Question about Polaroid i1035 Digital Camera
On starting the camara I get the message "card not supported".
On start up I get the message "card not supported" and then the camara shuts down. What can I do/
This device cannot start. (Code 10)
Make sure that you have the most updated driver installed for the card. Another thing to try is removing the card (after shutting down your computer) and boot it up. Once Windows loads, give it a few minutes and then shut it back down. Reinstall the card and turn it back on.
Drivers Software Support Toshiba
Jan 03, 2014 | Toshiba Computers & Internet
I tried ALL the suggestionas for my fuji fine pix J150W camara. still have the message of "frame no full". Thanks for all the efforts. I will be buying a new camara.
Don't buy a new camera yet. This solution will help you correct your camera problem. If this helps consider voting me.
1). Insert a new memory card.
2). Format the memory card using the FORMAT function in SET-UP menu in the camera.
3). Set RENEW as the FRAME NO. setting in the SET-UP menu.
4). Start taking pictures.
5). Set CONTINUOUS as the FRAME NO. setting in the SET-UP menu.
Good luck! And thanks for using FixYa!
Sep 05, 2011 | FUJIFILM FinePix J150w Compact Camera...
In my camara when i start message shows ''clean the contact area of the card with a dry cloth''
Having gone over a month with no response, I assume this is no longer a problem.
May 16, 2010 | Olympus FE-25 Digital Camera
MAC PRO dual2.3- freezes, gray screen crash, freeze with hi fan mode,kernel panic reports, all require start button shut down. Some forums suggest ATI card failure. I'm lost.
All computers will shut them selves off or crash when fans are failing, or have failed. Cooling fans are plugged into the motherboard, and firmware on the MB keeps track of the system fans, along with everything else. If a system fan is failing, or has failed, the signal is sent to shut down. Some PC's will shut down cleanly, others give error messages, and some just freeze up. Of course, Bad RAM, video cards, and hard drives with bad sectors, can also cause problems like you have discribed.
I would write down any error messages, and beep codes, and then look them up online for a place to start.
Oct 22, 2009 | Apple Power Mac G5 Desktop
I have a kodak M1033 camara with a SD HC PNY optima 240 HD 16 GB and the camara says internal memory is full and is only 1/2 minute video in the camara please help
Hi!
Sonds like the camera hasn't switched to the memory card. Go to setup and set memory to Auto not Internal. If that doesn't help, it's possible that the camera doesn't support 16GB card, but it should give you a card error then, so check the memory settings first.
Tom
Oct 06, 2009 | Kodak EasyShare M1033 Digital Camera
My digital camara will not save pictures. Messages appear.
If you are using SD memory card, it can be locked. Take out your memory card, on the left side there's a switch. Turn switch up and try again. Hope this will work.
Aug 09, 2009 | Cameras
Camara on blackberry phone does not work
You can clear the memory by doing a soft reset - Hold down Left Alt, Right Shift and Delete keys simultaneously for a couple of seconds which will clear the memory.
Let me know how you get on with the above.
Jun 02, 2009 | AT&T Blackberry Curve 8300 Smartphone
Try turning off the phone and then removing the battery for a few minutes. Replace the battery and then then let the phone reboot, it should work fine after it reboots.
May 31, 2009 | AT&T Blackberry Curve 8300 Smartphone
Help
Here's the fix (condensed from another post):
Turn the camera off. Then, put the camera in manual mode (turn the dial to A S M) and then take a picture. Card formats and all is fine.
This works for some reason. Thanks to original poster out there somewhere.
Nov 25, 2007 | Olympus C-3000 Zoom Digital Camera
O2 xda orbit shuts down after several minutes
hi there..
it seems the os of your phone shomehow got curropted..first hard reset your phone using.... camara+recording button+power button and reset it with stylus....but you will loose your data stored on phone.....bet data on storage card will be saved........if this solve your problem...thats great...in case if not...reinstall the os on PDA...this will surely solve your problem...
All the Best.
Was this solution helpful? Show your Appreciation by rating it:
Aug 23, 2007 | O2 Xda Orbit Smartphone
Polaroid i1035 Digital Camera Logo
48 people viewed this question
Top Polaroid Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
