Question about Kitchen Ranges
Burner light stays on even if burner is off and stays cool
I recently replaced a bad burner, but the burner light still flickers and stays on even when the burner is turned off and is cool to the touch. Do I need to worry about this or is it just an issue with the light? It is an Amana electric oven with ceramic cooktop.
    President:
  • 1,304 Answers
You have the ground wire for that burner on the wrong pin your loosing ground somewhere
so the sensor is reading hot
Posted on Oct 03, 2009
Heater is not igniting
see this causes and fix it. God bless you
f there is no heat, check the electrical service panel for a burned fuse or tripped breaker. Relight the pilot light (see below). If there is not enough heat, adjust the burner air shutter (see below); and clean the burner ports (see below).
If the pilot light does not light or does not stay lit, clean the pilot orifice carefully with a toothpick, test the thermocouple and replace it if it is faulty (see below).
If the flame flickers, adjust the pilot (see below).
If there is an exploding sound when the burner ignites, adjust the pilot to a higher setting and clean the pilot orifice and the burner ports.
If the burner takes more than a few seconds to ignite, clean the pilot orifice and adjust the pilot light.
If the burner flame is uneven, clean the burner ports. If the burner flame is very yellow, clean the burner; open vents in the furnace room to provide more air; adjust the burner air shutter.
If the furnace makes a rumbling noise when the burners are off, clean the burner and adjust the burner air shutter.
If the air is too dry, wash or replace the evaporator pad if you have a humidifier; test the humidistat; and adjust the water-level float to raise the water level.
If some rooms are too cool and others too warm, the distribution system may require balancing. Refer to the Forced-Air Distribution Fix-It Guide .
Oct 08, 2012 | Intertherm Heating Cooling System 15kw...
The light for the right back burner stays on,even though the burner is turned off and is cool
Here is a tip that I wrote about the problem of the cooktop light staying on.
Oven Hot Surface Indicator Light stays on
heatman101
Dec 25, 2010 | Microwave Ovens
The oven seldom lights. Igniter is working, there's usually no smell of gas, burners and broiler are working properly, replaced dual gas safety valve with no help. When it does light, it won't maintain...
Just because it glows that does not mean it is not bad...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Sep 07, 2010 | Maytag Kitchen Ranges
Pilot will stay lit but burner goes out about 1 minute after it lights
The thermocouple is bad. You get the thermocouple very hot when lighting it, but then it cools down a bit even with the main flame on, and it shuts the burner down.
Replace the thermocouple and you will be good again.
heatman101
Mar 26, 2010 | Water Heaters
The cooktop indicator light is still on even when all the knobs are in the Off position on my Whirlpool range model RF265LXTY
MOST SMOOTH TOP ELECTRIC STOVES THE INDICATOR LIGHT WILL STAY ON UNTIL THE BURNER COOLS OFF.IF THE BURNER IS COOLED THEN ONE OF YOUR SURFACE BURNER SWITCHES IS BAD AND WILL NEED REPLACEMENT .HOPE THIS HELPS .PLEASE RATE MY RESPONSE :)
Dec 12, 2009 | Whirlpool RF265LXT Range
LIGHT STAYS ON FOR HOURS BUT THE TOP HAS COOLED
if its going out, its probably ok
its not a light indicating the burner is on, rather that the glass is abcove 100 degrees and still not safe to put something on
2 hours is a bit long but it depends on how fst the surface can cool of
you can test this by trying to cool it off faster with a fan ans see what happens
Oct 21, 2009 | Whirlpool RCC3024 Electric Cooktop
Red light stays on indicating burner is on when burner is not on.
It should stay on after the burner has been turned off and remain on until the top has completely cooled down,if it stays on and never goes off, the thermostat for one or more burners is faulty and will need replaced.
Jul 26, 2009 | Frigidaire FEF366 Electric Kitchen Range
We have a Kenmore model #790.96011407 range with smooth top. It was working fine until recently one, then the other, front burner started operating on their own. They will not turn off when you turn the...
If this is happening on more than one burner the command module may be bad, small cicuit board inside control panel. With power disconnected easy replacement. check wiring to each burner control 1st by removing control panel cover. Be careful to remove small screws on either side of panel between panel & burner.
Jun 27, 2009 | Kenmore 96012 / 96014 / 96019 Electric...
Burner light does not go off on Amana AKT3040
Sounds like a short in that particular burner circuit. Usually when the light stays on even after cool down the heat sensor is bad. This is inside the burner. If your getting white smoke the burner switch could also be shorted out.
Apr 05, 2008 | Amana AKT3040 Electric Cooktop
Kitchen Ranges Logo
473 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
