Question about Kenmore Dryers
Trying to remove the fan blade from the motor without snapping it off.
  • Kenmore Master
  • 8,404 Answers
Look for a set screw ... probably allen head
I'm guessing ... I have seen fans that slip on and others that have a set screw ... there are probably other mathods too.
I hope this helps
a
Posted on Sep 26, 2009
How do i take the fan blades off of the motor that is holding it?
the retainer is in the center of the blades ( finish trim , name plate , knob etc )
it is left hand thread so make like you are doing it up and it will screw off
Oct 01, 2016 | Dryers
My fan doesn't start right away when the switch is turned on. Then as it is starting up it squeaks and hesitates. Seems like a "gunked-up" problem but I can't remove the impeller blade assembly from the...
The fan blade can be removed from the shaft. You just need to pop the lock washer off and pry the fan blade. You most likely will not be able to remove the fan blade without damaging the blade. You can buy the replacement fan blades online. The part number is 5901A000. Here is a blog on the entire replacement motor assembly. http://nutoneproducts.typepad.com/nutone-products/2009/08/nutone-0695b000-replacement-bath-fan-motor-for-model-qt80.html
Oct 05, 2009 | Broan-NuTone QT80 Fan
Aloha Breeze pedestal fan blades won't turn, but motor is humming
remove protected cover and with wd-40 or oil spray lightly behind the blade at the base oil up the bearing turn blade by hand till free put back and test the bearings get sticky from the dust
Sep 12, 2009 | Windchaser 3-way Oscillating Fan
Removing the ceiling mount from the ceiling of a hampton ceiling
Sometimes there is a small trim piece where the canopy meets the ceiling that "snaps" into place and rather than turning to unlock it needs to be gently pryed off. If you have a small trim piece that makes more than about 1/8 of a turn without unlocking. that is definately what you have.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jerry_612d8419f8984578
Sep 06, 2009 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Blades will not turn
The motor probally damaged while you are moving the fan to the new house.
Jul 06, 2009 | Casa Vieja Probe Brushed Nickel Ceiling...
Blade replacement
the lever on the clippers locates into the cutter of the clipper blade its only a matter of lining the lever up with the slot in the top blade which you can slide from side to side by hand. Please keep in mind wear on this plastic Drive Lever may lead to cutting problems.
Apr 22, 2009 | Oster 76076-010 Hair Trimmer
Blower motor location for 2000 Caravan
The motor is located just under the glove box on the passenger side. I remove the glove box then the panel below the glove box. I also go ahead and pull back the carpet and the padding under the motor. It is held in place by 3-4 bolts that take a 7-8 millimeter socket. I use a swivel extension for the back bolts. The motor with the fan blade attached is a tight fit, just keep wiggling and pulling it should come out. Try to remove the old moter without cracking the fan blade, because sometimes the replacement motor doesn't come with a blade
Sep 17, 2008 | 2000 Dodge Caravan
Blade is loose
on the inner part of the motor [fan side] look for an external snap ring and a fiber spacer. the armature fits all the way into the rear part of the housing, the other housing goes over the motor shaft and must press against the snap ring and fiber washer.
Sep 03, 2007 | Vornado Circulating Fan
Dryers Logo
37 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
