Question about Kenmore Dishwashers
Ultra wash quiet guard standard kenmore. Little preassure from pump. brand new.
  • mdlamoth Sep 26, 2009
    Forgot to mention it was bought at yard sale.Its brand new and you can tell its never been hooked up.The pump seems to work enough for the water to erupt to the ceilling of the dishwasher but does not spin the propeller if thats what its called.any more suggestions,thaks.
    Brigadier General:
  • 4,088 Answers
Call Sears and have them honor their warranty.
Posted on Sep 26, 2009
My kenmore quiet guard My partially fills and therefore does not clean. any suggestions
Possibly low water pressure; possibly a clogged inlet screen on the inlet valve; possibly a bad inlet valve (replace it).
Nov 14, 2014 | Kenmore Dishwasher With Ultra Wash And...
Why is my kenmore ultra wash quiet guard blinking clean?
You can go to Kenmore's website, list your machine model and the
problem and you can get an answer. Usually you have to re-program
those machines every 400 hours. Hope this helps
Jul 06, 2014 | Kenmore 24 in. 17482 / 17484 / 17489...
Kenmore ultra wash quiet guard standard. Very little pressure coming out of the jets. Doesn't clean the dishes.
sounds like hard water is the problem and may have clogged the jets. clean it out really well and get the dishwasher filtration system from www.dishwasherfilter.com. that will remove the hard minerals and leave your dishes and dishwasher spotless. awesome product and the results are guaranteed.
Jul 08, 2013 | Dishwashers
I see the pressure tower for a Kenmore Ultra Wash Quiet Guard dishwasher laying in the bottom of the dishwasher. I've just rented the house and haven't used the dishwasher yet. Does this pie
No, the designers put it in there for a reason; it won't work as well without it, as it would with it in. Probably the mounting tabs are broken or sprung. A new tower isn't very expensive. You can probably get one from SearsPartsDirect.com, RepairClinic.com, EasyApplianceParts.com, or AppliancePartsPros.com.
Mar 28, 2012 | Kenmore Dishwashers
My Kenmore Ultra Wash Quiet Guard
take kick plate off get book out how to reset board
Apr 24, 2010 | Kenmore 15899 Built-in Dishwasher
Soap dispenser will not open during was cycle.
Probably a faulty solenoid on the dispenser. Not replacable new dispenser needed
Jan 20, 2010 | Dishwashers
Loud Buzzing Sound from Dishwasher
have you ever seen green led "Clean" light flashing? before or about the same time the buzzing sound started? and if so that would indicate that the control senses a fault in the temperature rise during the heating cycle and that the electronic control could be reset by initiating a service diagnostic cycle.(which is what you were trying to do) pls reread your manual there are times during that sequence that some buttons have to be pushed at the same time and within a certain amount of time..possible that your machine also has a bad timer which would give you a buzzing noise..if thats the case I would recommend replacing the cpu or control board..or the machin all together..The Kenmore Ultra Wash Quiet Guard name is sears but whirpool has the contract to produce all "kenmore products.hope that helps.
Jul 30, 2009 | Dishwashers
Smelly dishes from Kenmore Ultra Wash
If you post the model number of your dishwasher plus its approximate age (in years) I can help more.
But the most common cause is a weakening pump motor. On many dishwashers, the wash pump motor is also the drain motor. Replacing that motor / pump assembly will solve the problem. While you are replacing the pump, check the heating element to confirm that it is not shorted out or broken.
For now, add a cap full of bleach to the water _after_ the initial dishwasher fill cycle ends and the wash cycle begins. White vinegar would also work, but this will not fix your problem.
Good Luck!
May 04, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
The IRONY of my Quiet Guard!! SO LOUD!!!!
Yes the wash arm can be removed to get to the sump area. Take the model number for your dishwasher and enter it into a site like partselect.com. There you can get a blown up diagram of the components that need to be removed to get to the cause of the grind noise. Usually a seed or some other hard object has found its way down there.
Feb 06, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
No water
inlet solenoid not working, check wiring is attached
Jan 27, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
Dishwashers Logo
337 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
