Question about Maytag Dryers
Maytag legacy squells like crazy, trouble gaining entry to check idler arm.
  • Maytag Master
  • 7,482 Answers
The noise you are hearing could be coming from the drum rollers needing lubricant.
If it is a front loading maching pull off the front of the machine, you can access the drum rollers to lube them or replace them and also get to the idle arm
Posted on Sep 26, 2009
When I turn my dryer on, it squells really bad...the clothes dry fine....it doesn't squell all the time, kinda comes and goes. It sounds like a belt on your car that would squell when it is getting...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Jun 29, 2011 | Dryers
Why belt keeps shredding
usually due to a bad bearing, or from resistance due to a frozen or failing assemble, as in power steering, alternator, or an idler. The best way to determine is to remove the belt and check all pulleys for play and resistance.
Feb 10, 2011 | 2000 Chevrolet Venture
ANt diagram of how the belt goes on the Maytag
pull the loop on the bottom of the tumbler once you have it warped around and hanging free
pull that loop twords the motor under the idler pully
both side of the loop
pull the loop twords the motor hub, you may need to left the idler pully to gain a liitle slack
once on the motor let go of the idler and it should tighten the belt
Oct 19, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Belt broke on Maytag dryer DE410. I purchased a
The squeak may be coming from the drum rollers, check them to see if they need lubrication.
I recommend that you use a good grade of machine oil to lube them such as 3 in One oil. Lube them at the shaft of the roller. Also check the rollers to see if they have flat spots on them, if they do then they will need to be replaced.
Recheck your location of the idler arm bracket with pulley to see that you have it in the right location and that the spring is also in the right location. Look for wear spots on the frame and idler arm and match them up.
Good Luck,
I hope this helps
Oct 12, 2009 | Maytag Dryers
The grinding (bearing) noise on "spin", now leaking rusty water under machine... 3 1/2 years old "Legacy" ??? NOT !
maytag has rear rollers and front drum glides when goes out sound like sand paper scratching, also inspect belt idler same noise
Aug 14, 2008 | Maytag Legacy Series Top Load Washer
Dryer squelles
the sound is thr support rollers or the idler pully, the support rollers located under the drum to the back the pully holds the belt tight. look for meatle shavings or rust dust on rollers.
Jul 14, 2008 | Maytag Neptune MDE4000 Electric Dryer
Dryers Logo
65 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
