Question about Acer Aspire One PC Notebook
Computer says connected to wireless connection but pages won't load
  • 6,831 Answers
Hello there
I had a similar problem about a week ago.
Windows 7 confirmed that i was connected and windows updates worked but i could not open any web page. The problem was that my proxy setting have changed. If this is your problem, you just open your broser go to tools, internet options, connections, lan connections and then just tick of the box which says auto detect settings. Restart the broser and it should work.
The other problem could just as easy be that your ip is not set to auto obtain. Try this as well. I really hope this works for you, it did for me. Please rate this.
Best regards
Posted on Sep 26, 2009
Cant put a password
Are you trying to secure wireless network?
Which page is not loading.
You mean the setup page of the router?
What is the model number of your router?
Is your computer wired to the router?
Make sure that your computer is connected to the router with the Ethernet cable. Do not use wireless computer.
If it is not opening the complete page then try to reset and reconfigure it.
If that doesn't work then upgrade the firmware of the router.
Read steps to secure wireless network on Linksys router
May 30, 2012 | Linksys Computers & Internet
Tv won't connect with wireless
what kind of error message are you getting, if none open event viewer by hitting the windows key and the R key at the same time and type "eventvwr" after it loads look at your system logs to see if you have any messages there as to why it won't connect.
May 20, 2012 | Computers & Internet
I disabled my smc wireless through the ip address provided. When I went to reable it, the ip page won't load?? Help please
You might be connecting through wireless before and now that you have disabled it, your computer is not connected to the router and that is why you are not able to display the setup page. You can use an Ethernet cable to connect your pc to the router. Once connected, try to load the router's setup page again through the provided ip address. If you are unsure about your router's ip address, check this out for guidance. click here.
Hope this helps.
Jun 27, 2011 | Computers & Internet
I have the RNX-N1MAC wireless adapter and just recently it has started dropping internet connection. It stay connected to the wireless and shows full bars, but pages won't load.
1. check the manufacturers web site to see if there is an updated firmware for your adapter.
2. check your wireless router to see if you have to update the firmware ( this is is you are using this adapter on your home network
Jun 17, 2011 | Rosewill Wireless Adapter RNX-N1MAC IEEE...
I was connecting my siemens wireless router 6520 and i reset it after doing that the wireless light went off and would not work again anything i can do?
If you reset the router, you will likely need to go into the router's configuration through a wired connection and enable the wireless functionality of the router.
Please see the excerpt from the below website:
NOTE: The IP address in the example may differ than your actual IP
Please follow these steps to set up your a wireless network with your Siemens Speedstream 6520 Wireless Modem.
To create a wireless network you first need to enable the wireless functionality of the router. To do this you need to connect the router by an Ethernet cable to your computer. Once the wireless modem is plugged into your computer via Ethernet and turned on please follow these steps to enable the wireless functionality.
Open Internet Explorer or your preferred browser.
  1. In the address bar type 192.168.254.254 then press enter.
  2. This will bring up the main page for the Router.
  3. Once the start up page has loaded you will then need to login by clicking on the "Go" button in the top left of the window.
  4. This will bring up the Login page. Once the page has loaded please enter the username username and your password, then click "Log In".
Note: The default password is "admin", although this may have changed if you have changed the password.
Once this page has loaded click on "Home Network" and then click "Advanced".
Once the new page has loaded you will have a list of links, please click on the "Configure the Local Speedstream Gateway Wireless Network" link.
This will bring up a new page called "Wireless Summary".
Once this page has loaded place click on "Begin Wireless Wizard".
On the new page under where it says "Wireless Interface" please click "Enable".
Once you have changed the wireless interface to "Enable" please enter a name for your wireless network where it says SSID (e.g. "Home Office").
Then please click on the "Next" link.
On the new page, please change "Security Mode" to "WEP 64-bits" and click "Next".
This will bring up the "Wireless 64-Bit WEP Configuration" page.
On this page you will need to enter a passphrase to generate your WEP keys. We have used "icecream" but you can use anything. Once you have entered a phrase click "Generate Key".
This will generate four 64 Bit Key's. Please select any one of the four keys and click "Next".
Note: You will need the 64 Bit Key that you select in the future for devices to log on to the wireless network. Make sure you can remember your chose a passphrase that you will remember.
Once you have clicked "Next" a new page will load called "Wireless Filter Configuration". This is an advanced page for allowing access and denying access to certain computers or devices. We have set the "Wireless Filter" mode to "Disable".
Please click on the "Next" button to bring you to the "Wireless Options Configuration Page".
On this page pleas make sure that:
"Data Transfer Rate:" is set to "Auto"
"RTS/CTS Threshold:" is set to "2432"
"Fragmentation Threshold:" is set to "2346"
Once these setting are correct please click "Next" to bring up the "Wireless Wizard" page.
Once this page has loaded, you have finished enabling your wireless network so click "Finish".
This will bring up the "Wireless Summary" page again, but next to where it says "State" it should say "Enabled". Please ensure your settings are the same as the screen shot below ("SSID" and "Security Key Info" may be different").
If all these details are the same please click on the "Reboot" button to save the changes, and then once the new page loads click on "Reboot" to restart the router.
Once your modem has fully rebooted, please close your browser.
You are now able to unplug the Ethernet cable from the router and the computer.
How to connect other computers to your wireless network
On the computer you want to connect to the wireless network please follow these steps.
Once your browser is closed please click on the "Start" menu on the bottom of your screen, the click on "All Programs", hover over "Accessories", then hover over "Communications" and then click on "Network Connections".
Once "Network Connections" has opened under where it says "LAN or High-Speed Internet" please right click on "Wireless Network Connection" and then click "View Available Wireless Networks".
This should load the "Wireless Network Connection" window, and you should be able to see the wireless network you have set up.
Note: If there is nothing in your list you will need to click the "Refresh network list" button.
Once you see your network, make sure it is highlighted and then click "Connect".
Once you have clicked "Connect" it will ask you for your "Network Key". Please enter your 10 character key next to where it says "Network Key" and then retype the 10 character key where it says "Confirm Network Key".
Note: Your "Network Key" is the 64 Bit Key that you generated with a passphrase in step 16.
Once you have entered and confirmed your network key click on connect.
If everything is successful, the "Wireless Network Connections" window should say "Connected" next to your wireless network that you set up.
You should now be able to browse the internet.
May 06, 2011 | Siemens SpeedStream Modem (4100) (SS4100)
My ipod touch will not connect to my belkin wireless router
change the "security" type to WEP 64bit..... use 10digit number as password for security....
disable "wifi protected setup" in router.... the network(ssid) name should be a single word without any spaces and symbols....you can find SSID in "channel and ssid".......
you can login to router to do these settings.... hardwire any computer to one of wired ports in belkin router... type 192.168.2.1 in Internet explorer or firefox.... login password: no password... leave it blank and click submit... on the left side of router setup page you will find all the above key words.... do the settings accordingly...
Apr 25, 2010 | Belkin (F5D7230-4) Router (587009)
Was working fine, moved to another apartment down the hall, now it won`t even show under wireless connections, but i can connect to any unsecured network in our building and hardwire my laptop into the...
Considering How thick the walls are... the signal from your router may not be able to go through plus all the other EMI devices like Chordless phone etc.
Try Setting up the router in an open area suitable for a better signal for your laptop.
Apr 04, 2010 | Linksys Wireless-G WRT54G Router
Loses the connection
You will need to check the wireless settings of the router
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
Click here for step by step instructions
Feb 07, 2010 | D-Link RangeBooster G WBR-2310 Wireless...
Acer Aspire One  PC Notebook Logo
100 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
