Patchy black colour printing.Tried new 5 and * cartridges sometimes works OK sometimes doesnt. Appears to be getting more regular bad results
JMuskovitz
  • 135 Answers
SOURCE: printing black squares in word.doc
It sounds like this is an HP driver issue. HP drivers have built-in "optimizations" (that unfortunately have bugs) for things like printing photos. Different programs (word, for example) try to take advantage of these optimizations in different ways. When they work, they give superior photo printing (faster, with more accurate color). When they don't, you get black squares. This is why "converting" it to PDF worked for you -- Word printed it through the PDF driver instead of the HP printer driver, then when you printed the PDF file, that program avoided those optimizations when it sent the images to the printer. Unfortunately, the translation caused quality loss. If your goal was to print out something like a "proof-sheet" of photos, you might try the free photo organizer at www.preclick.com. It will print these for you, captions and everything, and should be able to avoid the driver issues.
Posted on Apr 11, 2007
IrishDruid
  • 2712 Answers
SOURCE: Dell 924 inject
Use only original cartridges and not generic/refilled ones. I think that is the source and answer to your problem ;)
Posted on May 15, 2008
SOURCE: hp officejet 6110 not printing with black ink
I think I know what is the problem. I refilled my black ink cartridge and it printed for a while, but at some point it just stopped working. The head wouldn't touch the paper. Initially I thought the printer had a problem, but then I discovered that the color cartridge still worked.I had a spare new cartridge so I changed it. Everything worked just fine afterwards. My hypothesis is that HP tracks an identifier in the cartridge and does NOT allow you to refill (I even think they simulate for the cartridge to be failing, but I still have to corroborate this). I think this is outrageous and illegal. Please let other people with the same problem know about it. So, the solution is to stop using HP products.
Posted on Dec 05, 2008
  • 1335 Answers
SOURCE: I have just changed my black ink cartridge however still patchy
Typically you do not have to change the color cartridge when you replace the black cartridge.
As far as the spotty printing, it sounds like you have some clogged nozzles caused by the lower quality of ink in refilled or aftermarket cartridges. There cartridge inks may not be up to specification. This is especially true for the ultra fine printers.
To clear the problem you need to insert an OEM cartridge, run the deep nozzle cleaning utiliity at least twice followed by the alignment utility. This should clear up the problem with the spotty and washed out printout.
Let me know if this solves your problem otherwise we can explore other solutiions. For the record, which printer do you have?
Please rate this solution. Thanks.
Posted on Oct 07, 2009
Testimonial: "I have a Lexmark X1180 printer. Excellent feedback and also very prompt! Thankyou"
Sebin
  • 712 Answers
SOURCE: black ink will not print. Colours ok
Get a syringe, remove the needle, remove the ink cartridge and use the syringe to blow air GENTLY through the hole the cartridge connects to. Make sure you have a cleaning cloth to remove ink dislodged from pipe connected at the print head, do this gently to remove any obstruction and there should not be too much mess and can easily be cleaned up.
Posted on Feb 04, 2010
My canon iP3500: Black print comes out patchily, despite many attempts at deep cleaning, Each time I deep clean, a couple of pages come out with the black print OK, then it goes patchy again.
It sounds to me like your cartridge nozzles are clogged. That's more common with recycled or refilled cartridges, but it can also happen with new cartridges if they are older. If you just purchased the cartridge you could try to return it. Otherwise, I would try to continue deep cleaning and nozzle checks until it starts to print. It takes a lot of ink, but sometimes that's the only way to get it to print. Usually it will work eventually. Do a nozzle check in between each cleaning and deep cleaning.
Feb 06, 2011 | Canon PIXMA iP3500 Printer
Black ink will not print. Colours ok
Feb 04, 2010 | Brother DCP 165C Compact Color Inkjet...
Oct 07, 2009 | Office Equipment & Supplies
No black ink printing
Try reinstalling the printer, as it sounds like a driver problem. This shouldn't happen, but occasionally the drivers get corrupted. And refilled cartridges certainly don't help, and may continue to give trouble even when replaced with OEM ones. Have you tried turning the printer completely off - disconnecting the power lead, for a few minutes? That sometimes clears things.
Jun 27, 2009 | Canon PIXMA MP510 All-In-One InkJet...
My printer will not accept a new black cartridge.
ITS NOT THE BLACK CARTRIDGE!!! Try changing the colour cartridge and see what happens. When a 9600 checks ink levels it does the black ink first, then the colour, if the colour is low it goes back and checks the black again but will constantly give an error message for the black cartridge. Sounds bizarre but try just the black cartridge in with no colour. print a test page in black only, if that does not print then it is a fault. Also make sure the driver is updated!!!
Feb 16, 2009 | HP DeskJet 9650 InkJet Printer
Mx700 only printing in B&W
This is a software problem, do uninstall and re installation of the printer software on your computer and that should do it...
Dec 14, 2008 | Canon MX700 Office All-In-One InkJet...
Using far too much ink
This came from brothers website:
The Yellow ink cartridge yield is up to 300 pages @ 600 x 150 dpi when printing at 5% coverage on A4 sized paper.
The Magenta ink cartridge yield is up to 300 pages @ 600 x 150 dpi when printing at 5% coverage on A4 sized paper.
The Cyan ink cartridge yield is up to 300 pages @ 600 x 150 dpi when printing at 5% coverage on A4 sized paper.
The Black ink cartridge yield is up to 350 pages @ 600 x 150 dpi when printing at 5% coverage on A4 sized paper.
so it appears that what you are experiencing is not normal and you may have a leaking printer.
There is one thing you can check though, everytime you print, make sure that you are not printing at the highest quality option selectable as this almost certainly will fire out more ink than regular printing... choose a middle quality option or even draft option if you will be printing regular text.
Jul 02, 2008 | Brother Office Equipment & Supplies
Wonky colour printing!!
you need to run a print alignment test.. this should correct the colour faults (unless you really do have blocked cartridges,
Sep 27, 2007 | HP DeskJet 5550 InkJet Printer
23 people viewed this question
k24674
