Question about Dell Latitude D600 Notebook
All lights come on and the hard drive runs for a short time. no monitor activity.
  • Dell Master
  • 1,606 Answers
This may be a display problem. Let it boot and in a fairly bright room look at the screen from a few angles if you see a ghost image then the problem is your back light has failed. It is possible your video display is the problem. To test that you need to connect your laptop to an external monitor and see if you get a picture then. If you get a picture then it is probably your back light if you don't your video display which is a more serious problem.
LCD's work sort of like a projector where the lcd forms the image and the back light shines through so you can see it. So if the back light fails the image is still there but hard to see. There are several places that can repair this for about $120-$150. It is a repair you can do if you have some technical ability. You can order the parts from several places and they usually have online guides available. Have a look at them before you order to be sure you are up to it.
Posted on Sep 26, 2009
I have problems in sarting up my EI System laptop ,the power light is on but no display on screen
The power light will only show whether power is reaching the machine. The important light is the hard drive activity light and perhaps the wireless activity light.
If the power light is all you have you should take your laptop to the computer doctor but if the hard drive light shows activity it would be worth connecting it to a separate monitor and if it then produces a display you might be able to figure out what has happened.
Sep 19, 2016 | Computers & Internet
Asus k55a will not turn on. Power light comes on, fan comes on. No hard drive noise or any other light. Running windows 8.1
Take it back to where you bought it and ask them to check the Power Pak. But it sounds like the Hard drive has bit the dust.
Feb 02, 2015 | ASUS Computers & Internet
A885GM-A2 new mother board will not boot up screen
You are missing the driver for the monitor. It should have come up but sometimes all the drivers are not or do not activate. If you have a disc for it run it and try to activate the monitor. It could also be the type of hook up you have. Make sure the cable is connected in the right port and that it compatible with your monitor. Might try the user friendly controls on the monitor. Make sure the contrast or black and white settings are not blacking the monitor out. Then there is always the possibility that you have a bad MB. Everything can work and it have a bad monitor driver as a matter of fact I have seen a lot of new and especially refurbished boards that were missing drivers. Also if you have the disc for the monitor you may have to run it again and it should program itself to the MB. Sometimes that has to be done. I have two monitors an Acer and a Dell and every time I have a hard drive go out I have to reprogram the Dell monitor. Try these things and let me know what results you get.
Later-
z
Mar 17, 2014 | EliteGroup ECS A885GM-A2 (V1.1) AM3 AMD...
OS Maverick very slow after time capsule backup
Use the App "Activity Monitor" to see what process is driving hard. if not already open: open the activity monitor window. Click the CPU% tab and show highest percentages at the top (should be an upside down triangle) may have to click the CPU% twice to do this. now the Activity monitor is showing you what processes are eating up your computers power. Google the process/es . It may be indexing the drive, which can take a long time. there are other processes too, that you should just let it do. once they are done, then things should be good. Such is the case for me when I upgraded to Mavericks.
Nov 19, 2013 | Apple iMac Computers & Internet
Monitor lamps keep blinking although the modem line works fine and hard reset cannot help.
The lights will blink indicating activity. Much like your HDD, DVD/CD drive light blinks with activity. Correct me if I am not understanding your question, "monitor lamps". Has this been happening for a long time, just started? How many years have you had the wireless access point? If you reboot the device does it complete the self-test?
Nov 15, 2012 | Cisco RVL200 Router
Machine wont boot
There is your answer no power to the monitor. Make sure it is plugged in replace with another monitor if you cannot get the button on the monitor to power on the unit. Maybe time for another monitor. John
Apr 20, 2012 | Dell XPS 210 PC Desktop
My nec p9120 has power to it and the wi-fi is on but the fan and everything else is not running and my lcd screen stays black
Try connecting to an external monitor and see if that works. Is the hard drive activity light flashing at all?
Mar 20, 2012 | NEC Computers & Internet
Hello, I have a HP 22w LCD monitor, running
Can you try the monitor on another computer? Also, make sure the cable is tight on the monitor side. And you also may need to replace the cable between the monitor and the computer.
Jun 13, 2009 | HP dx2300 Monitor Personal computer Intel...
Compaq Presario SR1030NX fails to start
Sounds like the power supply or motherboard is biting the dust. U may consider power off, open case and clean out the dirt, check U'r connections and if the power supply smells, replace it.
Else replace the pc. When the power supply dies, it usually stresses the motherboard out and it dies later, sooner.
Jun 02, 2008 | Compaq Presario SR1030NX (DW256A#ABA) PC...
Power edge 2600 sever shows problem
i replaced one of the hard drives in my poweredge. how do i get it to copy from the good hard drive?
Jan 28, 2008 | Dell PowerEdge 2600 Server
Dell Latitude D600 Notebook Logo
79 people viewed this question
Alun Cox
