Question about Canon PIXMA MP600 all-In-One InkJet Printer
Patchy black printing Cannon MP600 - Canon PIXMA MP600 all-In-One InkJet Printer
ginko
  • 19396 Answers
SOURCE: My Pixma MP600 Cannon Printer
I cannot understand what the problem is
Posted on May 03, 2008
Webcauldron
SOURCE: error code 6a00 on my cannon mp600 what does it mean
simply move the cartridge back and forth a few times
Posted on Mar 02, 2009
  • 1335 Answers
SOURCE: I have just changed my black ink cartridge however still patchy
Typically you do not have to change the color cartridge when you replace the black cartridge.
As far as the spotty printing, it sounds like you have some clogged nozzles caused by the lower quality of ink in refilled or aftermarket cartridges. There cartridge inks may not be up to specification. This is especially true for the ultra fine printers.
To clear the problem you need to insert an OEM cartridge, run the deep nozzle cleaning utiliity at least twice followed by the alignment utility. This should clear up the problem with the spotty and washed out printout.
Let me know if this solves your problem otherwise we can explore other solutiions. For the record, which printer do you have?
Please rate this solution. Thanks.
Posted on Oct 07, 2009
Testimonial: "I have a Lexmark X1180 printer. Excellent feedback and also very prompt! Thankyou"
Icebassman 5
  • 57 Answers
SOURCE: my cannon mp600 will not print in black both black
Hi there.
Print head is possibly faulty.
Iceman.
Posted on Nov 10, 2009
pineworks
  • 4041 Answers
SOURCE: My black ink is patchy, even after deep cleaning
Hi There
Summary
Usage of compatible ink and leave the printer idle too long may cause printhead clogging
What should you do if you get this problem. Relax; you may recover the printhead by unclogging it. Follow these steps to unclog the printhead
1. Right click in the printer driver name
2. Select Properties menu
3. Click Maintenance tab
4. Click on cleaning sign for regular cleaning. Perform this up to 3 times.
5. If this does not work, perform Deep Cleaning
And if that not work
Some times it needs a good clean up but this is up to you if you want to do this,
But after you done this prime the printer so it gets the inks back in the heads, it may take a little time for the inks to work.
Ok.
There is fluid cleaner for this but I can never find any in the shops the only ones I seen is when they sell them in Tesco but they come in with the ink refill bottles so I just use worm water by it self on a cloth and dabbing on the heads to clean them, it will not harm the heads but not to much water.
Some heads are on the inks them self but some have them inside the printer so I not know your printer so if the heads are inside you need to get them out you may find that some heads will just clip out put some need to be unscrewed so you got to know how they come out so be careful and not push to hard on them, if the heads are on the ink then it is a easy job to clean them,
It worth a try it worked for me more than ones.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Posted on Mar 16, 2010
Paper Feed problems for Cannon MP600
Mechanism Problem replace the mechanism with new one.
Jan 01, 2013 | Canon PIXMA MP600 all-In-One InkJet...
Hi We have a Cannon MP600 printer. Just replaced the large black cartridge (PGBK 5) as it had run out. The printer is now smearing gaps in the text (in black). Tried 2 cartridges & both produced the...
Hi ...
This printer has an ink absorber that takes in ink during the printing and print head cleaning processes. The cleaning process is necessary in order to keep the print head nozzles from becoming clogged and showing the line gap in printing. Over the life of the printer, the amount of ink that the ink absorber has absorbed is calculated by the printer. Eventually, after substantial use, the printer will enter an error condition when the ink absorber is nearly full. At this point, printing is still possible by pressing the button on the printer. To protect the printer from damage, you will not be able to print at all once the ink absorber is full.
Canon recommends having the printer serviced before the absorber becomes full. We are aware that there are many "do-it-yourself" Web sites that offer instructions for making this repair. Replacing the ink absorber is a complicated and potentially messy procedure. Even if the ink absorber is successfully changed, the ink absorber counter must be reset. Be aware that if you attempt this procedure, it is at your own risk.
Please vote if this helps ... Cheers :)
Jan 08, 2011 | Canon PIXMA MP600 all-In-One InkJet...
Cannon MP600 printer shut itself down during printing operation . Pressing ON/OFF button will not turn it. I checked connections and power source. Still, no reaction.
Re: "Cannon MP600 printer shut itself down during printing operation ."
If a Canon inkjet printer is turning itself off, then problem is either control board or power unit. When this happens printer is often considered beyond repair, and in any case it must be tested by a technician to find out the problem.Repair involves testing volts out from power unit and testing components on main board.
Considering that the MP600 is quite an expensive inkjet, I suggest contacting Canon support and asking a quote on repair.
Here Canon support pages:
Canon U.S.A. : Contact Us
Canon U.S.A. : Support
Canon UK - Support
Canon South Africa - Support
Aug 30, 2010 | Canon Office Equipment & Supplies
Cannon Mp600. I have an error code 6A00
Try
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Jan 12, 2010 | Canon PIXMA MP600 all-In-One InkJet...
CANON MP600 - NOT PRINTING IN BLACK INK
I have had the mp600 for 3 years - worked fine on a couple of different pcs. I switched to a mac and encountered 2 issues - scanner stopped working and above problem of no black ink. The newest driver (just google mp600 driver) fixed the scanner issue. The ink issue has a work around - select non plain paper in the media quality tab, instead use any photo paper setting. Finding this area in a mac can be tricky - in the mini print options window you have to click the small chubby arrow and you will then be given a list of options including quality and media. Presto, black ink returns but probably uses more ink and takes longer to print. I have not found a more elegant solution as you have to select this non default paper option every time.
Apr 18, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Error code 6a00 on my cannon mp600 what does it mean
Feb 03, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Waste ink absorber full on canon pixma ip4000
cannon pixma ip4000 waste ink absorber is almost full what do i do, getting patchy printing, have cleaned and deap cleaned and this hasn't ;helped
Jul 23, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Canon PIXMA MP600 all-In-One InkJet Printer Logo
23 people viewed this question
old marine
old marine
