Question about Stiebel Eltron TEMPRA 24 Tankless Water Heater
No green light on, power gets to unit but no light or red light and no hot water. Thanx. Rob
  • 117 Answers
Did you dry fire it and burn out the fuse?
Posted on Oct 03, 2009
One of my poer sources is out. How can I fix it??
I am not familiar with your unit but I believe it has 3 12 Kw heaters. I would guess one of them has failed or the relay powering it has.
Feb 04, 2014 | Stiebel Eltron Tempra 36 Whole House...
Atwood water heater electronic ignition
Copy following link for possible troubleshoot resources:
http://waterheatertimer.org/Atwood-water-heater-resources.html
Might want to call service technician instead of messing with gas appliance.
Or sent to service center.
Install 20 gallon under counter electric water heater and connect to 120Volt... 1500 watt element will heat water pretty quickly. To have more hot available, turn up water heater thermostat, then that will give 2 showers because more cold will be added to very hot water, thereby stretching amount of available hot..
http://waterheatertimer.org/How-to-install-under-counter-water-heater.html
Add a comment as needed
Jun 02, 2013 | Water Heaters
No hot water,power to the units but red power lights are not on and reset buttons are not poped
Add a comment with clear description of model, brand and type of water heater, and include approx age of installation.
Oct 13, 2012 | Water Heaters
Rheem rte13 standby (green) light not on
You might have crossover problem caused by bad faucet cartridge.
http://waterheatertimer.org/Crossover.html
The green standby light should come on when 240Volt power is applied. Page 6 manual.
Both red lights should come on when tankless is activated. Page 6 manual
RTE 13 requires 60 amp breaker and 6 gauge wire
http://waterheatertimer.org/How-to-wire-Tankless-electric-water-heater.html
http://waterheatertimer.org/pdf/Rheem-TanklessElectricUC_AP15447.pdf
Factory temperature setting is usually default 120 degrees.
Adjust temps page 11 manual
Thermostat calibration is always approximate.
120 degrees is not hot enough to burn the skin.
Exceptionally cold incoming water temperature can cause tankless not to heat enough hot water: install tempering tank to preheat water to room temperature.
Tankless cannot be exposed to more than 11 grains hardness in water. Delime tankless yearly, clean water filter monthly, do not install low-flow restrictions or conserve water since the flow rate must remain high for tankless to activate.
Rheem does not post service manuals for their tankless water heaters.
Call Rheem 800 432-8373
Aug 05, 2012 | Rheem Tankless Hot Water Heater...
Where is the thermostat located on a rheem fury 81v52s ?
Hi, The thermostat on most hot water heaters is part of the gas control unit.
if you disconnect the wiring on an electric unit or the piping on a gas unit the whole controller should screw out. Make sure that the electrical power is off, gas **** is closed and water tank is empty.
Hope this helps.
Rob
Oct 07, 2011 | Rheem Water Heaters
Gas works fine -gets hot water. But electric will not give hot water, only cold. How do you remove the heating element? It is on the inside of trailer in a black box? Model GC6AA-10E Atwood.
I'm thinking when you say black box, that you also have a wall switch with a symbol like a lightning bolt and you switch that on as well as checked breaker panel to make sure breaker is on as well.
With that said, you'll have 2 of 3/8" nuts holding that black cover on. Remove top one and loosen bottom one and pull cover off. ( Be sure power is off to unit while doing this.) You'll find the element in behind it. Put a voltmeter on black to element (red probe or alligator clip) and (black probe) to ground where you see green wire connected to tank. Turn breaker on then switch at wall. You should hear a relay click and 120 Volts should show at black wire ( red probe) . If you've got 120 volts there, shut off all power, drain water heater and replace element.
Jul 04, 2011 | RTO Atwood Water Heater - 6 Gal LP
The unit is no longer heating the water. The red light comes on indicating that the unit is heating the water, but only cold water comes out of the faucet. We've tried raising and lowering the...
This will be a thermostat or element problem. The red light tells us that you have power to the unit. If you are handy you can test the thermostat and the element with a continuity tester. A voltmeter may also be used. This will tell you where the fault lies.
Mar 06, 2011 | Stiebel Eltron Tempra 24 Electric Hot...
My hot water heater has a red and a black wire,but the electric supply wires coming in to power the water heater have a red,black white and a bare ground. Which wires go where?
Your 220v hot water heater does not need the neutral(white) wire coming in. Bare wire goes to ground -green headed screw. Black goes to black, Red goes to red. White gets teminated with a wirenut or some electrical tape.
Jan 24, 2010 | Rheem 80 GAL ELEC TALL Water Heater 6YR SC...
I have a digistat scr with a flashing red light and no heating there is nothing wrong with the batteries, this only occured after a poweer cut.
Try this first before condeming the unit.
1. Turn off the power supply to the Digistat SCR (receiver unit)
and leave for 5 seconds.
2. Turn on power to SCR unit and check red light is on.
3. Press override button No.2 and check the green light comes
on and boiler fires.
4. Press & hold down button No.1 (Keep depressed), then
press No.2 and keep depressed. {The Red LED light will flash
a couple of times and then it will go out}
5. Now release both the buttons – {the two LED lights should
come back on}
6. Get the Digistat+2RF/+3RF unit and stand two metres away
from the SCR unit with the Digistat+2RF/+3RF unit in your hand.
7. Remove the battery cover and fit the batteries.
8. The Red LED light on the SCR will now flash for approx. 7
seconds.
9. This confirms that the radio signal is being sent and
received.
10. The Digistat+2RF/+3RF and the SCR are now successfully
linked by a dedicated RF address.
Mar 21, 2009 | Water Heaters
Water heats for about 3 seconds and goes cold
Take the cover off and look for reset that has trip.If you can't find no reset turn the power off and wait for five minutes,turn on and turn water on also to see if you get hot water.
Mar 14, 2009 | TitanNet TITANTANKLESS. COM PRESENTS THE...
Stiebel Eltron TEMPRA 24 Tankless Water Heater Logo
494 people viewed this question
Top Stiebel Eltron Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Stiebel Eltron Water Heater Expert? Answer questions, earn points and help others
