housing are mounted on 4 springs to cut down on vibration.
One or more of the springs has broken, allowing the internal unit to flop around, hitting the sides of the case.
There is no repair possible except replacing the compressor.
Oddly, the compressor may run a long time in that condition, but it will ultimately fail.
Oct 22, 2010 | Whirlpool ET1MTKXKQ White 20.9 Cu. Ft....
Fridge working off/on
If the noise was coming from the compressor when it was cutting off or starting, it was the internal mounts of the compressor and the compressor will have to be replaced. If the noise was a fan, it may have stopped. One is in the freezer behind the rear cover and one is underneath where the compressor is behind the cardboard cover.
Dec 31, 2009 | Whirlpool ED2FHSS Side by Side...
Refrigerator knocking noise
If it seems to be coming from underneath the unit it could be the compressor. Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} That's usually mounts inside the compressor. Usually when the compressor cuts off. It could still last awhile so if you can put up with the noise just wait for it to quit before replacing the compressor or getting a new fridge.
Any other noise would be from a fan. One in the freezer behind the back panel and one under the unit where the compressor is.
Dec 29, 2009 | GE Profile Stainless Bottom-Freezer...
When the compressor (thermostat?) shuts off, it makes a very loud noise. Freezer and refrigerated area are keeping things cold just fine. Refrigerator is 12 years old.
The compressor has 3 or 4 internal motor support springs . Over time , one can rust , due to the contaminates in the refrigerant system . One of them can break free , which will not cause any damage , other than a clunk , when the compressor cuts off . You can still have many years of correct cooling , only the noise will be present .
Nov 19, 2009 | Refrigerators
Whirlpool fridge incessant buzzing
The knocking noise when cuts off , is a compressor internal motor support spring , broken . This does not mean the compressor is bad , only noisy for the rest of the compressor life , but should be covered under the 5 yr warranty . The gurgling sound is the refrigerant being pumped thru the system . The buzzing could be from the compressor also . My suggestion , would be to call a factory warranty company , to see if they can replace the compressor under warranty .
Sep 07, 2009 | Refrigerators
Knocking noise
If it knocks when the compressor cuts on or off, That's usually mounts inside the compressor. It could still last awhile so if you can put up with the noise just wait for it to quit before replacing the compressor or getting a new fridge.
Aug 13, 2009 | KitchenAid Architect KBRA20ERSS Bottom...
Whirlpool GS6NBEXR Side by Side Refrigerator Logo
126 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
