Question about Sony DSC-T70 Digital Camera
How is cover removed to replace battery box? - Sony DSC-T70 Digital Camera
Battery cover remove
Remove seat. Disconnect battery. Undo two bolts at rear of battery box. Push down on Left side of box(rear of box). Slide out top plate. Pull box out and up. Hope that helps.
Apr 30, 2014 | 2002 Harley Davidson FXD Dyna Super Glide
Where is the computer box located in a 97 avallon
Instructions
    • 1
      Remove the battery cover to access the battery terminals. Disconnect the negative (-) battery cable with the pliers.
    • 2
      Open the glove box door and squeeze the outer part to remove the door. Locate the two screws behind the door to remove the glove box.
    • Sponsored Links
    • 3
      Access the ECU behind the glove box. Remove the electrical connectors by hand; remove the bolts mounting the ECU to the inner dash.
    • 4
      Install the new ECU in the same position. Replace the bolts and reconnect the electrical connectors.
    • 5
      Replace the glove box and the glove box door. Reconnect your battery.
Sponsored Links
Read more: How to Replace a Toyota Avalon ECU ' eHow.com http://www.ehow.com/how_6170111_replace-toyota-avalon-ecu.html#ixzz289jiGlka
Oct 02, 2012 | Toyota Avalon Cars & Trucks
How to change the battery
Remove the battery box compartment cover. Disconnect the positive and negative battery leads. Undo the battery holding down clamp screws and remove the battery clamp, now you can lift out the battery.
Place the new battery in the battery box and secure the battery hold down clamp. Connect the battery leads to the battery, the red lead to the battery's positive terminal and the black negative lead to the battery'e negative terminal, then replace the battery box cover.
Mar 16, 2012 | 2002 Suzuki LS 650 Savage
Remove battery from 2002 dyna
The Dyna battery can be removed by:
1. Remove the seat.
2. Remove negative connection at frame, and positive connection at battery.
3. Remove the lower rear bolt. (left side of battery box at frame upright)
4. Remove the upper rear bolt, and swing down the battery box.
5. Remove the top cover, nad side cover.
6. Lift battery out, and remove negative cable from battery.
Feb 05, 2011 | 2002 Harley Davidson FXDL Dyna Low Rider
How do i take off the battery cover
1. Remove the seat.
4. Remove hte upper rear bolt, and swing down the battery box.
5. Remove the top cover, and side cover.
Jan 17, 2011 | 2001 Harley Davidson FXDL Dyna Low Rider
How to replace main heater fan
Blower Motor REMOVAL & INSTALLATION Front Fig. 1: Front heater blower motor assembly 89696g02.gif
Remove the glove box to access the front blower motor, which is on the firewall 89696p02.jpg
The blower motor vent tube helps to cool the blower motor for efficient operation 89696p04.jpg
A ratchet with extensions makes removal of the retaining screws easier 89696p06.jpg
  1. Disconnect the negative battery cable.
  2. Open the glove box door. Gently squeeze the retainers at the rear of the box inward and allow the box to swing downward. NOTE: If additional access is required, unfasten the glove box hinge retainers and remove the assembly.
