Printer not powering up
My epson stylus c88+ does not power on. tried everything ,changing cords outlets nothing works.
Epson stylus c62 went bang!
Well wish I had good news. Sounds like you're voltage distribution board got fried. BUT before we pronounce it dead, are you getting any codes at all? Or is everything blank? If your getting nothing, nothing you can do. Did you plug into wall or power strip? For grins, try one more outlet.
Oct 24, 2012 | Epson Stylus C62 InkJet Printer
My Epson stylus 2200 will not even power up now. I don;t get any lights. I've check that the cord is plug in the whole way, exchanged cords, and tried different outlets.
hi ldbartz,
i/m sure you already check all cabling issue.
if none if its working mean you got power problem.
on every printer these days, all system powered from an adapter,
if nothing happen to your power or adapter, printer will go power on and the power led will go on also.
the adapter itself (for all epson) is located inside, you cannnot replace it without open your printer like canon printer.
that is my opinion.
Mar 16, 2011 | Epson Stylus 2200 InkJet Photo Printer
C88 printer will not turn on ,no green light, power cord is ok. is there a fuse inside?
No fuse. This model is 5+ yrs old. Time for a new printer. Printers are so much cheaper now than trying to repair the old one. Sorry.
Mar 12, 2011 | Epson Stylus C88 InkJet Photo Printer
Epson Stylus C88 - New Epson Factory ink cartridges. Nothing prints, although printer goes through the motions of printing. What could be wrong? Ink levels are fine.
You should run a nozzle check to verify if the heads are printing all the inks correctly. If the pattern is incomplete you need to run head cleanings.
Apr 30, 2010 | Epson Stylus C88 InkJet Photo Printer
Epson Stylus C88 plus
Make sure that the head can move on the carriage bar as this indicates a head assembly lock or jam. Make sure all the paper paths are clear and there is no tiny piece of paper stuck. Power it back on. If this does not resolve then you will need a visit to the repair shop or buy a new printer which is probably cheaper!
Sep 11, 2009 | Epson Stylus C88 InkJet Photo Printer
Epson c88 prints horizontal lines
It looks like storm_christ has lost interest in this problem, so we may call it "solved by poster".
Apr 06, 2009 | Epson Stylus C88 InkJet Photo Printer
Lights flashing
- make sure cartridge cover is securely close
- power cycle the printer
- try to plug in directly to the outlet
- unplug the power cable and plug it back in
pls let me know if same issue persist!!!
Oct 05, 2008 | Epson Stylus C88 InkJet Photo Printer
Epson Stylus C88
my printer will not stop printing despite having been disconnected and turned off in an attempt to stop this from happening
Jan 13, 2008 | Epson Stylus C88 InkJet Photo Printer
Will it ever print again?!
mine did that. it was a full cartridge and it was still saying it was empty. tech support told me i had to reset the chip but mine was a refilled cartridge. then everything worked fine but i had the reseter
Feb 05, 2007 | Epson Stylus C88 InkJet Photo Printer
42 people viewed this question
k24674
jasbo
jasbo
