Question about Refrigerators
Refrigeration related-working on Randall eq/ sald bar at round table, salad bar not getting below 50 deg. no leak has been detected. could really use advice, already tried their tech dept
    Director Badge:
    Uploaded 100 video answers.
  • Refrigerators Master
  • 488 Answers
Posted on Jun 25, 2017
  • 358 Answers
Probably the condenser coil (the one by the compressor ) is dirty , even if doesn't look dirty ,if the unit is located inside the kitchen always grease gets in the coil , go to a refrigeration store and get a condensing coil cleaner , unplugged the unit , spray the cleaner and rinse it with water (is better with a hose , try not to spray water to the electrical parts or wires).
Posted on Sep 26, 2009
True prep table leaking water.
The drain tube that drains out the water is plugged. It runs from inside the cabinet to under the refrigeration unit outside the cabinet. Try to clean it out with a can of compressed air used to clean keyboards and see of that works.
Sep 19, 2016 | True TSSU-48-12 - 48 Sandwich Salad Prep...
What is the normal fluctuation range of a top freezer in a freeze-refrig combo? That is if I set the temperature of the freezer a 0 F, at what temperature should the freezer come on to keep the air i
Hello Richard;
My name is Peter. I am a retired field service refrigeration technician.
The normal range for a freezer is -2 to +2 Deg. F.
The normal range for the fresh food section is 35 to 40 Deg. F.
If you set your freezer at 0 Deg. F. it will stay at 0 Deg. F.
When the freezer temperature drops below 0, your compressor will kick in to bring the freezer back to 0 Deg. F.
Dec 15, 2014 | Frigidaire Refrigerators
Adjust true prep table door
There are plastic cams in the hinges that wear and are replaceable. A company called Case Parts supplies a lot of refrigeration hardware like that and the web site should help and another company is called Refrigeration Hardware. The parts breakdown will show you what I mean. Hope this helps and good luck.
Oct 10, 2014 | True TSSU-48-12D-4-ADA 49" ADA Compliant...
Fan motor is good but does not come on with compressor
Is your system leak free? You could have the charge tested by a refrigeration specialist.
Sep 06, 2014 | Refrigerators
How do i adjust the EQ on the Eclipse 180G2
These answers are not even related to the problem. He wants to customize the equalizer, which is *clearly* an option. However, our Eclipse 180g2 players are not allowing us to switch bands, so we can only adjust the first bar of our equalizer.
How do we switch bands and fully adjust the equalizer?
Nov 28, 2013 | Eclipse Audio Players & Recorders
How do get to evap fans? One of them is causing the unit to pop the GFI.
Hi.
To reach the fan remove panel located behind the pans:
If instead you need to reach thermostat and evaporator, remove the panel at the back of the refrigeration compartment to reach the evaporator at the back.
Here the full service manual:
SERVICE MANUAL DOWNLOAD
Regards.
Ginko
May 28, 2011 | Turboair Turbo Air Sandwich Salad Table...
Model TSSU-48-08 Sandwich/salad prep table. I think it is a 1998 unit, so it has some age but is in nice shape, like new. I need to get it working. Doesn't cool. Compressor motor, evaporator fan...
You have it figured out...get it tested for leaks, fix them and recharge the unit...
Make sure to get a professional to do the work...
Here is a tip that I wrote about how to add refrigerant to a air conditioner or cooling system
How to add Freon to a Air Conditioner or Refrigeration System
heatman101
Sep 26, 2010 | True 598-TSSU608ADA SandwichSalad Unit 155...
Turbo air sandwich table too cold
Replace the thermostat which is located on the back of the unit underneath the bins in the very back. If the thermostat goes bad it will let everything just run and run and run. If this has been helpful please rate
Feb 12, 2009 | Turboair Turbo Air Sandwich Salad Table...
Casio tk1300
I'm in Australia and only going on the program manual for your area, it states that canadian tax is tax on tax? if this is true then you probably entered a code for add on or add in tax and thereby changed it all.
you need the following
tax table address
1 125
2 225
3 325
4 425
rounding off codes
rounding off to 2 decimal places is 50
rounding up to 2 decimal places is 90
cut off to 2 decimal places is 00
tax system code
tax table with out tax rate 01
tax table with tax rate and add on rate 02
add in tax rate 03
Canadian tax-on-tax rate 04
starting point
to get the starting point you multiply by 100 and subtract 1
eg 50 cents = 0.50 X 100 - 1 = 50 - 1 = 49
eg $4 = 4.00 x 100 -1 = 399
to program the tables go through these steps
go to program 3
tax table address eg 125
subtotal
tax rate
ca/amt tend
starting point eg 0.50 = 49
ca/amt tend
rounding eg 50
tax system eg 04
ca/amt tend
ca/amt tend
here you have 2 choices,
press ca/amt tend to go to the next tax table ie 225 and start over by entering the tax rate and go through the procedure again
or
press subtotal to finalise the tax table you are on
Hope this helps,
Adam
Apr 18, 2008 | Casio Parts Cash Register PC Desktop
Refrigerators Logo
56 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
