Question about Sony Playstation 3 (PS3) Console
Wont turn on
My PS# wotn turn on. When I flip the switch and touch the power button, the power light it first turns green, then yellow, then it starts flashing red and makes 3 quick beeps. What is wrong with it and how can I fix it?
  • J1NXFOUR Mar 03, 2009
    I was in the middle of an online cod5 game when my ps3 just shut down completely. It has power but it will not turn on. On the ps3 itself the light flashes red until i press it, then it stops flashing. I then press it again and it powers up for a second (green light comes on) then it dies again (back to flashing red light) HELP
I have a ps3 that has a problem. I was playing a game it shut off by it self i had to hit the main switch in the back to reset it then i play a like two more time and it keep turnin off. The next day i go to play and its dead there not stand by lights or nothing. Please help me out.
Posted on Dec 19, 2007
    Problem Solver:
  • 5 Answers
I don't think the outlet you are plugging it into has enough power to support the ps3. Try plugging it into a different outlet and see if it works.
Posted on Dec 18, 2007
I turn on my ps3 and the green light comes on for a short time and the it beeps three times shuts off and the green light turns red and starts to flash. If I push the power button again the red Light
you need to change your power box there is a bad connection with the wires. its over heating you might whant to buy another at game stop or take it in to get fixed. the more you messed with it it might mess up your whole system.
Aug 18, 2012 | Sony Playstation 3 (PS3) Console
I turn on my ps 3 and it goes green light then after about 3 seconds goes yellow then red.
when i turn ps3 on it flashes a yellow light then the green light comes on it dunt come up on screen and it wont turn off or eject disks
Dec 23, 2010 | Sony Playstation 3 (PS3) Console
Flashing red light will not eject game
if you turn it on, and it goes green then yellow then beeps 3 times and flashes red, then your ps3 has overheated and been damaged. you can fix it with the heat gun trick, http://www.youtube.com/watch?v=4_Ic1_TY-GU
but it will only break again.
try flipping the switch in the back, then hold the eject button while you flip the switch back on, that should eject the disc.
Dec 11, 2010 | Sony Playstation 3 (PS3) Console
It flashes a yellow light in front instead of green when i press the power button and won't let me play or even eject the disk
the ps3 is dead call customer support if you need hte disk out turn it on hold eject flip power switch off in the back whili still holding eject and turn it back on it will force the disk out
Dec 04, 2010 | Sony Playstation 3 (PS3) Console
Turned off and won't start. the light turns green then yellow then flash's red
The temperature inside the system is very high. Check whether the system is being used in a hot location OR the vents are not blocked. Touch the power button on the system front to stop flashing and then turn off the system until it cools down After it has cooled down, turn on the system again.
Mar 11, 2010 | Sony Playstation 3 (PS3) Console
My sharp tv wont stay on, it flashes green
Hi i have seen this before sharp hdtv's are known for having the internal power supply go faulty
Feb 01, 2010 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
My playstation has the light trun green yellow flashing red light
With your PS3 turned off, press and hold the Power button on the front of the PS3 for about 10 seconds (the system will beep as normal as it starts up but after 7-10 seconds it will beep again). The video settings should now be reverted. Doing this will also reset any theme settings. try this? seems to fix alot of issues.
Jan 22, 2010 | Sony PlayStation® 3 (80GB) Console
Turned the power button on turned yellow and flaSHED RED
You will need to have the motherboard reflowed. The processors have probably come unseated from overheating.
Oct 07, 2009 | Video Game Consoles & Games
Power switch light is on but no other poweris getting through, changed the power supply but same problem. light comes on power button but power supply fan doesn't even come on.
No beeps are heard, no CPU fan is turning on, only blinking yellow light. This brand usually experiences this problem.
  1. First, check the power supply. Disconnect connectors from the board and make a jumper wire for the green wire to any black wire. If the PS fan does not spin then it's busted, else proceed below.
  2. Reconnect connectors except the one with 4 wires, 2 yellow and 2 black, then switch on. If CPU fan turns on then you have a bad processor.
  3. If the fan is still not turning on then check the USB port pins for short circuit.. disconnect it from the board and switch on.
  4. Do the same with other hardware connected to the board.
PS: The metallic casing of computers must be connected to the common ground of the power utility to protect it from stray currents that result to damage of sensitive components such as processors, memory and hard disks.
Sep 26, 2009 | Packard Bell (190169) Power Supply
Sony Playstation 3 (PS3) Console Logo
336 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
