Question about Amana DLE330RAW Electric Dryer
Dle330raw not heating.replaced heating element was working on time dry then stopped, replaced thermostate. no heat at all now.
  • Amana Master
  • 7,482 Answers
Check your blower, it may not be blowing hot air to your drum..You did not say if it was blowing or not.
Posted on Sep 26, 2009
Three of the four stove stop heating elements thermostate doesnt work. It is either on fully or have to turn off to manage heat. remedy ?
Hi, You will have to replace the switch with a new one. That is all that is needed . Good luck.
Jan 12, 2016 | Dryers
Heat problem
Sound like thermostat is not working. Should turn off heating elements when drying temp. is reached.
Jan 20, 2014 | Bosch Nexxt WTMC 3300 Electric Dryer
It is not heating up
There could be a couple of problems. First, ensure the vent line is clear. If it is stopped up, this will cause the dryer to go out on overtemp and will not dry your clothes. Second, the overtemp sensor could be bad and not letting your heater element to energize. And third, your heating element could be shot. I have attached a link to Amana's owner manual for your dryer.
http://shop.amana.com/assets/pdfs/literature/40119701.PDF
Jul 17, 2010 | Amana DLE330RAW Electric Dryer
Super capacity Amana dryer is less than 3 years old. It no longer dries the clothes. There is no heat.
check your heating element in the back of the unit for breaks, if there is not heat that is your problem. the other issue can be a fuse that blew not letting power get to the heating element but the easiest and cheapest thing to look at first is the heating element
Jan 10, 2010 | Amana DLE330RAW Electric Dryer
My dryer doesnt dry. I believe it is the heating element. only cold air is coming out
To replace coil, unplug and take off the back. Might have to remove heat shroud to get at coil. Remove and replace. You might have bad contacts on relay switch so play with them first and plug it back in to try it. If it doesn't work then do first step
Jun 29, 2009 | Amana DLE330RAW Electric Dryer
I have a Amana DLE330RAW everything works, but it won't heat?
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Jun 13, 2009 | Amana DLE330RAW Electric Dryer
Heating element
What did the original heater look like when you removed it? Was it burned in two? Make sure you are getting air circulation over the heater. Check your lint filter and air exhaust piping. Flapper outside on the exhaust pipe may be sticking.
May 28, 2008 | Amana DLE330RAW Electric Dryer
Amana DLE330RAW
send me an email at b4829@yahoo.com and ill give you step by step but dont forget my four boxes here it helps my rating just ref your dryer in the e mail
Mar 28, 2008 | Amana DLE330RAW Electric Dryer
No Heat
more than likely that u have blown heater element u can test your element with a power cord connect it to the live earth and neutral and plug it in and element should heat up if not it will be your element that has blown
Dec 29, 2006 | Hotpoint TDC32 Electric Dryer
Amana DLE330RAW Electric Dryer Logo
149 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you an Amana Dryer Expert? Answer questions, earn points and help others