  3. Label and disconnect the electrical harness from the blower motor.
  4. Remove the blower motor housing tube and/or blower motor cover.
  5. Remove the blower motor retaining screws.
  6. Remove the blower motor from the A/C evaporator. To install:
  7. Install the blower motor in the A/C evaporator and tighten the retaining screws securely.
  8. Install the blower motor housing tube and/or blower motor cover.
  9. Connect the electrical harness to the blower motor.
  10. Reinstall the glove box and close its door.
  11. Connect the negative battery cable.
Rear Fig. 2: Service cover push pin locations 89696g03.gif
  2. Remove both rear passenger seats.
  3. Remove the three push pin retainers from the lower edge of the auxiliary heater and air conditioning service cover.
  4. Lift the service cover outward and upward to remove.
  5. Label and disconnect the electrical harness.
  6. Remove the blower motor housing tube.
  7. Loosen the three retaining screws and remove the blower motor. To install:
  8. Install the blower motor and tighten retaining screws securely.
  9. Install the blower motor housing tube.
  10. Connect the electrical harness.
  11. Position the service cover and install the three push pin retainers from the lower edge of the cover.
  12. Install both rear passenger seats.
  13. Connect the negative battery cable.
Dec 19, 2010 | 1998 Ford Windstar
Removal of Battery
lift seat up,then remove the air box decortive cover then remove air box cover remove air filter and at the base of the velocity stack are o-rings slide them up and remove the5mm screws then remove the bottom of the air box and the batttery is up front disconnect the cables and pull the rubber strape towards you and down then remove battery when replacing the velocity stacks do not over tighten the allen screws and make sure you put the o-rings back down to the base good luck
May 05, 2010 | 2002 Harley Davidson VRSCA V-Rod
Removing VW polo 2005 battery?
Removing a battery from a Beetle is a bit complex and tricky. I just changed the battery in a 2003 2.0 Beetle. However, the process is very similar in a TDI Beetle. You will need more than your standard generic tool set in order to complete this task. Your tool list needs to consist of a pair of pliers (prefer locking type), a # 20 TORX head screwdriver (You will also need this if you ever plan on changing the Beetle's internal dash pollen filter for the A/C. ), a 10 mm and 13 mm sockets, a long extension and a wobble or universal to allow flexibility in tight spaces, an allen socket for removing the power steering reservoir, and a small adjustable wrench or a 10mm to remove the battery cables. If you are changing the battery you might as well buy a new Air filter since you will need to remove the air box in order to replace the battery. If you do change the air filter you will need a phillips head screwdriver.
1. Pop the hood.
2. Remove the two 10 mm bolts that hold down the air filter box.
3. Undo the clamp that holds the large tubing to the air box using your pliers. Move the tubing away from the box.
4. Unclip hose attached to the back of the air box near the large hose (under it).
5. remove the small breather hose from the air box.
6. Pull air box up and out.
7. Remove snap on cover from top of battery.
8. Remove small snap on wiring cover from back of the battery covering.
9. Unbolt power steering reservoir (next to battery case).
10. Disconnect the battery cables. Positive side first.
11. Remove the 13 mm bolt at the base of the battery along with the hold down clamp.
12. Pull the top wiring away from the battery case and then slide the battery towards the engine.
13. Remove the plastic battery case.
14. Remove the battery
Oct 07, 2009 | 1997 Volkswagen Jetta
Wear is the batary on VW touareg 2 5 tdi
are you really ready for this..
if (typeof InitForm != "undefined") InitForm('lookup1','autodiv1','down');
Under the drivers seat. OK, let's add to this...
It's a tad more complicated. There are two plastic covers at the front of the seat on the floor. You need to lift both of them up. That exposes a fastener that will require a 10mm "triple square" male tool. This is similar to the familiar Torx (6 point star) fastener except it has 12 points instead of 6 points. This tool is available at many auto supply places, without it, you will NOT replace the battery. Remove both screws (they're TIGHT!!!), remove the plastic trim pieces from the rear of the seat slide assembly (carefully snap off) Tilt the seat back all the way forward, slide the seat forward almost all the way but leave space to miss the steering wheel. Now push back on the seat back and the entire seat will tilt to the rear exposing the battery box under the drivers seat. There are four clips that hold the cover on, unhook them, remove the torx screw holding the heater deflector to the battery box lid, remove the wire tie holding the wire to the top of the box and remove the box cover. Now you see the battery. Remove the gas vent plastic pipe from the front, remove the metal cover at the front left corner (10mm socket) it will not come out until you remove the (-) cable but don't just yet. remove the side clamp (10mm socket) and the battery is loose and free. It would be smart (but not required) to provide a 12 volt electrical source to the battery terminals as you replace the battery to help keep all of the radio GPS etc, settings. Remove the terminals, lift out the battery.
Sep 16, 2009 | Volkswagen Touareg Cars & Trucks
Disconnect and replace the battery.
yes remove top cover. diconnect battery. neg side first. remove front cover 2 screws near bottom lift off front cover. when installing new battery connect pos side first then neg
Jul 21, 2009 | 2003 Suzuki VL 1500 Intruder LC
Sony DSC-T70 Digital Camera Logo
29 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
