Question about Motorola Mobility E815
Motorola E815 alarm full
I can not edit or delete any of the alarms I have set on the E815. Tools - Alarm Clock - select from the list. All I can do is enable or disable. If I try to create a new alarm, it tells me "Alarm Clock Full". Any help on this? The manual I downloaded only mentioned the enable/disable feature. No delete or edit.
Thanks for any help you can provide.
At the alarm screen, highlight one of the alarms, then press the main menu button, several choices, including a delete option will be given. There is even a delete all option
Posted on Dec 18, 2007
Also, can't set the alarm clock on the phone.
Make sure u hv right time set.
Then go to Tools> alarm clock>new alarm> name>enter time for alarm to ring>select alarm alert tone> set volume..
NOTE: Yo handset shld be in 'Loud' ring style not silent
May 28, 2012 | Motorola Mobility RAZR V3x Cellular Phone
I can't find the alarm clock setting anywhere on my nokia surge phone! is this normal? I've searched everywhere for it, and it just doesn't make sense for there to not be such basic thing... I must have...
hiSelect > Tools > Clock To set a new alarm, open the Alarms tab, and select Options > New alarm. Enter the alarm time, select whether and when the alarm is repeated, and select Done. hope this will work. regards aniruddh
May 28, 2010 | Nokia 6790 Surge Cell Phone
How do you set the alarm clock on a motorola clutch i465?
There's an option in "Download Apps" from the "Java Apps" Menu called "Factory Preloads." Choose that option instead of the "New Purchases" option that you usually choose when installing other/new apps and it will give you a list of the default apps the phone came with. Alarm Clock Plus will be in the list.
You'll have the ability to re-download any of them, Alarm Clock Plus included. Make sure to uninstall the existing installation of Alarm Clock Plus first before doing so.
Mar 29, 2010 | Motorola Mobility Clutch i465 Cell Phone
Set all 3 alarms and they never go off. Big problem since it is my only alarm clock for work and just recently quit working have used for almost 2 yrs
You need to make sure the Ringer is enabled. Here are the instructions:
Alarm Clock
The Alarm Clock tool allows you to set up to three
alarms.
When you set an alarm, the current time is displayed.
When the alarm goes off, Alarm 1 (or 2 or 3, as
applicable) will be displayed on the LCD screen and
the alarm will sound.
1. From standby mode press the Center Select
Key c [MENU], then press the Directional Key
r right twice for SETTINGS & TOOLS, 2
Tools, 4 Alarm Clock.
2. Press the Directional Key j up or down to
highlight an Alarm (1, 2, or 3), then press the
Center Select Key c [OK].
3. Enter the alarm information including:
• On/Off
• Time
• Frequency
• Ringer
4. Press the Directional Key j up or down to
highlight the information you want to set, then
press the Left Soft Key L [Set] to view your
choices.
5. Set information and press the Center Select Key
c [OK].
6. Press the Center Select Key c [SAVE] after
setting all of the applicable Alarm Fields.
Feb 24, 2010 | Casio G'zOne Boulder Cell Phone
Alarm snooze
prees the menu button'
select the Office tools
scroll down and select the alarm clock
you can choose by pressing the right soft key
by choosing the disable the alarm clock..
Jan 08, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Razor alarm clock
Once you open alarm, select "set" for alarm 1, go to the time and change it to what ever time and click "set" again. After shut phone. I thought it was wierd that it did not confirm but It works. Let me know how it goes.
Cynthia
Nov 09, 2007 | Motorola Mobility RAZR V3
Motorola E815 alarm quit working
I've had a similar problem with alarms not going off.  In my case, it was caused by receiving a text message that was unanswered between the time that I set the alarm, and the time that it was supposed to go off.  Try reading all your text messages, deleting all messages, and then take the battery out and put it back in after a few minutes.  The last part is to reset any caching, but the first two steps followed by a turn off/turn on should also do the trick.
Oct 08, 2007 | Motorola Mobility E815
My alarm clock is full!
Yes delete them or edit them if chose or for some reason can't delete.
Feb 14, 2007 | Motorola Mobility RAZR V3
Help setting alarms
To set an alarm for an event: 1. Create a new event or double-click an existing event. 2. In the New/Edit Event dialog box, select the Alarm check box. 3. Click the time interval selector and select Minutes, Hours, or Days. 4. Type a number between 0 and 99 in the Time Measurement box. 5. Click OK. To set a default alarm for all new events: 1. From the Tools menu, choose Options. 2. In the Options dialog box, click the Date Book tab. 3. Select the Alarm Preset check box. 4. Click the time interval selector and select Minutes, Hours, or Days. 5. Type a number between 0 and 99 in the Time Measurement box. 6. Click OK. Setting Alarm Options You can configure the Alarm Manager settings for the Desktop application in the Alarm tab of the Options dialog box. To set Alarm options: 1. From the Tools menu, choose Options. 2. In the Options dialog box, click the Alarms tab and click one of the following actions: * Always available: Click this option if you want alarm notifications to appear regardless of whether the Desktop application is running. * Available only when Palm Desktop is running: Click this option if you want alarm notifications to appear only when the Desktop application is running. * Disabled: Click this option if you do not want alarm notifications to appear on your computer. 3. If you want an alarm tone to sound when the alarm notification message appears, click Play audible notification with alarm dialog. 4. Click OK.
Sep 07, 2005 | Palm Tungsten T5 - Multilingual Handheld
Motorola Mobility E815 Logo
165 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
