Question about Kenmore 3.2 cu. ft. Plus Top Load Washer
Water leaks out from the bottom right front corner of my washing machine model # 110 24692300 where is coming from?
  • 5,911 Answers
You will need to remove the exterior casing of the washer to access the interior and determine where the leak may be coming from. Follow these steps:
1. Unplug washing machine.
2. Remove console. This can be accomplished in one of two ways depending on which type of console you have.
a. If the console has removable end caps, the caps lift off by prying on the top from the back of the washer. The cap will pull off towards you as you are facing the unit from the front of the washer. There will be a screw under each end cap that you will need to remove.
b. If the console does not have removable end caps, you will need to slide a putty knife under the front corner of each side and push in while lifting up. There is a retaining clip under each side that has to be released.
3. Once the console has been released it will lift up and fold back over the back of the washer in its resting position. Use care not to stress the small plastic hinges that hold it on. They can break easily.
4. Under the console will be two large brass colored clips. Take a large flat blade screwdriver and place it in the groove of the clip on the washer top. With the screwdriver firmly in the groove, push away from you towards the back of the washer. This will release the clips.
5. Disconnect the lid switch connector plug. This is the white colored plug on the washer top under the console.
6. Remove the washer casing. Open the lid of the washer. Using one hand, grip under the front rim of the washer opening. Do not grab the wash tub, just the casing. Tilt the washer case from the back first towards you, slide forward slightly, and then lift up. The entire case comes off exposing the wash tub and components.
If the leak is coming from the front of the washer, most commonly this is caused by a leaking drain pump. The pump is located in the front directly below the wash tub. The pump is not serviceable and must be replaced if it is damaged.
Some other items to consider:
1. Check your fill hoses to ensure they are tight and not leaking. What can often appear as a washer problem, may be a loose hose.
2. With the washer case removed, check the area UNDER the wash tub. If the leak is coming from the center above the transmission, the tub seal may be leaking.
3. Inspect the wash tub for any cracks. If the tub is cracked and its not serious, you may be able to get by with some marine epoxy to reseal it. If the crack is significant, a new tub will be required.
4. Check the air dome on the lower right hand side of the wash tub. This is a small plastic air hose that runs from the wash tub all the way to the pressure switch. If this hose comes loose, the washer will start to leak as it fills. Simply reattach if it comes loose.
NOTE: It is important to remove the washer case in matters like this so that you can get a full view of everything to determine the source of the leak.
If you need an illustration of your washer and components, searspartsdirect.com, appliancepartspros.com, or pcappliancerepair.com usually has some excellent exploded view diagrams that you can refer to.
If you determine the pump is damaged and needs replaced, the following link explains how:
http://www.fixya.com/support/r397092-replacing_water_pump
Prices can vary between these sites so shop around for the best deal. NOTE: Use the part number from the Sears site and use it to "Search by Part Number" on the other sites. It makes it easier to find as some sites may not have your model number listed, but will still carry the part.
To reinstall the washer casing, follow these steps to ensure you get the case correctly placed and secure on the frame:
1. With the lid of the washer open, grasp case under front rim and place it on the washer frame. While looking down through the washer lid opening, make sure the front lip of the case is placed UNDER the washer frame and rocked back onto the frame to ensure that the small cleats on the frame fit into the slotted grooves on the washer case base. If you do not get the case seated correctly it will rattle and vibrate while the washer is in operation.
2. Make sure the back of the washer fits into the washer casing on each side by leaning over the front of the washer and grasping the back panel and pull towards you. Reinsert the brass clips by placing the clips into the slot on the back of the washer first, and then forcefully push then down into the opening on top of the washer.
3. REINSTALL LID SWITCH CONNECTOR. It is easy to forget. If you do not reconnect it, the washer will not work correctly.
4. Reinstall console.
Read through everything thoroughly before beginning any repairs. If you have any questions, or require additional assistance, please let me know. I hope this information is helpful.
NOTE: Kenmore is manufactured by Whirlpool, so these instructions will apply.
