Question about GE Cooktops
We ordered a GE gas cooktop 2 burner module to replace the grill on the lefthand side of a cooktop we inherited (model JGP389WEVWW). The gas cooktop only had 2 burners with a grill, and since we want 4 burners, we called the GE Parts department to check on availablity of the 2 burner module. They said it was available and we ordered it. Since it was on backorder we went ahead and converted our electric cooktop to gas, after receiving confirmation from GE that the new gas module would be sent. GE sent part# JXGB79W which is supposedly the correct part number for our cooktop, however this part supercedes the former part# JXGB89W. The problem is, the new part number does not fit into the cooktop--the striker is in the wrong position. So although we ordered the cooktop, and had our electric cooktop converted to gas based on the information we were given, the new part does not fit. It took over 3 hours on the phone with GE today to discover that the new part number superceding the old won't work. I have looked online for the correct new part, checked Craig's List and Ebay, and I just can't find JXGB89W. It is appalling to me that GE didn't warn me that this superceded part may not fit our appliance -- we converted to gas before receiving the part from GE, which apparently was a huge error in judgment. I spoke with Customer Relations, the Parts Department, Credit and Returns, The GE Answer Center, and the process was a complete fiasco -- it was exceedingly difficult to get to the right people and try and negociate which direction I should go. It was a lady in Credit and Returns who was able to finally explain to me that a part that supercedes an old part may or may not fit! It is truly unconscionable to me how GE could allow people to order parts without warning them first that the part might not work. Why wasn't I forewarned? Had I known this may occur, I would not have ordered the 2 burner module. Are there any options available? I am so darn mad I cannot even see straight... Thanks for any help you can offer.
  • 582 Answers
THE BEST ADVICE I CAN GIVE YOU IS GO ON LINE TO
REPAIRCLINIC.COM AND THEY WILL ANSWER ANY QUESTIONS YOU HAVE AND CAN GET YOU GOING IN THE RIGHT DIRECTION
Posted on Sep 26, 2009
Testimonial: "Really appreciate your idea, but on Repair Clinic, the newer part (striker in the wrong position) has replaced the one we need. Same as the GE fiasco."
How do I replace spark ignitor on GE JGP963SEF1SS gas cooktop?
If none of your burners are igniting, you need a new Spark Module. If only 1 or 2 of your burners are not igniting, you may need a Spark Igniter. Click on the pictures below for a larger image.
The Spark Module is number 318 in the following diagram (underneath the burners):
The Spark Igniter is number 154 in the following diagram:
Jun 02, 2011 | GE Cooktops
My GE Gas cooktop model # JGP975EKSS is trying to ignite without any burners being turned on.
If all the burners are trying to ignite at the same time - the ignitor module is to blame.
If it is one specific burner - take a look at that individual knob.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 04, 2010 | GE Profile JGP636 Gas Cooktop
Have a four burner gas GE Profile cooktop. How do
The igniter module is working fine. One of the switches (which are on each valve shaft) is stuck or shorted out. Pull a wire off each one at a time to determine which one is bad. Careful! 120 volts to each wire. Also, this can happen after you spill water into the valve area, if that sounds right, let it dry out.
Jan 29, 2010 | GE 30 in. JGP328 Gas Cooktop
Should I buy a two burner unit if available? Or a new cooktop?
Yes you can as long as there ae two heat controls for the grill side of the stove/cooktop. That allows one burner control for each of the burners. You should be able to order directly from GE but I would also check out repairclinic.com since they normally sell OEM GE parts cheaper than you can buy them from GE. At least check out the price at both sources beforw purchasing.
Dec 29, 2009 | Cooktops
I have a GE model jgp940 gas cooktop one of the four burner electrodes will not spark.
You have to determine if it is the electrode or the ignitor module and replace the component. A simple test is to swap the wires on the spark module for the non working one and see if the other electrode still works. If not the electrode is bad, if it does than the module is bad.
Eric
Dec 24, 2009 | GE 30 in. JGP336 Gas Cooktop
The igniter on the right front burner of my GE Gas cooktop does not work....I must use a lighter or match to ignite....What can I do? There is no clicking sound when I turn on the burner?
the very first thing i would do here is to check the ignitor itself
under the head cap you should see two screws, once those are out you will be able to lift the burner plate, lift the burner plate, you will see, or should see the ignitor, and the wire.
i check this for voltage by unplugging the ignitor and olding the wire close to a ground, the metal body is good. Turn on the ignitor, becareful it is live. yhou shgould see a spark comming from the wire
if not check to make sure that wire is in position and on the spark module
if you do see a spark this way, just order the replacement ignitor
and install it when it arrives
appliancepartspros.com
part number AP3191250
Oct 17, 2009 | GE 30 in. JGP328 Gas Cooktop
GE Cooktop burner doesn't click or light.
Remove all the burner heads and lift the top. Sometimes easier said than done. How do you know it is the module? It could be a cracked insulator on the ignitor. To verify you can swap two of the connections on the module and if it lights then it is the module.
eric
Jun 20, 2009 | GE 30 in. JGP328 Gas Cooktop
Exhaust turns on automatically in burner mode
Hello
I have the one with the 4 burners and the grill, and when the grill in on the fan has to come on, and it does automaticly, but once you finish with the grill you have to change it back to stove mode by putting the 2 burners back or the fan will allways go on when you turn the switch. It is a safety regulation for the fan to be on with the grill to avoid the fumes......I know I hate that too.
Hope this help
Eddie Rentas
Tupper Lake NY
Jul 19, 2008 | GE 30 in. Profile JGP979 Gas Cooktop
Jenn-Air 30 in. JGD8130 Gas Cooktop
Yes. Buy a burner module. Sears sells them also most appliance part stores. (I am assuming you have the model with 2 knobs on the grill side) The electric version of burner modules is around $100 Gas should be similar price.
Jun 08, 2008 | Jenn-Air JGD8130 Gas Cooktop
It is not a GE but it is a Jenn-air
It's either a bad spark module or switch.
Nov 17, 2007 | GE 36 in. JGP628 Gas Cooktop
Cooktops Logo
253 people viewed this question
Top GE Cooktops Experts
Dan Webster
Dan Webster
Jim London
Jim London
Are you a GE Cooktop Expert? Answer questions, earn points and help others
