When clicking on aa a channel I get this disply
When clicking on aa a channel I get this disply on my screen(.no signal,) then it says to run a( channel scan) . I did run a scan several times, still no help
  • 8,457 Answers
U use free air signal right?Get a digital antena or a roof antena,get a better repcetions,an signal in put coming in.
Posted on Sep 26, 2009
Replaced batteries, outsid temp. does not display
Base Station Battery Installation
·Remove the printed vinyl label from the LCD screen of the base station
·Position the remote sensor near the base station
·Open the battery compartment at the back of the base station and insert (2) AA batteries according to the polarity markings. Replace the battery compartment cover.
·Within a short time the RF signal icon (located to the left of the outdoor temperature channel indicator) will start flashing. This indicates that the base station is ready to pick up the RF outdoor temperature signal from the remote sensor. It will continue to flash for 3 minutes or until the signal from the remote sensor is detected.
Register the Remote Sensor
·Open the battery compartment at the back of the remote sensor and slide the channel selector switch to your desired channel. For the first remote you may select any channel, for additional remotes select any unused channel
·Insert (2) AAA batteries according to the polarity markings. Be sure to install the batteries in the remote within the time that the RF signal icon is flashing on the base station.
1541 WeatherGuide Wireless Weather Forecaster with Barometer
Jan 05, 2016 | Taylor Measuring Tools & Sensors
WHEN I PLUG INTO ANTENNAE--I GET " NO SIGNAL"---BUT I KNOW THAT THERE IS A SIGNAL BECAUSE I GET A PERFECT PICTURE ON MY SONY COLOR TV? HOW CAN I GET THE OLEVIA TO RECOGNIZE THE ANTENNAE SIGNAL?
You'll need to use the Olevia remote and press the MENU or SETTINGS button. The choose the SETUP or MEMORIZE CHANNELS option. MEMORIZE CHANNELS may be in an ANTENNA screen.
When you memorize channels you'll need to set the option for Antenna or Cable TV then have it memorize channels.
The television will run through each channel looking for signal and memorize those it finds. Sometimes it finds a very weak signal and you'll need to manually remove some.
Oct 04, 2015 | Sony Televison & Video
All i have KEB F5 inverter with profibus disply card.can any body tell me how can i run this inver without profibus signal.i want run this inverter with keypad on my working table
There are many different ways to run the inverters without ProfiBus.
You must first determine what signals are being provided by ProfiBuss and determine the best way to replace these signals.
Jan 10, 2014 | Inverter KEB COMBIVERT F5
Blank screen for wind --- new batteries in everything
Did you press the reset on the solar transmitter after you replaced the batteries? It is left of the NiCAD pack if the AA batteries are on the right. If after pressing reset, and you are using a WMR 938, and still not receiving, press and hold the "channel" button for 5 seconds on your monitor to re-register the signal from the transmitter.
Dec 06, 2013 | Oregon Scientific STR938 Solar...
Display says please run auto channel scan
It sounds like it is not seeing any signal. Do you have the input set for the proper type? Air or Cable
Check your RF connection to ensure you have a signal coming into your television.
Nov 16, 2013 | AOC L22W898 22 in. LCD TV
Cannot change channel on my Dynex DX-L26-10a TV
Try checking the signal strength then run the scan again.
Checking the DTV signal strength
You can check the DTV signal strength to determine if you need to adjust your antenna or digital cable input. The higher the signal strength, the less likely you are to experience picture degradation.To check the DTV signal strength:
1.Press MENU. The on-screen menu opens.
2.Press < or > to highlight Channel, then press v. The Channel menu opens. The DTV signal strength is shown at the bottom of the menu.
3.Press EXIT to close the menu.
Oct 26, 2012 | Dell Vostro 200 PC Desktop
Hi there. I'm getting a "Please run channel auto scan" message on my Insignia flat screen. Please advise.
I am assuming this is your first digital television. Unlike the old analog television digital televisions
must have the channels scanned into the set. This what you have to do.
> Connect the signal source to the back. Antenna/Cable/Satellite.
(You may have already done the above step.)
> Go into the menu for the signal input source and set it to what was set on the back of the set.
> Click on scan or channel or whatever it's called and wait for it to search for available channels.
> Save the channels found.
You may exit menu and watch television.
The owner's manual gives this and more information.
Feb 16, 2011 | Insignia LCDTV26 26 in. Television
I live in Pretoria South Africa using Windows 7 I have installed the drivers for DVB S 100 however I cannot find signal scanning with Media center and my Theater please help
Follow this steps and try
in windows 7
On the start screen, scroll to Tasks, click settings, click TV, and then click Set Up TV Signal.
Follow the steps to connect a TV signal, depending on the type of tuner or tuners that the cable is connected to
else try
The Windows Media Center TV Pack has an "Auto Select" option which removes channels that have a weak signal from the EPG. To run the "Auto Select" option to check the list of available channels and to evaluate the signal strength for each channel, follow these steps:
  1. Start Windows Media Center.
  2. In the Start window, scroll to Tasks, click Settings, and then click TV.
  3. Click Guide.
  4. Click Edit Channels.
  5. Click Auto Select.
The "Auto Select" option tests each channel. Based on whether a strong or a weak signal is found, the "Auto Select" option puts a check mark in the box next to the channel. As soon as the detection process is complete, you have to click the "Save" option to save the newly selected channels to the EPG.
esle if the problem still persists
have a look aon the microsofts support in the following link
http://support.microsoft.com/kb/955485/en-us
Feb 19, 2010 | KWorld DVB-S 100 (DVBS100) Video Capture
Viore 7 tv no picture and tv disply
it is possibly you have put it into Cable mode or Video mode or even channel 3. also check and see if the remote has vcr/tv or tv/video you might have pressed this and that is why your tv is blank.
Feb 11, 2010 | Televison & Video
My 32" Philips CRT tv turns on fine, but seconds after, the screen - not the tv itself - turns off. I can get it back by changing the channel, and then changing back to 3 (my cable signal runs through the...
You need the Horizontal timing kit installed in this tv. Ask a tech to install part# 4835 310 57673. You have tv chassis# L04.1U AA...correct? Look on the rear of your TV. This will repair!
Oct 18, 2009 | Philips 32PT6441/37 32" TV
Televison & Video Logo
66 people viewed this question
Top Televison & Video Experts
