Question about Kohler CH25 PA-CH730-0040 Command Gasoline Engine
Engine revs up and down, improves when choking half way
JDeere kohler command 23 revs back and forth when on high throttle especially when hot thanks LB
    Novelist:
  • 168 Answers
Sounds like to me that your governor may need to be adjusted. Too much detail to explain here as to how to do it.
A dealers technician can fix that in 5 minutes if he knows what he's doing.
Posted on Oct 28, 2009
I have an older craftsman snow blower 10 hp. It starts ok with full choke, runs ok half choke, backfires with no choke-run position.
It's too lean; not enough fuel mixed with the air. Look for the main mixture screw--it should be a large screw with a spring under it on the carburetor. Run the engine until it's warm.
With the engine running, turn the screw outward (lefty-loosey) about 1/8 turn slowly and see if it improves. Slowly turn the screw back and forth until it runs best with the choke completely off. Then set it 1/8 turn richer (turn screw outward 1/8 turn) than the best position.
Reason for doing this: Conditions change, even the barometric pressure. Small engines run okay if they are a little rich but not if they are a little lean.
Mar 03, 2015 | Garden
Rpm high after starting the engine of R15 v.2
It sounds as if a throttle cable or choke cable is either sticking or badly routed . Most bikes rev high at cold start then the revs should decrease as the engine warms up. I would check the throttle and choke cables first make sure they lubricated and operate smoothly and especially with the throttle cable if you open it slowly does it return immediately you take your hand away. It should almost snap shut. I would also check out the pilot air screw in the carb these get clogged with debris from the petrol over time. Before you take the pilot air screw out turn it clockwise into the carb and note how many turns it takes until it stops (do not over tighten this screw) be very gentle when you do this. Check your user manual to see if the turns in you found match the turns out in the manual. Also make sure the tick over (idle) adjuster screw is set correctly your bike should idle at approx 1,200 to 1,300 RPM when hot. My Yamaha 125 is 1,300 RPM my Suzy 650 about the same.
Jan 09, 2015 | Yamaha Motorcycles
I got my mower out the other day it did fine till I engaged the electric pto, it then died and I cant get it started since then. It is getting spark and is getting fuel. It act like it is flooded , I have...
If the fuel is set too high and the choke is on it is easy to flood it. The solution is to open the choke and keep the throttle low for a few turns to air dry the spark plugs then back to choke to start it again
Oct 16, 2013 | Kohler CH25 PA-CH730-0040 Command Gasoline...
My kohler command 27 choke will not stay in it keeps working its way out and i have to keep pushing it back in how do i stop this it is beginning to annoy me
i have a 25hp kohler ch25s that does the same thing sometimes.. i figure it has to do with the spring that connects the throttle cable to the mechanism that connects to the carb.
Dec 19, 2010 | Kohler CH25 PA-CH730-0040 Command Gasoline...
Kohler ch18f revs up and down at half throttle. is this normal?
No this isn't normal. Sounds like high speed adjustment is to lean. Back it out counter clock wise with machine running until it smooths out.
Oct 11, 2010 | Cub Cadet Garden
John Deere Mower Engine Issue
HAVE YOU CHECKED THE CARB AT ALL? LOOK AT THE LINKAGE & MAKE SURE IT MOVES FREELY! IF CARB CHECKS OUT MAKE SURE GOVENER IS ADJUSTED RIGHT!!
Sep 05, 2009 | Kohler CH25 PA-CH730-0040 Command Gasoline...
Kohler small engine problem
1989 Kohler 20 backfires through the exhaust. What are the possible causes?
Jun 02, 2009 | Kohler CH25 PA-CH730-0040 Command Gasoline...
Kohler CH25 PA-CH730-0040 Command Gasoline Engine Logo
705 people viewed this question
Top Kohler Electrical Supplies Experts
rjivaro
John Trevino
Wayne McNeil
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