Posted on Sep 26, 2009
Testimonial: "GREST ADVISE THANK YOU FOR ANSWERING SO QUICKLY"
    Sergeant:
    Champion:
  • 289 Answers
Sounds like you have a bad water pump,this video should help youhttp://www.youtube.com/watch?v=WLPGs2UMUJc
Posted on Dec 26, 2009
Water is leaking from Bosch washing machine WFL2060UC. Checked the hose connections. Lots of water comes out of drain hose after one cycle and water is pooled in the pump (place where the cap is next to...
Bosch washing machine WFL2060UC This video will show you how to change the pump washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Apr 13, 2011 | Bosch Axxis WFL 2060 Front Load Washer
Leaking water on spincycle
I have the same problem with my washer. The problem just began a few weeks ago. It is splashing out the front left corner of the tub and running down the inside of washer and then leaking out the bottom of the frame. It is just enough water to be annoying. The washer is about 6 years old.
Model: FAV6800AWW
Serial: 11277017EG
Any ideas??? Help!
Jul 27, 2010 | Maytag Neptune FAV6800AW Top Load Washer
LAT 7793 ABL model number. Washer leaking during fill...? a seal or gasket but not sure how to remove the spin bars to access it
On Your washer to locate a leak, remove the front panel first. Should be two clips at the bottom of front panel, use a putty knife to pry them down while pulling lower of front panel forward (older models used two screws right through front panel on left and right sides). After getting both lower clips loose, pull bottom of front panel forward to remove from top.
Set front panel aside and then use a 3/8" socket or nut-driver to remove two screws (one each) in the front right and left corners that secure the top to the side panels of the washer (inside in front corners going upwards). After screws are removed slide machine away from the wall about 8-10" and lift front of top up. Will pivot up like the hood on a car. This will allow you to examine machine for leaks.
Let me know when you come up with leak location if you need any more help!!
Jun 30, 2010 | Maytag LAT3600A Top Load Washer
Water leaking from front right corner - not hoses
The leak is coming from the area of the drain pump, but you will need to remove the lower toe panel directly below the door to sufficiently inspect where the leak may be coming from. The access screws are located under the bottom front edge of the panel. With the screws removed, the panel will drop down, then come off. The following link explains what to look for:
http://www.fixya.com/support/r3576656-washer_leak__front_loader
Make sure you check all hose connections on the drain pump and make sure the drain pump reservior cap (if equipped) is on tight. If you have any questions, please post back with your MODEL NUMBER and let me know. I hope this helps you.
Apr 05, 2010 | Kenmore HE2 Plus Front Load Washer
Haier Washer/Dryer HWD1000 water leak from the bottom. When I turn the machine on, it starts taking water in, and then I see water leaking from the bottom..I checked the connection hoses, the door(front...
Check the button trap. Little door at front bottom right corner. There is a big screw in plug that has to be closed very tightly. Also check the plug gasket is clean.
Apr 01, 2010 | Haier HWD1000
Leaks at bottom lefthand corner when filling
On that model it's easy to unscrew the front and take it off. You can then see the hoses etc to see where the water is coming from. I had to replace the drain hose on mine.
Aug 12, 2009 | Kenmore 98702 Stacked Washer/Dryer
Water leaking inside the washing machine
you need to replace the water valve there should be 2 screws in the back bottom corner of your control panel take them out then stand in front grab each side of control and slide foward control and then pick up and lean it back then you will see a 2 clips holding you housing of your washing machine and a plug undo the clips and unplug the wire once done that grab each side of the casing and swivel it foward then slide the bottom front foward now you can access the water valve to replace it please rate
Jan 06, 2009 | Whirlpool LSN1000LW Top Load Washer
Water leaking from the bottom of the washer at the rear right corner!
firstly check that the inflow water pipes connected to the machine are connected correctly, feel around the pipes that touch the machine to see if there is any water. If there is the washers may need replacing on the pipe. Or the pipe may simply have got a bit loose through the machines spinning.
Oct 20, 2008 | GE Energy Star WCVH6260F Front Load Washer
Whirlpool front loading washing machine leaking
you will have to be nice to it as it will come out and with some fairy up liquid you can put it back so easy
Jan 02, 2008 | Hotpoint Aquarius WD63 Front Load...
Kenmore 3.2 cu. ft. Plus Top Load Washer Logo
396 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
